查看: 1169|回復: 1
51單片機控制32個發光二極管,至少三種花樣程序怎么寫阿?
ID:1048723 發表于 2022-10-22 14:29 | 顯示全部樓層 |閱讀模式
at89c51控制32個發光二極管,至少三種花樣程序怎么寫阿?大佬們!!!
ID:1048764 發表于 2022-10-22 20:32 | 顯示全部樓層
#include <REG52.H>
#define        uint        unsigned int
#define        uchar        unsigned char
uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//LED從低位往高位移
uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//LED從高位往低位移
uchar code table2[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};//LED從1個亮到8個都點亮(從低位往高位)
uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//LED從1個亮到8個都點亮(從高位往低位)
uchar code table4[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//LED從8個全亮到一個都不亮(從低位往高位)
uchar code table5[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//LED從8個全亮到一個都不亮(從高位往低位)
uchar code table6[]={0xfe,0xfc,0xfa,0xf6,0xee,0xde,0xbe,0x7e};//LED從低位往高位移(最低位始終為0)
uchar code table7[]={0x7f,0x3f,0x5f,0x6f,0x77,0x7b,0x7d,0x7e};//LED從高位往低位移(最高位始終為0)
uchar i,j;                //定義循環變量
uint tt=70;                //定義時間指數
void delay(uint time)        //延時函數
        uint x,y;
        for(x=time;x>0;x--)
        for(y=100;y>0;y--);
void disp0()                        //狀態0 所有LED閃爍3次
        for(i=0;i<1;i++)
                P0=0x00; P2=0x00; P3=0x00; P1=0x00;
                delay(12000);
                P0=0xff; P2=0xff; P3=0xff; P1=0xff;
                delay(300);
void disp7()                        //狀態7 LED自下而上逐漸點亮(直到全部點亮)再依次全滅
        for(i=0;i<8;i++)
                P1=table3[i];
                P3=table2[i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table2[i];
                P2=table2[i];
                delay(100);
        delay(3800);
        for(i=0;i<8;i++)
                P1=table5[i];
                P3=table4[i];
                delay(100);
        P1=0xff;P3=0xff;
        delay(100);
        for(i=0;i<8;i++)
                P0=table4[i];
                P2=table4[i];
                delay(100);
        P0=0xff;P1=0xff;P2=0xff;P3=0xff;
        delay(100);
void disp9()                        //狀態9 間斷8格的4個LED亮,然后逆時針逐漸點亮(直到全部點亮)
        for(i=0;i<8;i++)
                P0=table3[i];
                P2=table2[i];
                P1=table2[i];
                P3=table2[i];
                delay(100);
        delay(100);
void disp10()                        //狀態10 從LED全部亮到全不亮(間斷8格的4個LED開始逆時針熄滅)
        for(i=0;i<9;i++)
                P0=table5[i];
                P2=table4[i];
                P1=table4[i];
                P3=table4[i];
                delay(100);
        delay(300);
void disp12()                        //間斷8格的4個LED亮,然后順時針逐漸點亮(直到全部點亮)
        for(i=0;i<8;i++)
                P0=table2[i];
                P2=table3[i];
                P1=table3[i];
                P3=table3[i];
                delay(100);
        delay(5100);
void disp13()                        //狀態13 從LED全部亮到全不亮(間斷8格的4個LED開始順時針熄滅)
        for(i=0;i<9;i++)
                P0=table4[i];
                P2=table5[i];
                P1=table5[i];
                P3=table5[i];
                delay(100);
        delay(300);
void disp14()                        //狀態14 從LED不亮到全亮(從P0.0、P1.0、P2.0、P3.7開始逐步點亮)
        for(i=0;i<8;i++)
                P0=table2[i];
                P1=table2[i];
                P2=table2[i];
                P3=table3[i];
                delay(100);
        delay(4700);
void disp15()                        //狀態15 從LED全亮到全不亮(從P0.7、P1.7、P2.7、P3.0開始逐步熄滅)
        for(i=0;i<9;i++)
                P0=table5[i];
                P1=table5[i];
                P2=table5[i];
                P3=table4[i];
                delay(100);
        delay(300);
void disp17()                        //狀態17 LED從P0.7開始逆時針逐步點亮,(循環2次)并且速度會逐步提高
        for(i=0;i<8;i++)
                P0=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table2[i];
                delay(100);
        for(i=0;i<8;i++)
                P3=table2[i];
                delay(100);
        for(i=0;i<8;i++)
                P2=table2[i];
                delay(100);
        delay(2600);
        for(i=0;i<8;i++)
                P0=table5[i];
                delay(100);
