查看: 3779|回復(fù): 6
32單片機(jī)軟件ROM自檢程序怎么寫?
ID:404662 發(fā)表于 2023-2-13 15:42 | 顯示全部樓層 |閱讀模式
現(xiàn)在在做一款32位單片機(jī)軟件自檢程序,在做ROM的CRC校驗(yàn)自檢時(shí)遇到問題,認(rèn)證公司要求先把程序的CRC校驗(yàn)值寫到FLASH固定地址里面(該地址不做CRC校驗(yàn)),進(jìn)入自檢的時(shí)候程序進(jìn)行CRC計(jì)算,然后與放在FLASH固定地址的CRC比較來檢驗(yàn)ROM區(qū)域的程序是否有異常變化,自己寫了程序應(yīng)該是有BUG,有大佬提供一下例程不?
// 引用外部函數(shù)extern uint32_t iec60730_ram_march_bist_test(uint32_t addr);extern void iec60730_reg_r1_r4_bist_test(void);extern void iec60730_reg_r0_bist_test(void);extern void iec60730_reg_r8_r12_bist_test(void);extern void iec60730_reg_sp_bist_test(void);extern void iec60730_reg_spec_bist_test(void);extern void iec60730_reg_lr_bist_test(void);extern void iec60730_pc_test(void);extern CPUStatus STL_RunTimeCPUTest(void);void PC_Test_Func1(void)__attribute__((section(".ARM.__at_0x00003ff0"))); //地址以4為單位遞增,不然編譯不通過,函數(shù)聲明需要放在文件最上面聲明void PC_Test_Func2(void)__attribute__((section(".ARM.__at_0x0000400c"))); const  uint32_t  CRC_Result __attribute__((at(0x00007F8C))) = 0x00006EFF;uint32_t RamTestResult = 0;uint32_t CpuTestResult = 0;uint32_t crcResult = 0;/*flash self test*/static uint32_t _FLASH_CRC;// 棧底數(shù)據(jù)__IO uint32_t StackOverFlowPtrn[4]   __attribute__((section("STACK_BOTTOM"), zero_init));// 每次校驗(yàn)的數(shù)據(jù)量#define ROM_BIST_SIZE           8 /*  8 bytes every time */#define ROM_START (0x0)#define FLASH_ROM_START_ADDR (0x0)#define FLASH_ROM_SIZE       (20480)//(32*1024)//#define FLASH_ROM_SIZE       (32*1024)#define ROM_END   ((uint32_t)(FLASH_ROM_SIZE - 1))#define ROM_SIZE  ((uint32_t)ROM_END - (uint32_t)ROM_START + 1)static volatile uint32_t hw_crc,sw_crc;// bref: 測試flash// para:// note:static void ROM_Test(void){        stl_uint8_t* p_flash_start_addr = (stl_uint8_t*)FLASH_ROM_START_ADDR;        iec_test_result.rom_test_result = IEC_TEST_SUCCESS;                CRC_Init();        /*open crc apb clock*/        SYS_EnablePeripheralClk(SYS_CLK_CRC_MSK);        /* use hardware CRC16 to calculate expected crc first,                  then verify if the CRC code calculated by software is same with expected crc */           hw_crc = IEC60730_HardwareCRC16Gen(p_flash_start_addr, ROM_SIZE);        if(IEC60730_TEST_NORMAL != IEC60730_SoftwareCRC16Test(p_flash_start_addr, ROM_SIZE, hw_crc)){                iec_test_result.rom_test_result = IEC_TEST_FAIL;        }        // 使用過硬件CRC 完成一個(gè)完整的校驗(yàn) 選喲重新初始化        CRC_Init();        /* use software CRC16 to calculate expected crc first,                  then verify if the CRC code calculated by hardware is same with expected crc */        sw_crc = IEC60730_SoftwareCRC16Gen(p_flash_start_addr, ROM_SIZE);        if(IEC60730_TEST_NORMAL != IEC60730_HardwareCRC16Test(p_flash_start_addr,ROM_SIZE, sw_crc)){                iec_test_result.rom_test_result = IEC_TEST_FAIL;        }                // 記錄整個(gè)flash 區(qū)域的校驗(yàn)值        _FLASH_CRC = hw_crc;        crcResult = CRC_Result;        if(crcResult == sw_crc)//_FLASH_CRC CRC_Result        {                iec_test_result.rom_test_result = IEC_TEST_SUCCESS;        }        else        {                iec_test_result.rom_test_result = IEC_TEST_FAIL;        }        }
ID:996773 發(fā)表于 2023-2-15 16:14 | 顯示全部樓層
程序rom還能自檢?本人才疏學(xué)淺,一般單片機(jī)程序稍大一些1k起步,再大幾十k夠大了,如何自檢每個(gè)字節(jié)
甚至每個(gè)位能無差錯(cuò)?用什么原理,拭目以待等候高手出現(xiàn)
ID:1044091 發(fā)表于 2023-2-15 16:53 | 顯示全部樓層
STP ISP 在讀入hex文件那一刻,已經(jīng)對(duì)整個(gè)hex進(jìn)行校驗(yàn)計(jì)算了。
ID:89217 發(fā)表于 2023-2-15 22:19 | 顯示全部樓層
理論上只要程序正常運(yùn)行,程序就是對(duì)的,如果還要較驗(yàn)的話有什么意義?會(huì)不會(huì)被人故意刁難?
ID:1044091 發(fā)表于 2023-2-15 23:15 來自觸屏版 | 顯示全部樓層
我自己寫的eeprom連續(xù)讀寫代碼,每次存入12個(gè)字節(jié)。第一位是序號(hào),第2~11位是數(shù)據(jù),第12位是校驗(yàn)位。讀的時(shí)候校驗(yàn)一次,有問題就讀默認(rèn)數(shù)據(jù)。目的是為了防止eeprom寫入錯(cuò)誤,比如存儲(chǔ)單元損壞,或?qū)懭霑r(shí)意外斷電等。雖然幾率很小,但有預(yù)案總比沒有強(qiáng)。
ID:1044091 發(fā)表于 2023-2-16 19:27 | 顯示全部樓層
按照我的理解,所謂校驗(yàn)就是按地址順序讀出這段數(shù)據(jù),然后計(jì)算(比如累加求和),再與已存在的校驗(yàn)位比較,一致就是哪都沒錯(cuò)往下走;不一致就報(bào)錯(cuò)或者B計(jì)劃。應(yīng)該幾句代碼就搞定了,為何被你寫的如此復(fù)雜?
ID:496636 發(fā)表于 2023-2-19 00:11 | 顯示全部樓層
CRC較驗(yàn)啊,浙大中控,在工程師站編好程序后,編譯下載到控制站,下載好后,再回讀,進(jìn)行CRC較驗(yàn),得到CRC較驗(yàn)值與編譯好后下載前計(jì)算出來的CRC較驗(yàn)值進(jìn)行比較,如果相等,下載到控制站的程序無誤。
同時(shí),這次回讀生成的CRC較驗(yàn)值將保存起來,下次編譯后要下載的時(shí)候,將當(dāng)前的程序的CRC較驗(yàn)值與上次保存的CRC值比較,如果相等,提示程序沒有變化,無須下載,如果不相等,提示下載后會(huì)改變原來的程序,是否繼續(xù)。
CRC較驗(yàn)就是用商定好的一個(gè)數(shù)據(jù)作為除數(shù),待較驗(yàn)的數(shù)據(jù)作為被除數(shù),進(jìn)行除法運(yùn)算,除法運(yùn)算的時(shí)候沒有進(jìn)位和借位
