查看: 1734|回復: 2
單片機計算器程序error C267: 'LcdWriteCom': requires ANSI-style prototype
ID:1058309 發表于 2022-12-19 18:53 | 顯示全部樓層 |閱讀模式
想做一個簡易的計算器,程序出了點問題,有大神幫幫忙嗎
報錯信息:
jisuanqi.c(2): warning C318: can't open file 'lcd.h'
jisuanqi.c(3): warning C318: can't open file 'i2c.h'
jisuanqi.c(27): warning C206: 'LcdWriteCom': missing function-prototype
jisuanqi.c(27): error C267: 'LcdWriteCom': requires ANSI-style prototype
#include"reg52.h"
#include"lcd.h"
#include"i2c.h"
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit led=P3^7;
sbit beep=P2^0;
sbit k1=P3^1;
sbit k2=P3^0;
sbit k3=P3^2;
char res=0;
uint8 key,num;
uint8 fuhao;
uint8 flag;
long a,b,c,d,sum,sub;
uint8 k;
uint8 biao;
uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };
void delay(uint16 i)
  while(i--);
  void lcdwrc(uint8 c)
  LcdWriteCom(c);
  void lcdwrd(uint8 dat)
  LcdWriteData(dat);
  void lcd_init()
  LcdInit();
        key=0;
        num=0;
        flag=0;
        fuhao=0;
        a=0;
        b=0;
        c=0;
        d=0;
        biao=0;
        led=0;
  void keyscan()
  P1=0xfe;
        if(P1!=0xfe)
        delay(1000);
        if(P1!=0xfe)
                                key=P1&0xf0;
                                switch(key)
                {\n\t\t\t\t
                  case 0xe0: num=0;break;
                        case 0xd0: num=1;break;
                        case 0xb0: num=2;break;
                        case 0x70: num=3;break;
                        while(P1!=0xfe);
                        if(num==0||num==1||num==2)
                            if(flag==0)
                                   a=a*10+dat1[num];
                                         res =a;
                                {\n\t\t\t\t//led=1;
                                  b=b*10+dat1[num];
                                        res =b;
                        if(num==3)
                          flag=1;
                          fuhao=1;
                          lcdwrd(0x30+dat1[num]);
                          P1=0xfd;
                                if(P1!=0xfd)
                                  delay(1000);
                                        if(P1!=0xfd)
                                          key=P1&0xf0;
                                                switch(key)
                                                          case 0xe0: num=4;break;
                                                          case 0xd0: num=5;break;
                                                          case 0xb0: num=6;break;
                                                          case 0x70: num=7;break;
                                        while(P1!=0xfd);
                                        if(num==4||num==5||num==6)
                                          if(flag==0)
                                                  a=a*10+dat1[num];
                                                        res =a;\n\t\t\t
                                                b=b*10+dat1[num];
                                                res =b;
                                                flag=1;
                                                fuhao=2;
                P1=0xfb;
                if(P1!=0xfb)
          delay(1000);
                if(P1!=0xfb)
          {\n\t\t\t
                  key=P1&0xf0;
                        switch(key)
                                  case 0xe0: num=8;break;
                                        case 0xd0: num=9;break;
                                        case 0xb0: num=10;break;
                                        case 0x70: num=11;break;
                                }\t\n\t\t
                  while(P1!=0xfb);
                        if(num==8||num==9||num==10)
                  if(flag==0)
                                  a=a*10+dat1[num];
                                        res =a;
                                  b=b*10+dat1[num];
                                        res =b;
                                  flag=1;
                                        fuhao=3;
                                  lcdwrd(0x30+dat1[num]);\n\t
        P1=0xf7;
        if(P1!=0xf7)
           delay(1000);
                 if(P1!=0xf7)
                    key=P1&0xf0;
                                switch(key)
                                   case 0xe0: num=12;break;
                                         case 0xd0: num=13;break;
                                         case 0xb0: num=14;break;
                                         case 0x70: num=15;break;
                                   while(P1!=0xf7);
                                         switch(num)
                                           case 12:
                                                 if(flag==0)
                                                     a=a*10+dat1[num];
        res =a;
        lcdwrd(0x30);
                                                    b=b*10+dat1[num];
        res =b;
        lcdwrd(0x30);
