查看: 1741|回復: 4
LCD1602.h(8): error C129: missing ';' before 'LCD1602_RS'
ID:1044527 發(fā)表于 2022-9-12 11:29 | 顯示全部樓層 |閱讀模式
請問這個錯誤該怎么辦?改了很久都不對
#ifndef __LCD1602_H__
#define __LCD1602_H__
#define LCD1602_PORT P0
//#include <reg52.h>
#include <STC89C5xRC.H>
Sbit LCD1602_RS = P2^6;
Sbit LCD1602_RW = P2^5;
Sbit LCD1602_EN = P2^7;
extern void LCD1602_delay_ms(unsigned int n);
extern void LCD1602_write_com(unsigned char com);
extern void LCD1602_printc(unsigned char dat);
extern void LCD1602_prints(unsigned char *s);
extern void LCD1602_Init();
extern void LCD1602_set_position( bit hang, unsigned char x);           //LCD?????x?
extern void LcdPrintNum(unsigned int num);
#endif
ID:123289 發(fā)表于 2022-9-12 14:09 | 顯示全部樓層
錯誤在【LCD1602.h】中找。
ID:155507 發(fā)表于 2022-9-12 14:31 | 顯示全部樓層
  1. #ifndef __LCD1602_H__
  2. #define __LCD1602_H__
  3. #define LCD1602_PORT P0
  4. //#include <reg52.h>
  5. #include <STC89C5xRC.H>
  6. sbit LCD1602_RS = P2^6;  //Sbit LCD1602_RS = P2^6; Sbit 的S是小寫 <-----------------
  7. sbit LCD1602_RW = P2^5;  //Sbit LCD1602_RW = P2^5;
  8. sbit LCD1602_EN = P2^7;  //Sbit LCD1602_EN = P2^7;
  9. //????????
  10. extern void LCD1602_delay_ms(unsigned int n);
  11. extern void LCD1602_write_com(unsigned char com);
  12. extern void LCD1602_printc(unsigned char dat);
  13. extern void LCD1602_prints(unsigned char *s);
  14. extern void LCD1602_Init();
  15. extern void LCD1602_set_position( bit hang, unsigned char x);           //LCD?????x?
  16. extern void LcdPrintNum(unsigned int num);
  17. #endif
ID:59202 發(fā)表于 2022-9-12 19:58 | 顯示全部樓層
你把小寫sbit寫成大寫Sbit了,在keil編輯器中對關鍵字的字體和顏色做一下設置,比如設置成藍色或紅色,斜體字等,一眼就可以看出關鍵字是否寫正確了
ID:282850 發(fā)表于 2022-9-14 00:22 | 顯示全部樓層
具體不好說,一種是問題在其它C或h中,另一種是把#include <STC89C5xRC.H>放在文件最前,不要在#ifndef 及#define內試試
