查看: 1702|回復(fù): 2
使用中斷,蜂鳴器實(shí)現(xiàn)音樂功能,為什么我的FrepSelect的值在數(shù)組中無法改變
ID:1052714 發(fā)表于 2022-12-18 13:14 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <REGX51.H>
#include "Timer0.h"
void delay (int m);
sbit Beep=P3^6;
unsigned int code FrepTable[]={
       63628,63731,63835,63928,64021,64103,64185,64260,64331,64400,64463,64528,
           64580,64633,64684,64732,64777,64820,64860,64898,64934,64968,65000,65030,
           65058,65085,65110,65134,65157,65178,65198,65217,65235,65252,65268,65283};
unsigned char Music[]={12,12,19,19,21,21,19,17,17,16,16,14,14,12};
unsigned int FrepSelect;
  Timer0Init();
  {[url=]U[/url]
           FrepSelect++;
   delay(500);
   void Timer0_Routine() interrupt 1
   TL0=FrepTable[FrepSelect]%256;
   TH0=FrepTable[FrepSelect]/256;
   Beep=!Beep;
void delay (int m)
unsigned char i,j;
for (i=0;i<m;i++)
for (j=0;j<253;j++);
ID:384109 發(fā)表于 2022-12-18 22:20 | 只看該作者
FrepSelect沒賦初值
ID:213173 發(fā)表于 2022-12-19 07:48 | 只看該作者
延時(shí)函數(shù)使用的數(shù)據(jù)類型不當(dāng),一旦實(shí)參m大于255就導(dǎo)致永遠(yuǎn)出不了for (i=0;i<m;i++)循環(huán)。
  1. #include <REG51.H>
  2. //#include "Timer0.h"
  3. void delay (int m);
  4. sbit Beep=P3^6;
  5. unsigned int code FrepTable[]={
  6. 63628,63731,63835,63928,64021,64103,64185,64260,64331,64400,64463,64528,
  7. 64580,64633,64684,64732,64777,64820,64860,64898,64934,64968,65000,65030,
  8. 65058,65085,65110,65134,65157,65178,65198,65217,65235,65252,65268,65283};
  9. unsigned char Music[]={12,12,19,19,21,21,19,17,17,16,16,14,14,12};
  10. unsigned int FrepSelect;
  11. void Timer0Init(void)
  12. {
  13.     TMOD = 0x01;
  14.     TH0 = 0;
  15.     TL0 = 0;
  16.     EA = 1;
  17.     ET0 = 1;
  18.     TR0 = 1;
  19. }
  20. void main()
  21. {
  22.         Timer0Init();
  23.         while(1)
  24.         {//[url=]U[/url]
  25.                 FrepSelect++;
  26.                 delay(500);
  27.         }
  28. }
  29. void Timer0_Routine() interrupt 1
  30. {
  31.         TL0=FrepTable[FrepSelect]%256;
  32.         TH0=FrepTable[FrepSelect]/256;
  33.         Beep=~Beep;
  34. }
  35. void delay (int m)
  36. {
  37.         int i,j;
  38.         for (i=0;i<m;i++)
  39.                 for (j=0;j<253;j++);
  40. }
