查看: 1184|回復: 0
51單片機控制舵機驅動pc9685
ID:1039984 發表于 2022-7-19 20:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
                        PCA9685??????
                ??:89C52,??:11.0592
#include<reg52.h>
#include <intrins.h>
#include <stdio.h>
#include <math.h>
typedef  unsigned char  uchar;
typedef  unsigned int   uint;
sbit scl=P3^6;                        //?????
sbit sda=P3^7;                   //????/???
#define PCA9685_adrr 0x80//  1+A5+A4+A3+A2+A1+A0+w/r
                        //????,?????1?????,
                        // ?IIC? ?? ??PCA9685??????????
#define PCA9685_SUBADR1 0x2
#define PCA9685_SUBADR2 0x3
#define PCA9685_SUBADR3 0x4
#define PCA9685_MODE1 0x0
#define PCA9685_PRESCALE 0xFE
#define LED0_ON_L 0x6
#define LED0_ON_H 0x7
#define LED0_OFF_L 0x8
#define LED0_OFF_H 0x9
#define ALLLED_ON_L 0xFA
#define ALLLED_ON_H 0xFB
#define ALLLED_OFF_L 0xFC
#define ALLLED_OFF_H 0xFD
#define SERVOMIN  90 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  700 // this is the 'maximum' pulse length count (out of 4096)
#define SERVO000  130 //0???4096??????
#define SERVO180  520 //180???4096??????,????????????
void delayms(uint z)
  uint x,y;
  for(x=z;x>0;x--)
      for(y=148;y>0;y--);
        IIC?????????
                 ???????? ??4.7us
void delayus()
          _nop_();          //?intrins.h???
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                 IIC???????
void init()
    sda=1;                //sda scl????????
    delayus();
    scl=1;
    delayus();
                 IIC????????
void start()
    sda=1;
    delayus();
    scl=1;                        //scl??? sda??????? ????IIC??
    delayus();
    sda=0;
    delayus();
    scl=0;
    delayus();
                 IIC????????
void stop()
    sda=0;
    delayus();
    delayus();
    sda=1;
    delayus();
                 IIC????????
void ACK()
    uchar i;
    scl=1;
    delayus();
    while((sda==1)&&(i<255))         //?????sda=1?????????????
                i++;
    scl=0;
    delayus();
void write_byte(uchar byte)
    uchar i,temp;
    temp=byte;
    for(i=0;i<8;i++)
        temp=temp<<1;
        scl=0;
                                delayus();
                                sda=CY;
                                delayus();
                                scl=1;
                                delayus();
    scl=0;
    delayus();
    sda=1;
    delayus();
uchar read_byte()
                uchar i,j,k;
                scl=0;
                delayus();
                sda=1;
                delayus();
                for(i=0;i<8;i++)
                                delayus();
                                scl=1;
                delayus();
                if(sda==1)
                                j=1;
                else j=0;
                k=(k<< 1)|j;
                scl=0;
                delayus();
                return k;
                ??PCA9685?????
                ?PCA9685????,??
void PCA9685_write(uchar address,uchar date)
                start();
                write_byte(PCA9685_adrr);        //PCA9685?????
                ACK();
                write_byte(address);  //???????
                ACK();
                write_byte(date);          //???
                ACK();
                stop();
            ?PCA9685?????????(????)
uchar PCA9685_read(uchar address)
                uchar date;
                start();
                ACK();
                ACK();
                start();
                write_byte(PCA9685_adrr|0x01);        //?????????????,?????
                ACK();
                date=read_byte();
                stop();
                return date;
                        PCA9685??
void reset(void)
                PCA9685_write(PCA9685_MODE1,0x0);
void begin(void)
                reset();
                                        PCA9685??????
void setPWMFreq(float freq)
                uint prescale,oldmode,newmode;
                float prescaleval;
                freq *= 0.92;  // Correct for overshoot in the frequency setting
                prescaleval = 25000000;
                prescaleval /= 4096;
                prescaleval /= freq;
                prescaleval -= 1;
                prescale = floor(prescaleval + 0.5);
                oldmode = PCA9685_read(PCA9685_MODE1);
                newmode = (oldmode&0x7F) | 0x10; // sleep
                PCA9685_write(PCA9685_MODE1, newmode); // go to sleep
                PCA9685_write(PCA9685_PRESCALE, prescale); // set the prescaler
                PCA9685_write(PCA9685_MODE1, oldmode);
                delayms(2);
                PCA9685_write(PCA9685_MODE1, oldmode | 0xa1);
                                PCA9685??????
num:??PWM????0~15,on:PWM?????0~4096,off:PWM?????0~4096
??PWM????4096?,?0??+1??,??on???????,?????off?
??????,????4096????????on???0?????,?on??0?,
off/4096????PWM?????
void setPWM(uint num, uint on, uint off)
                PCA9685_write(LED0_ON_L+4*num,on);
                PCA9685_write(LED0_ON_H+4*num,on>>8);
                PCA9685_write(LED0_OFF_L+4*num,off);
                PCA9685_write(LED0_OFF_H+4*num,off>>8);
        uint a=1;
        uint b=0;
                begin();
                setPWMFreq(50);
                //????????60?,???,
                //60??????=0.5ms+(60/180)*(2.5ms-0.5ms)=1.1666ms
                //?????=1.1666ms/20ms=off/4096,off=239,50hz????20ms
                //setPWM(num,0,239);;;;???????SERVO000?SERVO180??
        if(a>400)
        b=1;
        if(a<200)
        b=0;
        if(b==0){
        a=a+1;
        if(b==1){
        a=a-1;
        //a=a%700
                                setPWM(0, 1, a);//?0?????????
                                //setPWM(1, 0, SERVO000);//?1?????0??
        //setPWM(15, 0, 3000);
                                delayms(1);
                                //setPWM(0, 0, SERVO180);
//                              setPWM(1, 0, SERVO180);
                                //delayms(15);