        P0=0xff;
        delay(100);
        for(i=0;i<8;i++)
                P1=table4[i];
                delay(100);
        P1=0xff;
        delay(100);
        for(i=0;i<8;i++)
                P3=table4[i];
                delay(100);
        P3=0xff;
        delay(100);
        for(i=0;i<8;i++)
                P2=table4[i];
                delay(100);
        P2=0xff;
        delay(100);
        for(i=0;i<8;i++)
                P0=table3[i];
                delay(50);
        for(i=0;i<8;i++)
                P1=table2[i];
                delay(50);
        for(i=0;i<8;i++)
                P3=table2[i];
                delay(50);
        for(i=0;i<8;i++)
                P2=table2[i];
                delay(50);
        delay(4300);
        for(i=0;i<8;i++)
                P0=table5[i];
                delay(50);
        P0=0xff;
        delay(50);
        for(i=0;i<8;i++)
                P1=table4[i];
                delay(50);
        P1=0xff;
        delay(50);
        for(i=0;i<8;i++)
                P3=table4[i];
                delay(50);
        P3=0xff;
        delay(50);
        for(i=0;i<8;i++)
                P2=table4[i];
                delay(50);
        P2=0xff;
        delay(50);
void disp18()                        //狀態18 LED從P0.7開始逆時針逐步點亮(每亮8位后就熄滅)
        for(i=0;i<8;i++)
                P0=table3[i];
                delay(90);
        P0=0xff;
        for(i=0;i<8;i++)
                P1=table2[i];
                delay(90);
        P1=0xff;
        for(i=0;i<8;i++)
                P3=table2[i];
                delay(90);
        P3=0xff;
        for(i=0;i<8;i++)
                P2=table2[i];
                delay(90);
        P2=0xff;
void disp19()                        //狀態19 LED從P2.7開始順時針逐步點亮,(循環2次)并且速度會逐步提高
        for(i=0;i<8;i++)
                P2=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P3=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table2[i];
                delay(100);
        delay(3300);
        P0=0xff; P1=0xff; P3=0xff; P2=0xff;
        delay(200);
        for(i=0;i<8;i++)
                P2=table3[i];
                delay(50);
        for(i=0;i<8;i++)
                P3=table3[i];
                delay(50);
        for(i=0;i<8;i++)
                P1=table3[i];
                delay(50);
        for(i=0;i<8;i++)
                P0=table2[i];
                delay(50);
        delay(4850);
        delay(200);
void disp20()                        //狀態20 LED從P2.7開始順時針逐步點亮(每亮8位后就熄滅)
        for(i=0;i<8;i++)
                P2=table3[i];
                delay(90);
        P2=0xff;
        for(i=0;i<8;i++)
                P3=table3[i];
                delay(90);
        P3=0xff;
        for(i=0;i<8;i++)
                P1=table3[i];
                delay(90);
        P1=0xff;
        for(i=0;i<8;i++)
                P0=table2[i];
                delay(90);
        P0=0xff;
void disp22()                        //裝態22 2個LED自上而下移動(循環4次,且頻率漸快,到最快時持續循環12次,然后循環4次頻率再逐漸降低)
        for(j=0;j<4;j++)
                for(i=0;i<8;i++)
                        P0=table1[i];
                        P2=table1[i];
                        delay(tt);
                P0=0xff; P2=0xff;
                for(i=0;i<8;i++)
                        P1=table0[i];
                        P3=table1[i];
                        delay(tt);
                P1=0xff; P3=0xff;
                tt=tt-10;
        for(j=0;j<12;j++)
                for(i=0;i<8;i++)
                        P0=table1[i];
                        P2=table1[i];
                        delay(20);
                P0=0xff; P2=0xff;
                for(i=0;i<8;i++)
                        P1=table0[i];
                        P3=table1[i];
                        delay(20);
                P1=0xff; P3=0xff;
        tt=20;
        for(j=0;j<4;j++)
                for(i=0;i<8;i++)
                        P0=table1[i];
                        P2=table1[i];
                        delay(tt);
                P0=0xff; P2=0xff;
                for(i=0;i<8;i++)
                        P1=table0[i];
                        P3=table1[i];
