查看: 1120|回復: 0
PIC18F4520無法調試問題
ID:1042189 發表于 2022-8-17 10:50 | 顯示全部樓層 |閱讀模式
在MPLAB X IDE上編譯好程序后能成功運行,也成功燒錄(利用PICKIT-4)到開發板上(慧凈電子HL-K18),但在MPLAB里卻無法調試,瀏覽了許多網站問題還是無法解決,彈出的錯誤如下,請各位大佬指點一下The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings.
