查看: 3294|回復(fù): 5
STM32 DMA串口接收為什么運(yùn)行不了,進(jìn)不了空閑中斷
ID:302293 發(fā)表于 2022-7-7 18:20 | 顯示全部樓層 |閱讀模式
#include "sys.h"
#include "usart.h"
int fputc(int ch, FILE *f)
        while((USART1->SR&0X40)==0);//循環(huán)發(fā)送,直到發(fā)送完畢
    USART1->DR = (u8) ch;
        return ch;
/*使用microLib的方法*/
        USART_SendData(USART1, (uint8_t) ch);
        while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {}
    return ch;
int GetKey (void)  {
    while (!(USART1->SR & USART_FLAG_RXNE));
    return ((int)(USART1->DR & 0x1FF));
u8  DMA_Rece_Buf[DMA_Rec_Len];           //DMA接收串口數(shù)據(jù)緩沖區(qū)
u16  Usart1_Rec_Cnt=0;             //本幀數(shù)據(jù)長度
//UART1的GPIO初始化
void UART1_GPIO_Init(void)
        //GPIO端口設(shè)置
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能GPIOA時鐘
        //USART1_TX   PA.9
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //復(fù)用推挽輸出
        GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9
        //USART1_RX          PA.10
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空輸入
        GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA10
//UART1的中斷優(yōu)先級初始化
void UART1_NVIC_Init(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;                //串口1接收中斷
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//搶占優(yōu)先級3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子優(yōu)先級3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure); //根據(jù)指定的參數(shù)初始化VIC寄存器
//UART1的DMA初始化
void UART1_DMA_Init(void)
        DMA_InitTypeDef DMA_InitStructure;
        //相應(yīng)的DMA配置
        DMA_DeInit(DMA1_Channel5);   //將DMA的通道5寄存器重設(shè)為缺省值  串口1對應(yīng)的是DMA通道5
        DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&USART1->DR;  //DMA外設(shè)ADC基地址
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)DMA_Rece_Buf;  //DMA內(nèi)存基地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //數(shù)據(jù)傳輸方向,從外設(shè)讀取發(fā)送到內(nèi)存
        DMA_InitStructure.DMA_BufferSize = DMA_Rec_Len;  //DMA通道的DMA緩存的大小
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外設(shè)地址寄存器不變
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //內(nèi)存地址寄存器遞增
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //數(shù)據(jù)寬度為8位
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //數(shù)據(jù)寬度為8位
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //工作在正常緩存模式
        DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x擁有中優(yōu)先級
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x沒有設(shè)置為內(nèi)存到內(nèi)存?zhèn)鬏?br />         DMA_Init(DMA1_Channel5, &DMA_InitStructure);  //根據(jù)DMA_InitStruct中指定的參數(shù)初始化DMA的通道USART1_Tx_DMA_Channel所標(biāo)識的寄存器
        DMA_Cmd(DMA1_Channel5, ENABLE);  //正式驅(qū)動DMA傳輸
//初始化IO 串口1
//bound:波特率
void uart_init(u32 bound)
        USART_InitTypeDef USART_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);        //使能USART1時鐘
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);        //使能DMA傳輸
        //USART 初始化設(shè)置
        USART_InitStructure.USART_BaudRate = bound; //串口波特率
        USART_InitStructure.USART_WordLength = USART_WordLength_8b; //字長為8位數(shù)據(jù)格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1; //一個停止位
        USART_InitStructure.USART_Parity = USART_Parity_No; //無奇偶校驗(yàn)位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //無硬件數(shù)據(jù)流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收發(fā)模式
        USART_Init(USART1, &USART_InitStructure); //初始化串口1
        UART1_GPIO_Init(); //UART1的GPIO初始化
        UART1_NVIC_Init(); //UART1的中斷優(yōu)先級初始化
        USART_ITConfig(USART1, USART_IT_IDLE, ENABLE); //開啟空閑中斷
        USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);   //使能串口1 DMA接收
        USART_Cmd(USART1, ENABLE);                     //使能串口
        UART1_DMA_Init(); //DMA功能初始化
//重新使能UART1_RX的DMA功能
void UART1_RX_DMA_Enable(DMA_Channel_TypeDef *DMA_CHx)
        //對于標(biāo)準(zhǔn)庫,空閑中先處理完數(shù)據(jù)再停止DMA
        DMA_Cmd(DMA_CHx, DISABLE ); //先停止DMA,暫停接收
         DMA_SetCurrDataCounter(DMA_CHx, DMA_Rec_Len);//DMA通道的DMA緩存的大小
         DMA_Cmd(DMA_CHx, ENABLE);  //使能USART1 TX DMA1 所指示的通道
//發(fā)送len個字節(jié).
//buf:發(fā)送區(qū)首地址
//len:發(fā)送的字節(jié)數(shù)
void Usart1_Send(u8 *buf,u8 len)
        u8 t;
          for(t=0;t<len;t++)                //循環(huán)發(fā)送數(shù)據(jù)
                while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
                USART_SendData(USART1,buf[t]);
//串口1中斷服務(wù)程序
void USART1_IRQHandler(void)
        u8 Res;
        //串口1空閑中斷
        if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)
                /* 1.清除標(biāo)志 */
                USART_ClearITPendingBit(USART1, USART_IT_IDLE); //清除中斷標(biāo)志
                /* 2.讀取DMA */
                USART_ReceiveData(USART1); //讀取數(shù)據(jù)
                Usart1_Rec_Cnt = DMA_Rec_Len - DMA_GetCurrDataCounter(DMA1_Channel5); //接收個數(shù)等于接收緩沖區(qū)總大小減已經(jīng)接收的個數(shù)
                /* 3.搬移數(shù)據(jù)進(jìn)行其他處理 (非DMA串口發(fā)送方式) */
                Usart1_Send(DMA_Rece_Buf, Usart1_Rec_Cnt); //將接收轉(zhuǎn)移通過串口1發(fā)送出去測試
                /* 4.開啟新的一次DMA接收 */
                UART1_RX_DMA_Enable(DMA1_Channel5); //重新使能DMA,等待下一次的接收
ID:301191 發(fā)表于 2022-7-7 23:51 | 顯示全部樓層
頂一下
ID:958310 發(fā)表于 2022-7-8 09:47 | 顯示全部樓層
GPIO定義那里把AFIO時鐘開一下看看
ID:195496 發(fā)表于 2022-7-8 13:52 | 顯示全部樓層
DMA時鐘打開沒有?
ID:302293 發(fā)表于 2022-7-19 08:48 | 顯示全部樓層
打開了,還是不行啊
ID:401564 發(fā)表于 2022-7-19 22:07 | 顯示全部樓層
我以為十來天了,問題已經(jīng)解決了端口A用的是復(fù)用AFIO,所以,要啟動AFIO時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能復(fù)用和端口時鐘
中斷函數(shù)增加清除中斷標(biāo)志功能
if(USART_GetFlagStatus(USART1,USART_FLAG_RXNE)==Bit_SET)
                USART_ClearFlag(USART1,USART_FLAG_RXNE);//清除接收標(biāo)志位
        if(USART_GetFlagStatus(USART1,USART_FLAG_TC)==Bit_SET)
                USART_ClearFlag(USART1,USART_FLAG_TC);//清除完成標(biāo)志位
其它的問題暫時沒有看到