                                                    break;
        case 13:
        lcdwrc(0x01);
        a=0;
        b=0;
        flag=0;
        fuhao=0;
        break;
        case 15:
        flag=1;
        fuhao=4;
        lcdwrd(0x2f);
        break;
        case 14:
        if(fuhao==1)
        lcdwrc(0x4f+0x80);
        lcdwrc(0x04);
        c=a+b;
        res =c;
        while(c!=0)
        lcdwrd(0x30+c%10);
        c=c/10;
        lcdwrd(0x3d);
        a=0;
        b=0;
        flag=0;
        fuhao=0;
        if(fuhao==2)
        lcdwrc(0x4f+0x80);
                                                          lcdwrc(0x04);
                                                          if(a>b)
        c=a-b;
        c=b-a;
                                                          res=c;
                                                while(c!=0)
                                                        lcdwrd(0x30+c%10);
                                                        c=c/10;
                                                if(a<b)        lcdwrd(0x2d);
                                                lcdwrd(0x3d);
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;
                                        if(fuhao==3)
                                                lcdwrc(0x4f+0x80);
                                                lcdwrc(0x04);
                                                c=a*b;
                                                while(c!=0)
                                                        lcdwrd(0x30+c%10);
                                                        c=c/10;
                                                lcdwrd(0x3d);
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;
                                        if(fuhao==3)
                                                lcdwrc(0x4f+0x80);
                                                lcdwrc(0x04);
                                                c=a*b;
                                                while(c!=0)
                                                        lcdwrd(0x30+c%10);
                                                        c=c/10;
                                                lcdwrd(0x3d);
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;
                                        if(fuhao==4)
                                                k=0;
                                                lcdwrc(0x4f+0x80);
                                                lcdwrc(0x04);
                                                c=(long)(((float)a/b)*1000);
                                                while(c!=0)
                                                        k++;
                                                        lcdwrd(0x30+c%10);
                                                        c=c/10;
                                                        if(k==3)
        lcdwrd(0x2e);
        k=0;
                                                if(a/b<0)
                                                        lcdwrd(0x30);
                                                lcdwrd(0x3d);
                                                a=0;
                                                b=0;
                                                flag=0;
                                                fuhao=0;
                                        break;
void keyscan2()
        keyscan();
        if(k1==0)
                delay(1000);
                if(k1==0)
                        At24c02Write(1,res);
                while(!k1);
                key=P1&0xf0;
                switch(key)
                switch(num) {
                        case 14:
                                lcdwrc(0x4f+0x80);
                                lcdwrc(0x04);
                                sum = res+res;
                                while(sum!=0)
                                        lcdwrd(0x30+sum%10);
                                        sum=sum/10;
                                lcdwrd(0x3d);
        if(k2==0)
                delay(1000);
                if(k2==0)
                        res=At24c02Read(1);
                        lcdwrc(0x4f+0x80);
                        lcdwrc(0x04);
                        while(res!=0)
                                lcdwrd(0x30+res%10);
                                res=res/10;
                while(!k2);
        if(k3==0)
                delay(100);
                if(k3==0)
                while(!k3);
                lcdwrc(0x4f+0x80);
                lcdwrc(0x04);
                sub=res-res;
                while(sub!=0)
                        lcdwrd(0x30+sub%10);
                        sub=sub/10;
                if(res<res)        lcdwrd(0x2d);
                lcdwrd(0x3d);
        lcd_init();
                keyscan();
                keyscan2();
ID:301191 發表于 2022-12-23 16:11 | 顯示全部樓層
頂一下
ID:883242 發表于 2022-12-23 16:22 | 顯示全部樓層
帖子標題的問題,實際出在第3行。
