查看: 1781|回復: 3
單片機+protues數碼管仿真,最后一位不顯示,幫忙分析一下
#include <regx51.h>
#include "intrins.h"
unsigned char NixieTable[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
void Delay1ms(unsigned int xms)                //@12.000MHz
        unsigned char i, j;
        while(xms--)
        i = 2;
        j = 239;
        do
                while (--j);
        } while (--i);
void Nixie(unsigned char location,unsigned char number)
                switch(location)
                case 1:P2_0 = 1; P2_1 = 0; P2_2 = 0; P2_3 = 0; break;
                case 2:P2_0 = 0; P2_1 = 1; P2_2 = 0; P2_3 = 0; break;
                case 3:P2_0 = 0; P2_1 = 0; P2_2 = 1; P2_3 = 0; break;
                case 4:P2_0 = 0; P2_1 = 0; P2_2 = 0; P2_3 = 1; break;
        P0 = NixieTable[number];
        Delay1ms(10);
                Nixie(1,1);
                Nixie(2,2);
                Nixie(3,3);
                Nixie(4,4);
屏幕截圖 2022-11-15 192501.png (144.18 KB, 下載次數: 79)
ID:161164 發表于 2022-11-16 09:30 | 只看該作者
加消影
ID:121859 發表于 2022-11-16 09:26 | 只看該作者
加個消隱處理就可以了,沒多復雜。
ID:213173 發表于 2022-11-15 21:42 | 只看該作者
  1. #include <reg51.h>
  2. #include "intrins.h"
  3. unsigned char NixieTable[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
  4. unsigned char num;
  5. void Delay1ms(unsigned int xms)                //@12.000MHz
  6. {
  7.         unsigned char i, j;
  8.         while(xms--)
  9.         {
  10.                 i = 2;
  11.                 j = 239;
  12.                 do
  13.                 {
  14.                         while (--j);
  15.                 } while (--i);
  16.         }
  17. }
  18. void Nixie()
  19. {
  20.         P2&=0xf0;
  21.         P0 = NixieTable[num+1];
  22.         P2|=0x01<<num;
  23.         num=++num%4;
  24. }
  25. void main()
  26. {
  27.         while(1)
  28.         {
  29.                 Nixie();
  30.                 Delay1ms(1);
  31.         }
  32. }
