查看: 1798|回復: 3
單片機設計把led燈的代碼加到主函數后數碼管就不亮了
#include<reg52.h>
char s;
uchar num=0;
char time=20;
char datitime=30;
uint tt,t1;
bit flag,s_flag=1,b_flag,fall_flag,fw_flag;
sbit K0=P3^0;
sbit beep=P3^7;
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit D1=P1^4;
sbit D2=P1^5;
sbit D3=P1^6;
sbit D4=P1^7;
sbit K_fw=P3^2;
sbit K_Time=P3^5;
void delay(uchar ms)
        uchar y;
        for(;ms>0;ms--)
                for(y=120;y>0;y--);
uchar code tabledu[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar code tablewe[]={0XFE,0XFD,0XFB,0XF7};
void T0_Init(void)
        TMOD=0X01;
        TH0=(65536-2000)/256;
        TL0=(65536-2000)%256;
        TH1=(65536-2000)/256;
        TL1=(65536-2000)%256;
        ET0=1;
        ET1=1;
        EX0=1;
        EA=1;
        IT0=1;
        P0=0;
void Key_Scan(void)
        if(K0==0)
                delay(10);
                if(K0==0)
                        while(!K0);
                        TR0=1;
                        s=time;
                        tt=0;
                        flag=1;
                        s_flag=1;
                        b_flag=1;
                        num=0;
                        beep=1;
                        fall_flag=0;
void Scan(void)
        if(K1==0)
                delay(10);
                if(K1==0)
                        while(!K1);
                        num=1;
                        TR0=0;
                        TR1=1;
                        s_flag=0;
        if(K2==0)
                delay(10);
                if(K2==0)
                        while(!K2);
                        num=2;
                        TR0=0;
                        TR1=1;
                        s_flag=0;
        if(K3==0)
                delay(10);
                if(K3==0)
                        while(!K3);
                        num=3;
                        TR0=0;
                        TR1=1;
                        s_flag=0;
        if(K4==0)
                delay(10);
                if(K4==0)
                        while(!K4);
                        num=4;
                        TR0=0;
                        TR1=1;
                        s_flag=0;
void display(void)
        if(flag==1)
                if(num!=0)
                        P0=tabledu[num];
                        P2=tablewe[0];
                        delay(2);
                        P0=0;
                        P2=0XFF;
                        P0=0;
                        P2=0XFF;
                P0=tabledu[s/10];
                P2=tablewe[2];
                delay(2);
                P0=0;
                P2=0XFF;
                P0=tabledu[s%10];
                P2=tablewe[3];
                delay(2);
                P2=0XFF;
                P0=0;
                if(fall_flag==1)
                        if(num!=0)
                                P0=tabledu[num];
                                P2=tablewe[0];
                                delay(2);
                                P0=0;
                                P2=0XFF;
                                P0=tabledu[15];
                                P2=tablewe[2];
                                delay(2);
                                P0=0;
                                P2=0XFF;
                                P0=tabledu[15];
                                P2=tablewe[3];
                                delay(2);
                                P0=0;
                                P2=0XFF;
                                P0=0;
                                P2=0XFF;
                                P0=tabledu[15];
                                P2=tablewe[0];
                                delay(2);
                                P0=0;
                                P0=tabledu[15];
                                P2=tablewe[2];
                                delay(2);
                                P0=0;
                                P2=0XFF;
                                P0=tabledu[15];
                                P2=tablewe[3];
                                delay(2);
                                P0=0;
                                P2=0XFF;
void main(void)
        T0_Init();
           if(K0==0)
              D1=0;
                Key_Scan();
                if((flag==0)&(s_flag==1))
                if((flag==1)&(s_flag==0))
                        if(K_Time==0)
                                delay(10);
                                if(K_Time==0)
                                        while(!K_Time);
                                        s=datitime;
                                        TR0=1;
                                        tt=0;
                                        TR1=1;
                        Scan();
                        if(num!=0)
                                fall_flag=1;
                if((flag==1)&(s_flag==1))
                        Scan();
                display();
void int0(void) interrupt 0
        if(K_fw==0)
        while(!K_fw)
                   while(K0==1)
                {P0=tabledu[15];
                P2=tablewe[0];
                delay(2);
                P0=0;
                P0=tabledu[15];
                P2=tablewe[2];
                delay(2);
                P0=0;
                P2=0xFF;
                P0=tabledu[15];
                P2=tablewe[3];
                delay(2);
                P0=0;
                P2=0xFF;}
void timer0(void) interrupt 1
        TH0=(65536-2000)/256;        //2ms
        if(b_flag)
                beep=~beep;
        beep=1;
        if(s<5)
                if(s%2==0)
                        b_flag=1;
                        b_flag=0;
        tt++;
        if(tt==500)
                tt=0;
                s--;
                b_flag=0;
                if(s==-1)
                        s=20;
                        TR0=0;
                        flag=0;
                        s_flag=1;
                        num=0;
void timer1(void) interrupt 3
        beep=~beep;
        t1++;
        if(t1==500)
                t1=0;
                TR1=0;
單片機設計把led燈的代碼加到主函數后數碼管就不亮了,但是把led燈的拿掉后又出來了.
ID:161164 發表于 2022-6-2 09:23 | 只看該作者
這是什么縫合怪代碼?
如果你說的led燈代碼是下面箭嘴所指的那段
你的C 語言要補一補課了
  1. void main(void)
  2. {
  3.         T0_Init();
  4.         while(1)
  5.         {//<<<<<<<<<<<<<<<
  6.                 if(K0==0)
  7.                 {
  8.                         D1=0;
  9.                 }
  10.         }//<<<<<<<<<<<<<<<
  11.         {
  12.                 Key_Scan();
  13.                 if((flag==0)&(s_flag==1))
  14.                         if((flag==1)&(s_flag==0))
  15.                         {
  16.                                 if(K_Time==0)
  17.                                 {
  18.                                         delay(10);
  19.                                         if(K_Time==0)
  20.                                         {
  21.                                                 while(!K_Time);
  22.                                                 s=datitime;
  23.                                                 TR0=1;
  24.                                                 tt=0;
  25.                                                 TR1=1;
  26.                                         }
  27.                                 }
  28.                         }
  29.                 if((flag==0)&(s_flag==1))
  30.                 {
  31.                         Scan();
  32.                         if(num!=0)
  33.                         {
  34.                                 fall_flag=1;
  35.                         }
  36.                 }
  37.                 if((flag==1)&(s_flag==1))
  38.                 {
  39.                         Scan();
  40.                 }
  41.                 display();
  42.         }
  43. }
ID:979299 發表于 2022-6-2 10:38 | 只看該作者
void main(void)
         T0_Init();
            if(K0==0)
               D1=0;
         }《《《《《《《《《《程序到此不再往下,要么改復合方式,要么加控制語句,要看你想要同時運行還是分時運行
                 Key_Scan();
ID:735831 發表于 2022-6-2 11:44 | 只看該作者
死循環,跑不出去理所應當,不跑出去哪來的數碼管亮滅
