STM32L05系列ADC功能,精確到1毫伏。可以編譯直接用,通過串口1將數(shù)據(jù)發(fā)出,顯示的是實時的電壓值。
單片機(jī)源程序如下:
- #include "main.h"
- #include "adc.h"
- #include "usart.h"
- #include "gpio.h"
- #define led_on HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_RESET);
- #define led_off HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_SET);
- extern unsigned char flag;
- extern unsigned char sec_flag;
- uint16_t value;
- uint8_t valuel,valueh;
- uint16_t dianya;
- void SystemClock_Config(void);
- int main(void)
- HAL_Init();
- SystemClock_Config();
- MX_GPIO_Init();
- MX_ADC_Init();
- MX_USART1_UART_Init();
- CalibrateADC();
- HAL_ADC_Start(&hadc);
- while (1)
- value=(HAL_ADC_GetValue(&hadc)-0x1e);
- //valueh=(HAL_ADC_GetValue(&hadc)&0xFf00)>>8;/////取得AD轉(zhuǎn)換結(jié)果高8位
- //valuel=HAL_ADC_GetValue(&hadc)&0x00ff; //////////取得AD轉(zhuǎn)換結(jié)果低8位
- dianya=((uint16_t)value*3300/4096);
- if(flag)
- USART1_Send_Byte(dianya/1000+0x30);
- USART1_Send_Byte(0X2E);
- USART1_Send_Byte((dianya/100)%10+0x30);
- USART1_Send_Byte((dianya/10)%10+0x30);
- USART1_Send_Byte(dianya%10+0x30);
- USART1_Send_Byte(0X56);
- // USART1_Send_Byte(valueh);
- //USART1_Send_Byte(valuel);
- flag=0;
- if(dianya>=2500) ///電壓大于等于2.5V
- led_on;
- else
- led_off;
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
- /** Configure the main internal regulator output voltage
- __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
- /** Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_3;
- RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_2;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
- Error_Handler();
- PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
- PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
- if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
Keil代碼下載 hal庫:
代碼.7z
(2.42 MB, 下載次數(shù): 28)
2022-6-23 15:44 上傳
STM32L051adc 下載積分: 黑幣 -5
