查看: 2258|回復: 6
51單片機C語言程序位置的不對,導致的意外問題
這是個矩陣按鍵,按下任意一個按鍵,數碼管顯示從0-F的值。
單片機C語言源程序如下:
  1. #include<reg52.h>
  2. sbit ADDR0 = P1^0;
  3. sbit ADDR1 = P1^1;
  4. sbit ADDR2 = P1^2;
  5. sbit ADDR3 = P1^3;
  6. sbit ENLED = P1^4;
  7. sbit KeyIn_1 = P2^7;
  8. sbit KeyIn_2 = P2^6;
  9. sbit KeyIn_3 = P2^5;
  10. sbit KeyIn_4 = P2^4;
  11. sbit KeyOut_1 = P2^3;
  12. sbit KeyOut_2 = P2^2;
  13. sbit KeyOut_3 = P2^1;
  14. sbit KeyOut_4 = P2^0;
  15. unsigned char code LedChar[16] = {                                         //數碼管真值表
  16.     0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  17.                 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  18. };
  19. unsigned char keyStatus[4][4] = {                                          //全部矩陣按鍵當前的狀態
  20.     {1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
  21. };
  22. void main(){
  23.     unsigned char i,j;
  24.     unsigned char cnt = 0;
  25.     unsigned char backUp[4][4] = {{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}}; //按鍵狀態,保存前一次的值
  26.     EA = 1;
  27.     ENLED = 0;
  28.     ADDR3 = 1;
  29.     ADDR2 = 0;
  30.     ADDR1 = 0;
  31.     ADDR0 = 0;
  32.     TMOD = 0x01;
  33.     TH0 = 0xFC;
  34.     TL0 = 0x67;
  35.     ET0 = 1;
  36.     TR0 = 1;
  37.         P0 = LedChar[cnt];
  38.
  39.     while(1){
  40.         for(i = 0; i < 4; i++){
  41.             for(j = 0;j < 4; j++){
  42.                 if(backUp[i][j] != keyStatus[i][j]){
  43.                     if(backUp[i][j] == 0){ //按鍵抬起
  44.                     cnt++;
  45.                     if(cnt >= 16){
  46.                         cnt = 0;
  47.                     }
  48.                     P0 = LedChar[cnt];
  49.                     }
  50.                     backUp[i][j] = keyStatus[i][j];
  51.                 }
  52.             }
  53.                 }
  54.         }
  55. }
  56. /*T0中斷服務函數,判斷按鍵狀態并消抖*/
  57. void interruptTimer0() interrupt 1{
  58.     unsigned char i;
  59.     static unsigned char keyOut = 0;
  60.     static unsigned char keyBuff[4][4] = {
  61.         {0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF}          //矩陣按鍵掃描緩沖區
  62.     };
  63.     TH0 = 0xFC;
  64.     TL0 = 0x67;
  65.     keyBuff[keyOut][0] = (keyBuff[keyOut][0] << 1) | KeyIn_1;  //按位與,將KeyIn_1的最后一位移入緩沖區。按位與的結果:最后1位是0就移入0,是1就移入1。
  66.     keyBuff[keyOut][1] = (keyBuff[keyOut][1] << 1) | KeyIn_2;  //按位與,將KeyIn_2的最后一位移入緩沖區。按位與的結果:最后1位是0就移入0,是1就移入1。
  67.     keyBuff[keyOut][2] = (keyBuff[keyOut][2] << 1) | KeyIn_3;  //按位與,將KeyIn_3的最后一位移入緩沖區。按位與的結果:最后1位是0就移入0,是1就移入1。
  68.     keyBuff[keyOut][3] = (keyBuff[keyOut][3] << 1) | KeyIn_4;  //按位與,將KeyIn_4的最后一位移入緩沖區。按位與的結果:最后1位是0就移入0,是1就移入1。
  69.     //更新消抖狀態
  70.     for(i = 0; i <= 3 ; i++){
  71.         if((keyBuff[keyOut][i] & 0x0F) == 0x00){
  72.             keyStatus[keyOut][i] = 0;
  73.         }
  74.         else if((keyBuff[keyOut][i] & 0x0F) == 0x0F){
  75.             keyStatus[keyOut][i] = 1;
  76.         }
  77.     }
  78.     //執行下一次的掃描輸出
  79.     keyOut++;
  80.     if(keyOut > 4){
  81.         keyOut = 0;
  82.     }
  83.     //根據索引keyOut,釋放當前輸出引腳,拉低下次的輸出引腳。
  84.     switch(keyOut){
  85.         case 0: KeyOut_4 = 1; KeyOut_1 = 0; break;
  86.         case 1: KeyOut_1 = 1; KeyOut_2 = 0; break;
  87.         case 2: KeyOut_2 = 1; KeyOut_3 = 0; break;
  88.         case 3: KeyOut_3 = 1; KeyOut_4 = 0; break;
  89.         default: break;
  90.     }
  91. }
問題:其中這段代碼放在switch的前面,有一排按鍵按下,數碼管就一直在累加。
雖然keyOut初始值為0,++一次為1,錯過了keyOut為0的判斷,但是KeyOut加到4的時候,就置0了,下一輪,case0就可以覆蓋的到。
  1. //執行下一次的掃描輸出
  2. keyOut++;
  3. if(keyOut > 4){
  4. keyOut = 0;
  5. }
這段代碼放到switch后就ok了,但是邏輯上我 實在不明白為什么放在前面就不可以。求各位大神給指點一下,答疑解惑!
ID:1034164 發表于 2022-6-12 19:17 | 只看該作者
為了方便格式化 閱讀,我生成了代碼的圖片
ID:213173 發表于 2022-6-13 06:05 | 只看該作者
xcopter 發表于 2022-6-12 19:17
發生錯誤的根本原因是代碼錯誤,改變代碼位置只是改變發生錯誤的矩陣行。
錯誤:if(keyOut > 4)
正確:if(keyOut >= 4) 或 if(keyOut > 3)
ID:688692 發表于 2022-6-13 09:02 | 只看該作者
轉成就成圖看看
ID:979299 發表于 2022-6-13 11:54 | 只看該作者
條件表達式語句,動作里面沒有包括switchy語句,放到前后都沒有作用。
這個格式是java語言寫法吧
| 這個管道符在這里是按位或啊
ID:275826 發表于 2022-6-13 15:53 | 只看該作者
這個程序代碼長,內存大,不好
ID:428114 發表于 2022-6-13 17:52 | 只看該作者
// 執行下一次的掃描輸出
        keyOut++;
       if(keyOut > 4)
            keyOut = 0;
這個是要給下一次掃描處理的吧?
    switch(keyOut)
這個switch處理的是keyOut當前值
要先處理當前的,然后再考慮下一個,邏輯要清楚啊
