查看: 1619|回復: 1
51單片機按鍵控制數碼管程序問題
ID:1055060 發表于 2022-12-1 17:01 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機普中開發版 這個是按鍵p3_0控制數碼管左邊顯示20-50右邊00-50同時顯示,怎么樣再加一個按鍵p3_1控制左邊的數碼管顯示20-50讓他們分開顯示
#include <REGX52.H>
#include "Delay.h"
unsigned char NixieTable[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F, 0x00};
void Nixie(unsigned char Location,Number)
        switch(Location)
                case 1:P2_4=1;P2_3=1;P2_2=1;break;
                 case 2:P2_4=1;P2_3=1;P2_2=0;break;
                 case 3:P2_4=1;P2_3=0;P2_2=1;break;
                 case 4:P2_4=1;P2_3=0;P2_2=0;break;
                 case 5:P2_4=0;P2_3=1;P2_2=1;break;
                 case 6:P2_4=0;P2_3=1;P2_2=0;break;
                 case 7:P2_4=0;P2_3=0;P2_2=1;break;
                 case 8:P2_4=0;P2_3=0;P2_2=0;break;
        P0=NixieTable[Number];
void Timer0Init(void)                //1毫秒@11.0592MHz
        TMOD &= 0xF0;                //設置定時器模式
        TMOD |= 0x01;                //設置定時器模式
        TL0 = 0x66;                //設置定時初值
        TH0 = 0xFC;                //設置定時初值
        TF0 = 0;                //清除TF0標志
        TR0 = 1;                //定時器0開始計時
        ET0=1;
        EA=1;
        PT0=0;
unsigned char num=0,ber=20;
        while(1){        if(P3_0==0)break;        }
        Timer0Init();
                Nixie(5, num/1000);
                 Delay(1);
                 Nixie(5, 10);
                Nixie(6, num/100);
                 Delay(1);
                 Nixie(6, 10);
                 Nixie(7, num/10);
                 Delay(1);
                 Nixie(7, 10);
                 Nixie(8, num%10);
                 Delay(1);
                 Nixie(8, 10);
                 break;
                Nixie(1,ber/1000);
                 Delay(1);
                 Nixie(1, 10);
                Nixie(2, ber/100);
                 Delay(1);
                 Nixie(2, 10);
                 Nixie(3, ber/10);
                 Delay(1);
                 Nixie(3, 10);
                 Nixie(4, ber%10);
                 Delay(1);
                 Nixie(4, 10);
unsigned char KeyNum;
void Timer0_Routine() interrupt 1
        static unsigned int T0Count        ;
        T0Count++;
    if(T0Count>=100)
    {           T0Count=0;
                if(num<50)
                {                num ++;        }
                 {                 num=0; }
                 if(ber<50)
                {                ber ++;        }
                 {                 ber=20; }
ID:213173 發表于 2022-12-2 12:20 | 只看該作者
  1. #include <REGX52.H>
  2. //#include "Delay.h"
  3. unsigned char NixieTable[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F, 0x00};
  4. unsigned char data dis_buf[8];
  5. unsigned char num,ber;
  6. void Nixie()
  7. {
  8.         static unsigned char i;
  9.         switch(i)
  10.         {
  11.                 case 0:dis_buf[i]=NixieTable[10];break;
  12.                 case 1:dis_buf[i]=NixieTable[ber/10%10];break;
  13.                 case 2:dis_buf[i]=NixieTable[ber%10];break;
  14.                 case 3:dis_buf[i]=NixieTable[10];break;
  15.                 case 4:dis_buf[i]=NixieTable[10];break;
  16.                 case 5:dis_buf[i]=NixieTable[num/10%10];break;
  17.                 case 6:dis_buf[i]=NixieTable[num%10];break;
  18.                 case 7:dis_buf[i]=NixieTable[10];break;
  19.         }
  20.         P0=0x00;
  21.         P2&=0xe3;
  22.         P2|=i*4;
  23.         P0=dis_buf[i];
  24.         i=++i%8;
  25. }
  26. void Timer0Init(void)                //1毫秒@11.0592MHz
  27. {
  28.         TMOD &= 0xF0;                //設置定時器模式
  29.         TMOD |= 0x01;                //設置定時器模式
  30.         TL0 = 0x66;                //設置定時初值
  31.         TH0 = 0xFC;                //設置定時初值
  32.         TF0 = 0;                //清除TF0標志
  33.         TR0 = 1;                //定時器0開始計時
  34. //        ET0=1;
  35. //        EA=1;
  36. }
  37. unsigned char num=0,ber=20,Count=0;
  38. bit sign;
  39. void main()
  40. {
  41.         Timer0Init();
  42.         while(1)
  43.         {
  44.                 if(TF0)
  45.                 {
  46.                         TF0 = 0;
  47.                         TL0 = 0x66;                //設置定時初值
  48.                         TH0 = 0xFC;                //設置定時初值
  49.                         if(!P3_0||!P3_1)
  50.                         {
  51.                                 if(++Count>=10 && sign==0)
  52.                                 {
  53.                                         sign=1;
  54.                                         if(!P3_0)
  55.                                         {
  56.                                                 if(ber<50)ber ++;
  57.                                                 else        ber=20;
  58.                                         }
  59.                                         if(!P3_1)
  60.                                         {
  61.                                                 if(num<50) num ++;
  62.                                                 else num=0;
  63.                                         }
  64.                                 }
  65.                         }
  66.                         else
  67.                         {
  68.                                 Count=0;
  69.                                 sign=0;
  70.                         }
  71.                         Nixie();
  72.                 }
  73.         }
  74. }
