查看: 2078|回復: 8
單片機程序只執行到一半,往下就不運行了是什么回事?
我程序只運行到了這里, if(k3==1)                                  {
                   LED[0]=a%10;  //顯示計數
                                                LED[1]=a/10%10;
                                                LED[2]=a/100%10;
                                                LED[3]=a/1000;
后面的就不顯示了,啥回事?
全程序如下:
  1. /*
  2. MCLKO/NRST/SCL_2/MOSI/RxD_3/T1CLKO/T0/INT2/P5.4
  3. Vcc
  4. SDA_2/SS/TxD_3/T0CLKO/T1/INT3/P5.5
  5. Gnd
  6. P3.3/TxD_2/INT1/MISO/SDA
  7. P3.2/RxD_2/INT0/SCLK/SCL
  8. P3.1/TxD
  9. P3.0/RxD/INT4
  10. */
  11. #include "8g.h"
  12. #include "intrins.h"
  13. #define uchar unsigned char
  14. #define uint  unsigned int
  15. #define EX3             0x20
  16. void LED4_Display (void);                        // LED顯示
  17. void LED_OUT(uchar X);                                // LED單字節串行移位函數
  18. unsigned char code LED_0F[];                // LED字模表
  19. unsigned char code fseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  20. unsigned char code segbit[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
  21. unsigned char  disbuf[4]={0,0,0,0};
  22. sbit DIO = P3^2;                                //串行數據輸入
  23. sbit RCLK  = P3^3;                                //時鐘脈沖信號——上升沿有效
  24. sbit SCLK = P5^4;                                //打入信號————上升沿有效
  25. sbit IN3=P5^5;  //對射光藕
  26. sbit k31=P3^1;
  27. //sbit IN3=P1^2;
  28. //sbit IN4=P1^3;
  29. //sbit LED=P2^0;
  30. /******************************************************************************************
  31. 使用數組對數碼管預先定義
  32. /*****************************************************************************************/
  33. unsigned int motor1=0;         //計左電機碼盤脈沖值
  34. unsigned int speed1=0;         //計左電機碼盤脈沖值
  35. unsigned int k=0,a=0,k2;
  36. unsigned char k3=2;
  37. uchar LED[8];        //用于LED的8位顯示緩存
  38. void LED4_Display (void)
  39. {
  40.         unsigned char code *led_table;          // 查表指針
  41.         uchar i;
  42.         //顯示第1位
  43.         led_table = LED_0F + LED[0];
  44.         i = *led_table;
  45.         LED_OUT(i);
  46.         LED_OUT(0x01);
  47.         RCLK = 0;
  48.         RCLK = 1;
  49.         //顯示第2位
  50.         led_table = LED_0F + LED[1];
  51.         i = *led_table;
  52.         LED_OUT(i);
  53.         LED_OUT(0x02);
  54.         RCLK = 0;
  55.         RCLK = 1;
  56.         //顯示第3位
  57.         led_table = LED_0F + LED[2];
  58.         i = *led_table;
  59.         LED_OUT(i);
  60.         LED_OUT(0x04);
  61.         RCLK = 0;
  62.         RCLK = 1;
  63.         //顯示第4位
  64.         led_table = LED_0F + LED[3];
  65.         i = *led_table;
  66.         LED_OUT(i);
  67.         LED_OUT(0x08);
  68.         RCLK = 0;
  69.         RCLK = 1;
  70. }
  71. void LED_OUT(uchar X)
  72. {
  73.         uchar i;
  74.         for(i=8;i>=1;i--)
  75.         {
  76.                 if (X&0x80) DIO=1; else DIO=0;
  77.                 X<<=1;
  78.                 SCLK = 0;
  79.                 SCLK = 1;
  80.         }
  81. }
  82. unsigned char code LED_0F[] =
  83. {// 0         1          2           3        4         5          6           7        8         9          A           b        C    d          E    F    -
  84.         0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x8C,0xBF,0xC6,0xA1,0x86,0xFF,0xbf
  85. };
  86. //
  87. /*********************************************************************************************
  88. 外部中斷
  89. /********************************************************************************************/
  90. void INT_init (void)
  91. {
  92.                 INTCLKO |= EX3;                             //使能INT3下降沿中斷
  93.   EA = 1;                        //中斷總開關
  94. }
  95. /********************************************************************************************
  96. 定時器0初始化
  97. /********************************************************************************************/
  98. void T0_init (void)
  99. {
  100.                 AUXR |= 0x80;                //定時器時鐘1T模式
  101.         TMOD &= 0xF0;                //設置定時器模式
  102.         TL0 = 0;                //設置定時初始值
  103.         TH0 = 0;                //設置定時初始值計數初值
  104.         TR0 = 1;      //啟動定時器
  105.    ET0 = 1;    //使能定時器中斷
  106. }
  107. /********************************************************************************************
  108. //延遲函數
  109. /********************************************************************************************/
  110. void DELAY_MS (unsigned int a)
