查看: 1746|回復: 1
Proteus畫PCB出錯Connectors have been pre-annotated as J1,J2,J3 and J4 so you ...
ID:894800 發表于 2022-12-3 21:51 | 顯示全部樓層 |閱讀模式
Connectors have been pre-annotated as J1,J2,J3 and J4 so you must manually annotate the corresponding connectors in the schematic.接頭已預先標注為J1、J2、J3和J4,因此必須手動標注原理圖中的相應接頭。
請問這個問題應該如何解決呢?
ID:301191 發表于 2022-12-6 06:09 | 顯示全部樓層
頂一下
