查看: 2779|回復: 5
一個實現硬件I2C從機收發的單片機程序,有幾個地方不懂,希望大佬們分析一下
ID:1043477 發表于 2022-9-21 17:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "RX8F103.h"
#define        STCON         MSCON
#define        SRXBUF        MSRXBUF
#define        STXBUF        MSTXBUF
#define        SSTAT0        MSSTAT0
#define        SSTAT1        MSSTAT1
#define        SIEN0                MSIEN0
#define        SIEN1                MSIEN1
#define        SSADDR        MSADDR
//I2C主機多字節,單字節讀寫
//I2C Master 和 I2C Slave通信協議
S + DevAdd(Read)  + BayteN + Stop
S + DevAdd(Write) + BayteN + Stop
//I2C從機地址  7位地址
#define I2C_SLAVE_ADD   0x50
#define BUFF_MAX 128
unsigned char xdata DataBuf[BUFF_MAX];
unsigned char DataTxIndex = 0;
unsigned char DataRxIndex = 0;
unsigned char InterruptIndex = 0;
unsigned char WrtieTxBufFlag = 0;
void EUart0_SendOneChar(char c)
        ES0=0;                                //發送數據時關串口中斷
        TI0=0;                                //清TI位
        S0BUF = c;                //將待發送字符放入串口數據緩沖寄存器,并開始傳輸。
        while(!TI0);        //等待傳送結束。當字符發送結束后由硬件置位請求中斷,
        //此時while循環結束,而串口中斷處理函數需等到ES重新置1后才可能響應。
        TI0=0;                                //軟件清TI位,亦可在中斷處理函數中清0
        ES0 = 1;                        //開串口中斷
void EUart0_SendString(char *st)
        while(*st)
                EUart0_SendOneChar(*st++);
void Uart0_init(void)
        UART0PORTEN = 1;        //串口端口使能
        S0CON = 0x50;                        //SCON: Mode 1, 8-bit UART, Enable Rcvr
        S0RELH = 0x03;                //S0RELH + S0RELL  構成波特率設置S0REL[9:0]
        S0RELL = 0xF7;                //Baud rate  = SYSCK/(16×(1024-S0REL))  SYSCK跟CLKDIV寄存器有關  波特率為115200
        ES0 = 1;                                        //允許串口中斷位
        EUart0_SendString("RX8F103 UART0 Init OK!\r\n");
void I2c_Init(void)
        I2CPORTEN = 1;                                //IIC PORT口使能
        TOPCON = 0x00;                                //IIC Slave
        SSADDR = I2C_SLAVE_ADD;//IIC 從機地址寄存器
        SIEN0 = 0x01;                                        //正常結束中斷
        SIEN1 = 0x21;                                        //使能接收區滿中斷
        STCON = 0x40;                                        //使能I2C
void I2c_TxBuf_Reset(void)
        TOPCON |= 0x02;
        TOPCON &= 0xFD;
        I2c_Init();
void main(void)
        unsigned char i;
        CLKCON |= 0x1F;                                //默認所有時鐘打開
        RSTPORTEN = 1;                                //使能復位功能
        Uart0_init();
        //初始化數組
        for (i=0; i<BUFF_MAX; i++)
                DataBuf[ i] = 0x10+i;
        I2c_Init();
        EI2CFIFO = 1;                                        //開IIC FIFO 中斷
        EI2CRXTX = 1;                                        //開IIC TXRX 中斷
        EA = 1;        //使能總中斷
        while(1);
GC
SUNF
SOVF
SNE
以上任意一個或多個事件發送,均為產生EI2CRXTX中斷
void I2C_Slave_TRX_ISR(void) interrupt EI2CRXTX_VECTOR                //TRX中斷
        unsigned char ReadData;
        //Transmitted Data Byte not ready
        if (0x04 == (SSTAT0 & 0x04))
                //清中斷標志位
                SSTAT0 &= 0xFB;
        //Receive Overflow
        if (0x02 == (SSTAT0 & 0x02))
                ReadData = SRXBUF;
                //清中斷標志位
                SSTAT0 &= 0xFD;
        //Normal End
        if (0x01 == (SSTAT0 & 0x01))
                InterruptIndex = 0;
                WrtieTxBufFlag = 0;
                I2c_TxBuf_Reset();
                //清中斷標志位
                SSTAT0 &= 0xFE;
STBE
STBF
SRBE
SRBF
以上任意一個或多個事件發送,均為產生EI2CFIFO中斷
void I2C_Slave_FIFO_ISR(void) interrupt EI2CFIFO_VECTOR                //FIFO中斷
        //Transmission buffer is empty
        if (0x20 == (SSTAT1 & 0x20))
                if ((DataTxIndex < BUFF_MAX) && (1 == WrtieTxBufFlag))
                        STXBUF = DataBuf[DataTxIndex];
                        DataTxIndex++;
                SSTAT1 &= 0xDF;
        // Reception buffer is full
        if (0x01 == (SSTAT1 & 0x01))
                ReadData = SRXBUF;
                if (0 == InterruptIndex)
                        //收到Sub地址
                        if (ReadData < BUFF_MAX)
                                DataTxIndex = ReadData;
                                DataRxIndex = ReadData;
                                WrtieTxBufFlag = 1;
                        WrtieTxBufFlag = 0;
                        if (DataRxIndex < BUFF_MAX)
                                DataBuf[DataRxIndex] = ReadData;
                                DataRxIndex++;
                InterruptIndex++;
                SSTAT1 &= 0xFE;
/*---------------------------------EUART0 ISR--------------------------------------------*/
void EUART0ISR(void) interrupt EUART0_VECTOR //using 2
        if(S0CON & RI0)        //接收中斷
        RI0 = 0;        //清中斷標志位
程序主要不懂在下面這一段
//收到Sub地址
WrtieTxBufFlag = 1;
WrtieTxBufFlag = 0;
DataRxIndex++;
InterruptIndex++;
SSTAT1 &= 0xFE;
為什么if (0 == InterruptIndex)要這樣判斷,這樣的不就會丟失第一個數據么
WrtieTxBufFlag = 1;這段程序到底是啥意思,看不懂
ID:123289 發表于 2022-9-22 08:49 | 只看該作者
這么長,是不是考慮一下:需要問的地方做夠明顯標記。
ID:1043477 發表于 2022-9-22 09:10 | 只看該作者
yzwzfyz 發表于 2022-9-22 08:49
好的,我等等把問的字體放大一下
ID:1043477 發表于 2022-9-22 09:14 | 只看該作者
自己頂一下,對孩子很重要
ID:624769 發表于 2022-9-23 12:13 | 只看該作者
=〉  第一數據,不是長度么? 下面不是把 長度賦值給 INDEX了么?
=〉 如果  “長度” 小于 “緩沖池最大值”(即:沒有溢出的話), 執行后面的語句, 即:賦值給 INDEX, 寫發送標志置1,等等。
ID:1043477 發表于 2022-9-24 15:11 | 只看該作者
188610329 發表于 2022-9-23 12:13
=〉  第一數據,不是長度么?  ...
的確很怪,我已經大改了程序,現在勉強可以使用,還不完善,如果后續有問題,大佬再幫忙解答一下
