查看: 1237|回復: 1
單片機萌新一枚,在調試雙色點陣的時候發現問題
目前的狀態就是:
1.只能確定顯示在哪一行,但是顯示在哪一行給的數據無論多少那行都會全部點亮
2.想要顯示圖形的時候,點陣會全部點亮
  1. #include<reg52.h>
  2. #include <intrins.h>
  3. unsigned char  Line[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}; //8行,一到八行
  4. unsigned char code tab[]={0x83,0x43,0x24,0x18,0x18,0x24,0x43,0x83};
  5. /*------------------------------------------------
  6.                 硬件端口定義
  7. ------------------------------------------------*/
  8. /*sbit LATCH = P1^0; //RCLK
  9. sbit SRCLK = P1^1;
  10. sbit SER  = P1^2;
  11. sbit LATCH_B = P2^2;//RCLK
  12. sbit SRCLK_B = P2^1;
  13. sbit SER_B = P2^0;*/
  14. sbit LATCH = P1^3; //RCLK,鎖存端
  15. sbit SRCLK = P1^4;
  16. sbit SER  = P1^5;
  17. sbit LATCH_B = P2^5;//RCLK
  18. sbit SRCLK_B = P2^4;
  19. sbit SER_B = P2^3;
  20. void DelayUs2x(unsigned char t)
  21. {
  22. while(--t);
  23. }
  24. void DelayMs(unsigned char t)
  25. {
  26. while(t--)
  27. {
  28.      //大致延時1mS
  29.      DelayUs2x(245);
  30.          DelayUs2x(245);
  31. }
  32. }
  33. /*------------------------------------------------
  34.                 發送字節程序
  35. ------------------------------------------------*/
  36. void SendByte(unsigned char dat)
  37. {
  38.   unsigned char i;
  39.    for(i=0;i<8;i++)
  40.         {
  41.                                  SER=dat&0x80;
  42.          dat<<=1;
  43.          SRCLK=0;
  44.          SRCLK=1;
  45.          }
  46. }
  47. /*------------------------------------------------
  48.                 發送雙字節程序
  49. ------------------------------------------------*/
  50. void Send2Byte(unsigned char dat1,unsigned char dat2)
  51. {
  52.    SendByte(dat1);
  53.    SendByte(dat2);
  54. }
  55. /*------------------------------------------------
  56.                    595鎖存程序
  57.                   595級聯發送數據后,鎖存有效
  58. ------------------------------------------------*/
  59. void Out595(void)
  60. {
  61.         LATCH=0;
  62.         _nop_();
  63.         LATCH=1;
  64. }
  65. /*------------------------------------------------
  66.                 發送位碼字節程序
  67.                使用另外一片單獨595
  68. ------------------------------------------------*/
  69. void SendCol(unsigned char dat)
  70. {
  71. unsigned char i;
  72.    for(i=0;i<8;i++)  //發送字節
  73.         {
  74.          SER_B=dat&0x80;
  75.          dat<<=1;
  76.          SRCLK_B=0;
  77.                                  SRCLK_B=1;
  78.          }
  79.       LATCH_B=0;    //鎖存
  80.       _nop_();
  81.       LATCH_B=1;
  82. }
  83. /*------------------------------------------------
  84.                    主程序
  85. ------------------------------------------------*/
  86. void main()
  87. {
  88.                                         unsigned char i,j;
  89.                                         while(1)
  90.                                                 {
  91.                            for(j=0;j<60;j++)
  92.               for(i=0;i<8;i++) //8列顯示
  93.                   {
  94.                      SendCol(Line[i]);
  95.        Send2Byte(tab[i],0xff);
  96.        Out595();
  97.        DelayMs(1);
  98.        Send2Byte(0xff,0xff);//delay(10); //防止重影
  99.        Out595();
  100.                   }
  101.                           /*for(j=0;j<60;j++)
  102.               for(i=0;i<8;i++) //8列顯示
  103.                   {
  104.                      SendCol(Line[7-i]); //反向顯示同樣圖形
  105.        Send2Byte(0x00,tab[i]);
  106.        Out595();
  107.        DelayMs(1);
  108.        Send2Byte(0xff,0xff);//delay(10); //防止重影
  109.        Out595()
  110.                   }*/
  111.                                                         }
  112. }
立創畫的,我現在手上也沒有文件了
立創畫的,我現在手上也沒有文件了
只能確定顯示再哪一行
只能確定顯示再哪一行
屏幕截圖 2023-02-02 180752.png (213.05 KB, 下載次數: 96)
想要測試顯示的圖形
想要測試顯示的圖形
屏幕截圖 2023-02-02 180714.png (387.63 KB, 下載次數: 91)
用的雙色點陣
用的雙色點陣
想要顯示圖形時卻全部點亮
想要顯示圖形時卻全部點亮
雙色.rar
19.59 KB, 下載次數: 3
ID:1062015 發表于 2023-2-2 18:26 | 只看該作者
原理圖那里我放了排母當做點陣,然后發現對應的接線和我買的這塊點陣不匹配,但是對應的實物我用杜邦線接到實物點陣上了,排除點陣接線問題