                        delay(tt);
                P1=0xff; P3=0xff;
                tt=tt+10;
        tt=70;
void disp24()                        //狀態24 LED左右交替閃爍
        P1=0xff; P3=0xff; P0=0xff; P2=0xff;
        for(i=0;i<2;i++)
                P0=0x00; P1=0x00;
                delay(1000);
                P0=0xff; P1=0xff;
                P2=0x00; P3=0x00;
                delay(1000);
                P2=0xff; P3=0xff;
void disp25()                        //狀態25 LED交替閃爍
        for(i=0;i<2;i++)
                P0=0xaa; P1=0xaa; P2=0xaa; P3=0xaa;
                delay(1000);
                P0=~P0; P1=~P1; P2=~P2; P3=~P3;
                delay(1000);
        delay(200);
void disp26()                        //狀態26 2個LED開始上下移動半圈(LED不亮流水)
        P0=0x00;P1=0x00;P2=0x00;P3=0x00;
        for(i=0;i<8;i++)
                P0=~table1[i];
                P2=~table1[i];
                delay(200);
        P0=0x00; P2=0x00;
        for(i=0;i<8;i++)
                P1=~table0[i];
                P3=~table1[i];
                delay(200);
        for(i=0;i<8;i++)
                P1=~table1[i];
                P3=~table0[i];
                delay(200);
        P1=0x00; P3=0x00;
        for(i=0;i<8;i++)
                P0=~table0[i];
                P2=~table0[i];
                delay(200);
        delay(200);
void disp28()                        //狀態28 P1、P2和P0、P3交替閃爍
        for(i=0;i<2;i++)
                P1=0x00; P2=0x00; P0=0xff; P3=0xff;
                delay(1000);
                P1=0xff; P2=0xff; P0=0x00; P3=0x00;
                delay(1000);
        P1=0xff; P2=0xff; P0=0xff; P3=0xff;
void disp29()                        //狀態29 逐步順時針點亮P2、P1的LED,再順時熄滅后,再順時針點亮P0、P3的LED,再順時熄滅
        P0=0xff; P1=0xff; P2=0xff; P3=0xff;
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table3[i];
                        P1=table3[i];
                        delay(100);
                for(i=0;i<9;i++)
                        P2=table5[i];
                        P1=table5[i];
                        delay(100);
                for(i=0;i<8;i++)
                        P0=table2[i];
                        P3=table3[i];
                        delay(100);
                for(i=0;i<9;i++)
                        P0=table4[i];
                        P3=table5[i];
                        delay(100);
        delay(200);
void disp31()                        //狀態31 逐步逆時針點亮P2、P1的LED,再逆時熄滅后,再逆時針點亮P0、P3的LED,再逆時熄滅
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table2[i];
                        P1=table2[i];
                        delay(100);
                for(i=0;i<9;i++)
                        P2=table4[i];
                        P1=table4[i];
                        delay(100);
                for(i=0;i<8;i++)
                        P0=table3[i];
                        P3=table2[i];
                        delay(100);
                for(i=0;i<9;i++)
                        P0=table5[i];
                        P3=table4[i];
                        delay(100);
        delay(200);
void disp32()                        //狀態32 LED自上而下逐步點亮,然后從下往上逐步熄滅
        for(i=0;i<8;i++)
                P0=table3[i];
                P2=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table2[i];
                P3=table3[i];
                delay(100);
        for(i=0;i<9;i++)
                P1=table5[i];
                P3=table4[i];
                delay(100);
        for(i=0;i<9;i++)
                P0=table4[i];
                P2=table4[i];
                delay(100);
void disp33()                        //狀態33 LED從左往右開始點亮(直到全亮),然后從左右兩邊開始熄滅(直到全部熄滅)
        for(i=0;i<8;i++)
                P0=table2[i];
                P1=table2[i];
                delay(100);
        for(i=0;i<8;i++)
                P2=table3[i];
                P3=table2[i];
                delay(100);
        delay(500);
        for(i=0;i<9;i++)
                P2=table4[i];
                P3=table5[i];
                P1=table4[i];
                P0=table4[i];
                delay(100);
        delay(300);
void disp34()                        //狀態34 LED從左往右開始點亮(直到全亮),然后從中間往左右邊熄滅
