#include <reg52.h>
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
typedef unsigned char uchar;
typedef unsigned int uint;
unsigned int i;
unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char x;
unsigned int aj=0;
uchar time;
void delay(int a)
for(;a>0;a--)
for(i=0;i<62;i++);
void UsartInit()
TMOD = 0x20;
PCON = 0x00;
SCON = 0X50; //Method 1, ALLOW REN
TH1 = 0xFD;
TL1 = 0xFD;
REN = 1;
EA = 1;
ES = 1;
TR1 = 1;
void Show_Init()
key1=1;
key2=1;
key3=1;
key4=1;
key5=1;
key6=1;
void send(unsigned char cc)
SBUF = cc;
while(TI==0);
TI = 0;
void key()
{ if(!aj)
if(!key1)
delay(1);
if(!key1)
send('1');
aj=1;
x=1;
else if(!key2)
delay(1);
if(!key2)
send('2');
aj=1;
x=2;
else if(!key3)
delay(1);
if(!key3)
send('3');
aj=1;
x=3;
else if(!key4)
delay(1);
if(!key4)
send('4');
aj=1;
x=4;
else if(!key5)
delay(1);
if(!key5)
send('5');
aj=1;
x=5;
else if(!key6)
delay(1);
if(!key6)
send('6');
aj=1;
x=6;
if(key1==1 && key2==1 && key3==1 && key4==1 && key5==1 & key6==1)
aj=0;
Show_Init();
UsartInit();
P2=0xFD;
P0=tab[(int)time/0x10];delay(2);
P2=0xFB;
P0=tab[(int)time%0x10];delay(2);
P2=0xFE;
P0=tab[x];delay(2);
key();
void usart() interrupt 4
if(RI) //接收到數(shù)據(jù)進(jìn)入if
RI=0; //重置串口接收狀態(tài)
time = SBUF ; //time放到緩存區(qū)發(fā)送
