查看: 1846|回復: 2
單片機+74HC595 16*16點陣程序求大佬指點迷津
如圖仿u2u3兩個595進行點陣掃描,U4U5進行字模顯示一直都是亂碼
單片機程序如下:
#include <REG52.H>
sbit ds0=        P3^0;
sbit sh0=        P3^1;
sbit st=        P3^2;
sbit ds2=        P3^3;
sbit sh2=        P3^4;
unsigned  char code unmber[]={
0xFF,0xFF,0xFF,0xFF,0xE8,0x7B,0xED,0x7D,0xDB,0x61,0xC3,0x1F,0xFF,0x7F,0xFF,0x03,
0x80,0xFD,0xFB,0x3B,0xF6,0xC7,0xEE,0xF7,0xEE,0xF9,0xFE,0xFD,0xFF,0xFD,0xFF,0xFF,/*"張",0*/
void hc595(unsigned char x)
        sh2=0;
        ds2=x&0x01;
        x=x<<1;
        sh2=1;
void dianzhen()
        unsigned char j,k,i;
                for(j=0;j<16;j++)
                        ds0=j;
                        sh0=0;
                        sh0=1;
                                hc595(unmber[(2*j+1)]);
                                hc595(unmber[(2*j+0)]);
                        st=0;
                        st=1;
                dianzhen();
仿真圖
仿真圖
ID:332444 發表于 2022-11-22 16:32 | 只看該作者
看我帖子有595驅動荔枝8*8與16*16沒多大區別不過是送數據的次數不同而已
ID:1050622 發表于 2022-11-22 18:00 | 只看該作者
xianfajushi 發表于 2022-11-22 16:32
好的 感謝大佬