        for(i=0;i<8;i++)
                P2=table2[i];
                P3=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table3[i];
                P1=table3[i];
                delay(100);
        delay(500);
        for(i=0;i<9;i++)
                P2=table5[i];
                P3=table4[i];
                P1=table5[i];
                P0=table5[i];
                delay(100);
        delay(300);
void disp35()                        //狀態35  從P2.7、P1.7開始同時順時針旋轉,直到LED全亮
        for(i=0;i<8;i++)
                P2=table3[i];
                P1=table3[i];
                delay(100);
        for(i=0;i<8;i++)
                P3=table3[i];
                P0=table2[i];
                delay(100);
void disp36()                        //狀態36  從P0.7、P3.1開始同時逆時針旋轉,直到LED全亮
        for(i=0;i<8;i++)
                P0=table3[i];
                P3=table2[i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table2[i];
                P2=table2[i];
                delay(100);
void disp39()                        //狀態39 P1、P3LED(下半部分)一直亮,上半部分LED向外擴張亮,然后閃爍3次
        P1=0x00; P3=0x00;
        for(i=0;i<8;i++)
                P0=table3[i];
                P2=table3[i];
                delay(150);
        for(i=0;i<8;i++)
                P0=table3[i];
                P2=table3[i];
                delay(300);
        for(i=0;i<4;i++)
                P0=~P0; P2=~P2;
                delay(300);
        delay(1000);
        delay(100);
void disp41()                        //狀態41 LED從P2.7、P1.7開始順時針同時熄滅,直到全部熄滅
        for(i=0;i<9;i++)
                P2=table5[i];
                P1=table5[i];
                delay(100);
        for(i=1;i<9;i++)
                P0=table4[i];
                P3=table5[i];
                delay(100);
        delay(300);
                disp22();                //狀態22 2個LED自上而下移動(循環5次,且頻率漸快,到最快時持續循環16次,然后循環5次頻率再逐漸降低 ******
                disp9();                //狀態9 間斷8格的4個LED亮,然后逆時針逐漸點亮(直到全部點亮)********        1
                disp10();                //狀態10 從LED全部亮到全不亮(間斷8格的4個LED開始逆時針熄滅)********         2
                disp7();                //狀態7 LED自下而上逐漸點亮(直到全部點亮)再依次全滅********* 和19對稱
                disp14();                //狀態14 從LED不亮到全亮(從P0.0、P1.0、P2.0、P3.7開始逐布點亮) ********1
                disp15();                //狀態15 從LED全亮到全不亮(從P0.7、P1.7、P2.7、P3.0開始逐步熄滅)*********2
                disp17();                //狀態17 LED從P0.7開始逆時針逐步點亮,并且速度會逐步提高         ************
                disp18();                //狀態18 LED從P0.7開始逆時針逐步點亮(每亮8位后就熄滅) **
                disp20();                //狀態20 LED從P2.7開始順時針逐步點亮(每亮8位后就熄滅)**
                disp39();                //狀態39 P1、P3LED(下半部分)一直亮,上半部分LED向外擴張亮,然后閃爍3次    **
                disp24();                //狀態24 LED左右交替閃爍         **
                disp25();                //狀態25 LED交替閃爍                   **
                disp12();                //間斷8格的4個LED亮,然后順時針逐漸點亮(直到全部點亮)*********         1
                disp13();                //狀態13 從LED全部亮到全不亮(間斷8格的4個LED開始順時針熄滅)********        2
                disp26();                //狀態26 2個LED開始上下移動半圈(LED不亮流水)         *****
                disp19();                //狀態19 LED從P2.7開始順時針逐步點亮,(循環2次)并且速度會逐步提高******** 和7對稱
                disp28();                //狀態28 P1、P2和P0、P3交替閃爍           **
                disp29();                //狀態29 逐步順時針點亮P2、P1的LED,再順時熄滅后,再順時針點亮P0、P3的LED,再順時熄滅        **** 和31對稱
                disp31();                //狀態31 逐步逆時針點亮P2、P1的LED,再逆時熄滅后,再逆時針點亮P0、P3的LED,再逆時熄滅        **** 和29對稱
                disp32();                //狀態32 LED自上而下逐步點亮,然后從下往上逐步熄滅         *****
                disp33();                //狀態33 LED從左往右開始點亮(直到全亮),然后從左右兩邊開始熄滅(直到全部熄滅) *****
                disp36();                //狀態36  從P0.7、P3.0開始同時逆時針旋轉,直到LED全亮*****
                disp35();                //狀態35  從P2.7、P1.7開始同時順時針旋轉,直到LED全亮        *****
                disp41();                //狀態41 LED從P2.7、P1.7開始順時針同時熄滅,直到全部熄滅  *****
                disp34();                //狀態34 LED從左往右開始點亮(直到全亮),然后從中間往左右邊熄滅 *****
                disp0();                //狀態0 所有LED閃爍3次 *******
//這個你可以參考下!!
