查看: 1579|回復: 0
C語言結構體數組[3],[4]是什么意思,參數怎么提取?
ID:302293 發表于 2022-6-15 18:08 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
typedef enum {
        PORT2 = 2,                        /* RS485 port2 */
        PORT3,                                /* RS485 port3 */
        PORT4,                                /* RS485 port4 */
} SBUPORT;
typedef enum
    a1,
    a2,
}SUBTYPE ;
typedef struct {
        uint8_t exAlarmID                : 8;
        uint8_t exAlarmPort        : 2;
        uint8_t alarmCH                : 5;
        uint8_t alarmSW                : 1;
} alarm_cfg_t;
alarm_cfg_t uk;
typedef struct {
        uint8_t exAlarmID        ;
        uint8_t exAlarmPort        ;
        uint8_t alarmCH                ;
        uint8_t alarmSW                ;
} cb;
typedef struct {
        /* 采集子設備通用配置 */
        SUBTYPE          type;
        uint16_t         vendor;        /* 設備供應商, 0為默認設備 */
        SBUPORT          port;
        uint16_t         devID;
        alarm_cfg_t alarm;         /* 報警配置 */
        /* 采集子設備私有配置參數 */
        struct {
                uint16_t cfg[MAX_PRIVATE_PRARS];
        } priv;
} subdev_cfg_t;
subdev_cfg_t number[5]=
     {.type=1 },
[3]={.type=2,1,PORT3,3,5},
  [4]={.type=2,1,PORT3,3,5},
