查看: 2511|回復: 3
單片機驅動16*16點陣源程序(多種驅動方式)Proteus8.15仿真
ID:579397 發表于 2023-1-28 05:25 | 顯示全部樓層 |閱讀模式
設計了四套驅動方案:1、154+595驅動  2、154+P口驅動 3、595驅動  4、單片機P口驅動
程序為文字左移顯示
供初學者參考
單片機16×16點陣(154+595驅動)源程序如下:
  1. #include <intrins.h>                //函數,應用于程序設計
  2. #include <reg52.h>                //單片機頭文件
  3. /**********接口說明**********/
  4. sbit SER=P3^0;                        //DS 第14腳 串行數據輸入
  5. sbit SRCLK=P3^1;                //SH_CP        第11腳 數據輸入時鐘線
  6. sbit LATCH=P3^2;                //ST_CP        第12腳 輸出存儲器鎖存時鐘線
  7. sbit OE=P3^3;                                //OE 第13腳 輸出有效,低電平有效
  8.
  9. /**********全局變量**********/
  10. unsigned int word=1;                //數據位指針
  11. unsigned char column=0;                //列數,最大數16
  12. unsigned char time=5;                //走字速度,可修改
  13. unsigned char code segout[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //列掃描數組
  14. unsigned char code tab[]=
  15.         {
  16.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//空白位置
  17.                 /*以下文字開始*/
  18.                 0x00,0x01,0x00,0x02,0x03,0xEC,0x02,0x20,0x02,0x20,0x02,0x28,0xFE,0x26,0x12,0x20,0x12,0x28,0x12,0x26,0x12,0x20,0x13,0xE0,0x10,0x08,0x10,0x07,0x00,0x00,0x00,0x00,//點,1
  19.                 0x00,0x00,0x7F,0xFF,0x40,0x10,0x44,0x08,0x5B,0x10,0x60,0xE0,0x10,0x10,0x13,0x10,0x1D,0x10,0xF1,0x10,0x17,0xFF,0x11,0x10,0x11,0x10,0x11,0x10,0x10,0x10,0x00,0x00,0x00,0x00,//陣,2
  20.                 0x08,0x20,0x06,0x20,0x40,0x7E,0x31,0x80,0x00,0x01,0x7F,0xE2,0x40,0x0C,0x4F,0xF0,0x40,0x08,0x7F,0xE4,0x00,0x00,0x1F,0xE2,0x00,0x01,0xFF,0xFE,0x00,0x00,0x00,0x00,//測,3
  21.                 0x02,0x00,0x02,0x00,0x42,0x00,0x33,0xFC,0x00,0x08,0x09,0x14,0x09,0x06,0x09,0xFC,0x09,0x08,0x09,0x08,0xFF,0x80,0x08,0x70,0x88,0x0C,0x68,0x02,0x08,0x0F,0x00,0x00,0x00,0x00,//試,4
  22.                 0x24,0x10,0x24,0x60,0x25,0x80,0x7F,0xFF,0xC4,0x80,0x44,0x60,0x00,0x02,0x7C,0x92,0x44,0x92,0x44,0x92,0x44,0xFE,0x44,0x92,0x44,0x92,0x7C,0x92,0x00,0x82,0x00,0x00,0x00,0x00,//程,5
  23.                 0x00,0x02,0x00,0x0C,0x3F,0xF0,0x20,0x00,0x20,0x80,0x20,0x80,0x28,0x80,0xA8,0x82,0x6A,0x81,0x29,0xFE,0x2A,0x80,0x2C,0x80,0x28,0x80,0x20,0xA0,0x20,0xC0,0x00,0x00,0x00,0x00,//序,6
  24.                 /*以上文字結束*/
  25.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//空白位置
  26.                 0xBB,//結束碼
  27.                 };
  28.
  29. void Delay(unsigned char ms)
  30.         {
  31.                 unsigned char x,y;
  32.                 for(x=ms;x>0;x--)
  33.                 for(y=124;y>0;y--);
  34.         }
  35.
  36. void SendByte(unsigned char dat)
  37.         {
  38.                 unsigned char i;
  39.                 for(i=0;i<8;i++)
  40.                 {
  41.                         if(dat&0x01==1)
  42.                                 {
  43.                                         SER=1;
  44.                                 }
  45.                                 else
  46.                                         {
  47.                                                 SER=0;
  48.                                         }
  49.                                         dat>>=1;
  50.                                         SRCLK=0;
  51.                                         _nop_();
  52.                                         _nop_();                //空指令
  53.                                         SRCLK=1;
  54.                 }
  55.         }
  56.
  57. void Out595(void)                //給出上升沿
  58.         {
  59.                 LATCH=0;                //輸出存儲器鎖存時鐘線置0
  60.                 _nop_();
  61.                 _nop_();                //空指令
  62.                 LATCH=1;                //輸出存儲器鎖存時鐘線至1,給上升沿
  63.         }
  64.
  65. void Send_Rank(unsigned int dat)
  66.         {
  67.                 SendByte(tab[2*dat-1]);                //09~16行數據選擇
  68.                 SendByte(tab[2*dat-2]);                //01~08行數據選擇
  69.         }
  70.
  71. void main()
  72.         {
  73.                 while(1)                //無限循環
  74.                         {
  75.                                 unsigned char temp=0;
  76.                                 for(temp=time;temp>0;temp--)                //循環掃描,可修改走字速度
  77.                                         {
  78.                                                 for(column=0;column<16;column++)                //循環掃描16列
  79.                                                         {
  80.        P2=column;                //列掃描程序
  81.        Send_Rank(word);                //行數據顯示程序
  82.        Out595();                //給出上升沿
  83.        OE=0;                //74HC595輸出有效
  84.        Delay(2);
  85.        OE=1;                //消隱
  86.        word++;                //數據位指針加1,準備顯示下一行數據
  87.        }
  88.                                                         if(tab[2*word-2]==0xBB)                //判斷下一個顯示數據是否為結束碼,若是往下執行
  89.        {
  90.        word=1;                //行數據重新賦值
  91.        }
  92.        else
  93.        {
  94.        word-=16;                //行數據返回前16行
  95.        }
  96.                                         }
  97.                                         word++;                //行數據加1,達到顯示數據左移目的
  98.                                         }
  99.                                 }
Keil代碼與Proteus8.15版本的仿真下載(注意:不能兼容其他版本 只能用8.15打開):
點陣.7z (338.8 KB, 下載次數: 53)
參與人數 1黑幣 +80 收起 理由
admin + 80 共享資料的黑幣獎勵!
ID:408289 發表于 2023-2-7 13:44 | 顯示全部樓層
很經典的,非常值得看,反復看
ID:830831 發表于 2023-7-28 09:34 | 顯示全部樓層
老兄,請問Proteus8.15在哪下載的呀?
ID:1054732 發表于 2025-2-16 22:50 | 顯示全部樓層
里面程序是空的
