是不是你想要的?
- #ifndef __BSP_H
- #define __BSP_H
- #include <stdbool.h>
- #include "bspconfig.h"
- #if defined( BSP_STK )
- #include "em_usart.h"
- #endif
- #ifdef __cplusplus
- extern "C" {
- #endif
- /** @addtogroup BSPCOMMON API common for all kits */ /** @{ */
- #define BSP_STATUS_OK 0 /**< BSP API return code, no errors. */
- #define BSP_STATUS_ILLEGAL_PARAM (-1) /**< BSP API return code, illegal input parameter. */
- #define BSP_STATUS_NOT_IMPLEMENTED (-2) /**< BSP API return code, function not implemented (dummy). */
- #define BSP_STATUS_UNSUPPORTED_MODE (-3) /**< BSP API return code, unsupported BSP mode. */
- /* Initialization flag bitmasks for BSP_Init(). */
- #define BSP_INIT_DK_SPI 0x01 /**< Mode flag for @ref BSP_Init(), init DK in SPI mode (DK3x50 only). */
- #define BSP_INIT_DK_EBI 0x02 /**< Mode flag for @ref BSP_Init(), init DK in EBI mode (DK3x50 only). */
- #define BSP_INIT_BCC 0x04 /**< Mode flag for @ref BSP_Init(), init board controller communication. */
- #if defined( BSP_DK )
- /** @addtogroup BSP_DK API for DK's */ /** @{ */
- /** Display Control */
- typedef enum
- BSP_Display_EBI, /**< SSD2119 TFT controller driven by EFM32 EBI interface */
- BSP_Display_SPI, /**< SSD2119 TFT controller driven by EFM32 SPI interface */
- BSP_Display_BC, /**< SSD2119 TFT controller driven by board controller (AEM) */
- BSP_Display_PowerEnable, /**< SSD2119 Enable power */
- BSP_Display_PowerDisable, /**< SSD2119 Disable power */
- BSP_Display_ResetAssert, /**< Hold SSD2119 in reset */
- BSP_Display_ResetRelease, /**< Release SSD2119 in reset */
- BSP_Display_Mode8080, /**< Configure SSD2119 for 8080 mode of operation */
- BSP_Display_ModeGeneric, /**< Configure SSD2119 for Generic+SPI mode of operation */
- } BSP_Display_TypeDef;
- /** Bus control access mode */
- typedef enum
- BSP_BusControl_Undefined=0, /**< Board control mode unknown (not set) */
- BSP_BusControl_OFF, /**< Board control disable */
- BSP_BusControl_DIRECT, /**< GPIO direct drive (n/a) */
- BSP_BusControl_SPI, /**< Configure Board controller for SPI mode */
- BSP_BusControl_EBI, /**< Configure Board controller for EBI mode */
- } BSP_BusControl_TypeDef;
- #if defined( BSP_DK_3200 ) /* Gxxx_DK */
- /** Peripherals control structure for Gxxx_DK's. */
- typedef enum
- BSP_ACCEL = BC_PERCTRL_ACCEL, /**< Accelerometer */
- BSP_AMBIENT = BC_PERCTRL_AMBIENT, /**< Light sensor */
- BSP_POTMETER = BC_PERCTRL_POTMETER, /**< Potentiometer */
- BSP_RS232A = BC_PERCTRL_RS232A, /**< Serial port A */
- BSP_RS232B = BC_PERCTRL_RS232B, /**< Serial port B */
- BSP_SPI = BC_PERCTRL_SPI, /**< SPI interface */
- BSP_I2C = BC_PERCTRL_I2C, /**< I2C interface */
- BSP_IRDA = BC_PERCTRL_IRDA, /**< IrDA interface */
- BSP_ANALOG_SE = BC_PERCTRL_ANALOG_SE, /**< Single ended analog input */
- BSP_ANALOG_DIFF = BC_PERCTRL_ANALOG_DIFF, /**< Differential analog input */
- BSP_AUDIO_OUT = BC_PERCTRL_AUDIO_OUT, /**< Audio Out */
- BSP_AUDIO_IN = BC_PERCTRL_AUDIO_IN, /**< Audio In */
