網上找來的程序,基于51單片機的倒計時裝置,定時時間到后蜂鳴器鳴叫,倒計時結束,想添加一個控制繼電器功能,就是計時開始繼電器吸合,計時結束繼電器釋放,不知道怎么加,請各位大佬幫幫忙,在此謝過了!
以下是源碼:
// Copyright (C) 2020 Jobcrazy
// All rights reserved
#include <reg52.h>
//Button registers
sbit Step1m = P3^6; //按鍵3,+1分鐘
sbit Step10m = P3^5; //按鍵2,+10分鐘
sbit Step1h = P3^4; //按鍵1,+1小時
sbit StepStart = P3^7; //按鍵4,開始計時
//Beep register
sbit Beep = P1^6; //蜂鳴器
//Relay
sbit Relay = P1^7; //繼電器
//Time Led Dot register
sbit TIME_DOT = P1^5; //數碼管":"
//Time Led Segment register
sbit ShuMa_Duan_0 = P1^0; //數碼管1
sbit ShuMa_Duan_1 = P1^1; //數碼管2
sbit ShuMa_Duan_2 = P1^2; //數碼管3
sbit ShuMa_Duan_3 = P1^3; //數碼管4
//Initial settings
#define DEFAULT_HOUR 00
#define DEFAULT_MINUTE 00
#define DEFAULT_SECOND 00
volatile int Hour = DEFAULT_HOUR;
volatile int Minute = DEFAULT_MINUTE;
volatile int Second = DEFAULT_SECOND;
//Led Number Definitions
code unsigned char ShuMa_Data[10] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92,0x82,0xF8,0x80,0x90};
//Led Number Indexes
volatile int Shi_Left = 0;
volatile int Ge_Left = 0;
volatile int Shi_Right = 0;
volatile int Ge_Right = 0;
//Delay 1 minisecond
void Delay_1ms( int i )
for( ; i > 0; --i )
int j = 0;
for( ; j < 110; ++j )
//Timer Settings
void Init_Timer()
TMOD = 0x11; //Using timer 0 and timer 1
TH0 = 0xB8;
TL0 = 0x00; //Timer0 = 20ms
TH1 = 0xB8;
TL1 = 0x00; //Timer1 = 20ms
TR0 = 0x01; //Enable Timer 0
TR1 = 0x00;
//Enable Timer
void Init_Interrupt()
ET0 = 1;
ET1 = 1;
EA = 1;
//Show Number on the Timer Led
void ShuMa(unsigned char ShuMa_Wei, unsigned char ShuMa_Index)
P2 = ShuMa_Data[ShuMa_Index];
if( ShuMa_Wei == 0 )
ShuMa_Duan_0 = 0;
ShuMa_Duan_1 = 1;
ShuMa_Duan_2 = 1;
ShuMa_Duan_3 = 1;
else if( ShuMa_Wei == 1 )
ShuMa_Duan_0 = 1;
ShuMa_Duan_1 = 0;
ShuMa_Duan_2 = 1;
ShuMa_Duan_3 = 1;
else if( ShuMa_Wei == 2 )
ShuMa_Duan_0 = 1;
ShuMa_Duan_1 = 1;
ShuMa_Duan_2 = 0;
ShuMa_Duan_3 = 1;
else if( ShuMa_Wei == 3 )
ShuMa_Duan_0 = 1;
ShuMa_Duan_1 = 1;
ShuMa_Duan_2 = 1;
ShuMa_Duan_3 = 0;
//We must delay 1ms here, or else the Led will not show a correct number
Delay_1ms(1);
//Convert the time to a displayable format
void CalcSecond()
if( 0 < Hour )
Shi_Left = Hour / 10;
Ge_Left = Hour % 10;
Shi_Right = Minute / 10;
Ge_Right = Minute % 10;
Shi_Left = Minute / 10;
Ge_Left = Minute % 10;
Shi_Right = Second / 10;
Ge_Right = Second % 10;
//Counter Timer
void Interrupt_Timer_0() interrupt 1
static int Counter = 0;
TH0 = 0xB8;
TL0 = 0x00;
++Counter;
if( 49 < Counter )
//Ths scope will run 1 time per second
Counter = 0;
TIME_DOT = ~TIME_DOT;
Second--;
//Let's see how long time is left
if( Second < 0 )
Second = 59;
Minute -= 1;
if( Minute < 0 )
if( 0 < Hour )
Hour--;
Minute = Second = 59;
Hour = Minute = Second = 0;
TR0 = 0; //Disable counter timer
TR1 = 1; //Enable Beep Timer
CalcSecond();
//Beep timer
void Interrupt_Timer_1() interrupt 3
static int n = 0, Counter = 0;
TH1 = 0xB8;
TL1 = 0x00;
++Counter;
if( Counter < 10 )
Beep = 0;
else if( Counter < 30 )
Beep = 1;
else if( Counter > 49 )
Counter = 0;
n++;
if( n >= 5 )
n = 0;
//Disable two timers
TR0 = 0;
TR1 = 0;
//Covert time to be recognizable
void formatTime()
if( Minute >= 60 )
Minute = 0;
Hour = Hour + 1;
if( Hour >= 99 )
Hour = 0;
Minute = 0;
Second = 0;
CalcSecond();
//To avoid long press
int Pressed = 0;
//Light Timer Dot
TIME_DOT = 0;
//Turn Off Beep
Beep = 1;
//Make P3 output high-level signal
P3 = 0xFF;
CalcSecond();
//Infinite loop
formatTime();
//Show time the led screen
ShuMa( 0, Shi_Left );
ShuMa( 1, Ge_Left );
ShuMa( 2, Shi_Right );
ShuMa( 3, Ge_Right );
if( 0 == TR0 && 0 == TR1 ) //If timer is not running
if( 0 == Step1m && 0 == Pressed )
//If Step1m button is pressed down
Pressed = 1;
Minute = Minute + 1;
else if( 0 == Step10m && 0 == Pressed )
//If Step10m button is pressed down
Pressed = 1;
Minute = Minute + 10;
else if( 0 == Step1h && 0 == Pressed )
//If Step1h button is pressed down
Pressed = 1;
Hour = Hour + 1;
else if( 0 == StepStart && 0 == Pressed )
//If StepStart button is pressed down
Pressed = 1;
if ( 0 != Hour || 0 != Minute || 0 != Second )
Init_Timer();
Init_Interrupt();
if( 1 == Step1m && 1 == Step10m && 1 == Step1h && 1 == StepStart )
//If no button is pressed down
Pressed = 0;
