查看: 1655|回復: 1
關于Arduino Blinker庫中的按鍵回調函數疑問
ID:991374 發表于 2022-6-23 15:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
功能:在Blinker的APP端設置了4個按鍵,按下每個按鍵esp32端口輸出不同的數組
問題:a,b,c,d四個按鍵對應輸出A,B,C,D四個數組,但實際上按下b會輸出AB兩個數組的數,按下c會輸出ABC三個數組的數,按下d會輸出ABCD四個數            組的數。求助。。。
代碼:
#define BLINKER_WIFI
#include <Blinker.h>
#include <Arduino.h>
char DATA1[]={0x55,0xAA,0x11,0x02,0x01,0x10,0x24,0x02};
char DATA2[]={0x55,0xAA,0x11,0x02,0x01,0x20,0x34,0x32};
char DATA3[]={0x55,0xAA,0x22,0x02,0x01,0x10,0x35,0x31};
char DATA4[]={0x55,0xAA,0x22,0x02,0x01,0x20,0x45,0x01};
char auth[] = "5b05dc85109b";//Your Device Secret Key
char ssid[] = "keke";//Your WiFi network SSID or name
char pswd[] = "123456789";//Your WiFi network WPA password or WEP key
BlinkerButton Button1("btn-1l");
BlinkerButton Button2("btn-1r");
BlinkerButton Button3("btn-2l");
BlinkerButton Button4("btn-2r");
void Button1_callback(const String & state)
   digitalWrite(5,HIGH);
   Serial.print(DATA1);
   Blinker.delay(300);
void Button2_callback(const String & state)
   Serial.print(DATA2);
   Blinker.delay(300);
void Button3_callback(const String & state)
   Serial.print(DATA3);
   Blinker.delay(300);
void Button4_callback(const String & state)
   Serial.print(DATA4);
   Blinker.delay(300);
void setup() {
  Serial.begin(14400);
  pinMode(5,OUTPUT);
  Blinker.begin(auth, ssid, pswd);
  Button1.attach(Button1_callback);
  Button2.attach(Button2_callback);
  Button3.attach(Button3_callback);
  Button4.attach(Button4_callback);
void loop() {
  Blinker.run();
  digitalWrite(5,LOW);
ID:991374 發表于 2022-6-23 16:21 | 只看該作者
我用for循環把數組成員一個一個print出來,結果是可以的;但直接print數組不行