- BSP_ACCEL_GSEL = BC_PERCTRL_ACCEL_GSEL, /**< Accelerometer range select */
- BSP_ACCEL_SELFTEST = BC_PERCTRL_ACCEL_SELFTEST, /**< Accelerometer selftest mode */
- BSP_RS232_SHUTDOWN = BC_PERCTRL_RS232_SHUTDOWN, /**< Disable RS232 */
- BSP_IRDA_SHUTDOWN = BC_PERCTRL_IRDA_SHUTDOWN /**< Disable IrDA */
- #ifdef DOXY_DOC_ONLY
- } BSP_Peripheral_Typedef; /* Hack for doxygen doc ! */
- #else
- } BSP_Peripheral_TypeDef;
- #endif
- #endif /* BSP_DK_3200 */
- #if defined( BSP_DK_3201 ) /* DK3x50 DK's */
- /** Peripherals control structure for DK3x50 DK's. */
- typedef enum
- BSP_RS232_SHUTDOWN, /**< Disable RS232 */
- BSP_RS232_UART, /**< UART control of RS232 */
- BSP_RS232_LEUART, /**< LEUART control of RS232 */
- BSP_I2C, /**< I2C interface */
- BSP_ETH, /**< Ethernet */
- BSP_I2S, /**< Audio I2S */
- BSP_TRACE, /**< ETM Trace */
- BSP_TOUCH, /**< Display touch interface */
- BSP_AUDIO_IN, /**< Audio In */
- BSP_AUDIO_OUT, /**< Audio Out */
- BSP_ANALOG_DIFF, /**< Differential analog input */
- BSP_ANALOG_SE, /**< Single ended analog input */
- BSP_MICROSD, /**< MicroSD SPI interace */
- BSP_TFT, /**< SSD2119 TFT controller */
- #endif /* BSP_DK_3201 */
- #endif /* BSP_DK */
- /************************** The BSP API *******************************/
- int BSP_Disable ( void );
- int BSP_Init ( uint32_t flags );
- int BSP_LedClear ( int ledNo );
- int BSP_LedGet ( int ledNo );
- int BSP_LedSet ( int ledNo );
- uint32_t BSP_LedsGet ( void );
- int BSP_LedsInit ( void );
- int BSP_LedsSet ( uint32_t leds );
- int BSP_LedToggle ( int ledNo );
- BSP_BusControl_TypeDef BSP_BusControlModeGet( void );
- int BSP_BusControlModeSet ( BSP_BusControl_TypeDef mode );
- uint32_t BSP_DipSwitchGet ( void );
- int BSP_DisplayControl ( BSP_Display_TypeDef option );
- int BSP_EbiExtendedAddressRange ( bool enable );
- int BSP_EnergyModeSet ( uint16_t energyMode );
- int BSP_InterruptDisable ( uint16_t flags );
- int BSP_InterruptEnable ( uint16_t flags );
- int BSP_InterruptFlagsClear ( uint16_t flags );
- uint16_t BSP_InterruptFlagsGet ( void );
- uint16_t BSP_JoystickGet ( void );
- int BSP_McuBoard_DeInit ( void );
- int BSP_McuBoard_Init ( void );
- int BSP_McuBoard_UsbStatusLedEnable ( bool enable );
- bool BSP_McuBoard_UsbVbusOcFlagGet ( void );
- int BSP_McuBoard_UsbVbusPowerEnable ( bool enable );
- int BSP_PeripheralAccess ( BSP_Peripheral_TypeDef perf, bool enable );
- uint16_t BSP_PushButtonsGet ( void );
- uint16_t BSP_RegisterRead ( volatile uint16_t *addr );
- int BSP_RegisterWrite ( volatile uint16_t *addr, uint16_t data );
- #endif
- int BSP_BccDeInit ( void );
- int BSP_BccInit ( void );
- bool BSP_BccPacketReceive ( BCP_Packet *pkt );
- int BSP_BccPacketSend ( BCP_Packet *pkt );
- void BSP_BccPinsEnable ( bool enable );
- float BSP_CurrentGet ( void );
- int BSP_EbiDeInit ( void );
- int BSP_EbiInit ( void );
- float BSP_VoltageGet ( void );
- #endif
- #endif
- #endif /* __BSP_H */
復(fù)制代碼 |