  111. {
  112.         unsigned int i;
  113.         while( a-- != 0)
  114.         {
  115.                 for(i = 0; i < 600; i++);
  116.         }
  117. }
  118. /*********************************************************************************************
  119. 主程序
  120. /********************************************************************************************/
  121. void main(void)
  122. {
  123.           P1M0 = 0x00;
  124.     P1M1 = 0x00;
  125.     P3M0 = 0x00;
  126.     P3M1 = 0x00;
  127.     P5M0 = 0x00;
  128.     P5M1 = 0x00;
  129.                 INT_init();
  130.                 T0_init();
  131.           IN3=1;//光藕初始化
  132.           k3=1;  //按鍵默認顯示速度
  133.         while (1)
  134.         {
  135.                 if(k31==0&&k3==1)
  136.                         {
  137.                                 DELAY_MS (10);
  138.                                         if(k31==0&&k3==1)
  139.                                         {
  140.                                                 k3=2;//顯示速度
  141.                                         }
  142.                         }
  143.                 if(k31==0&&k3==2)
  144.                         {
  145.                                 DELAY_MS (10);
  146.                                         if(k31==0&&k3==2)
  147.                                         {
  148.                                                 k3=1;//顯示計數
  149.                                         }
  150.                                 }
  151.                  if(a>9999)
  152.                  {a=0;}
  153.          LED4_Display ();
  154.         }
  155. }
  156. /*********************************************************************************************
  157. 外部中斷INT3計算電機1的脈沖
  158. /********************************************************************************************/
  159. void INT3_Isr() interrupt 11
  160. {
  161.         motor1++;
  162.         a++;
  163. }
  164. /*********************************************************************************************
  165. 外部中斷INT1計算電機2的脈沖
  166. /********************************************************************************************/
  167. void TM0_Isr() interrupt 1
  168. {
  169.         TH0=(65536-1000)/256;        //16位計數寄存器T0高8位, 12MHZ時1000微秒
  170.         TL0=(65536-1000)%256;        //16位計數寄存器T0低8位,
  171.         k++;                        //k自加1
  172.         if(k==1000)
  173.         {
  174.                 k=k2;
  175.                 k=0;                        //重新定義k的值
  176.                 speed1=motor1*60; // 轉/min
  177.                 motor1=0;                 //重新定義motor1的值
  178.         }
  179.          if(k3==1)
  180.                                  {
  181.
  182.                    LED[0]=a%10;  //顯示計數
  183.                                                 LED[1]=a/10%10;
  184.                                                 LED[2]=a/100%10;
  185.                                                 LED[3]=a/1000;
  186.                                  }
  187.                                  if(k3==2)
  188.                                  {
  189.                   LED[3]=speed1/10;//顯示速度
  190.                                                 LED[2]=speed1%10;
  191.                                                 LED[1]=5;
  192.                                                 LED[0]=8;
  193.                                  }
  194.
  195.
  196. }
ID:523803 發表于 2022-10-20 00:41 | 只看該作者
你的K31是按鈕吧,如果是按鈕的話,你有沒有按呢,如果按了的話可能是切換的太快了
if(k31==0&&k3==1)
                                DELAY_MS (10);
                                        if(k31==0&&k3==1)
                                                k3=2;//顯示速度
                if(k31==0&&k3==2)
                                DELAY_MS (10);
                                        if(k31==0&&k3==2)
                                                k3=1;//顯示計數
這里k31按下條件成立K3=2,這個時候下面的判斷也成立了,就會反復執行
ID:198189 發表于 2022-10-20 10:02 | 只看該作者
18520649817 發表于 2022-10-20 00:41
if(k31==0&&k3==1)
k31我還沒啟用,我直接讓k3=2來調試,發現if(k3=2)這語句執行不起來。
ID:8222 發表于 2022-10-20 11:05 | 只看該作者
你語言描述都不清楚,你還是說明程序運行到到第幾行停止吧。
ID:198189 發表于 2022-10-20 12:12 | 只看該作者
溫xyz 發表于 2022-10-20 11:05
程序運行后只顯示計數,不顯示速度。就算我在程序開關規定讓它不經檢測直接默認顯示速度也無法顯示出來。
ID:198189 發表于 2022-10-20 12:19 | 只看該作者
另說明,程序是可以運行起來的,計數也是正確的。我調試時是把計數顯示直接去掉的,不是讓它們兩個同時運行,然后發現它不運行速度顯示的語句。我糾結了半天沒發現我的問題出現在哪里?
ID:161164 發表于 2022-10-20 16:41 | 只看該作者
xia20 發表于 2022-10-20 10:02
ID:198189 發表于 2022-10-20 21:24 | 只看該作者
大佬請收下我的膝蓋,我這是寫暈了頭忘了改了。
