查看: 801|回復: 1
麻煩大佬們看看這段C語言代碼,他這個怎么轉換成定時時間呀?我C學的不好
ID:1027053 發表于 2022-6-1 19:07 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
//第一段音樂
uchar code tones_array1[][2] = {251,207,251,76,250,104,251,76,252,122,251,207,251,76,251,207,250,104,251,76,251,207,251,76,250,104,249,184,248,244,247,158,251,76,250,104,249,184,249,184,250,104,251,76,251,76,251,207,250,104,249,184,248,244,251,76,250,104,249,184,248,244,247,158,248,244,246,152};
uint code times_array1[] = {1000,333,666,666,666,333,333,1333,666,333,333,666,333,333,333,333,333,333,1333,1000,333,666,333,333,1000,333,1333,1000,333,333,333,333,333,2666};
//第二段音樂
uchar code tones_array2[][2] = {248,244,249,184,250,104,248,244,248,244,249,184,250,104,248,244,250,104,250,184,251,76,250,104,250,184,251,76,251,76,251,207,251,76,250,184,250,104,248,244,251,76,251,207,251,76,250,184,250,104,248,244,249,184,246,152,248,244,249,184,246,152,248,244};
uint code times_array2[] = {250,250,250,250,250,250,250,250,250,250,500,250,250,500,125,125,125,125,250,250,125,125,125,125,250,250,250,250,500,250,250,500};
uchar code scale_array[][2] = {248,244,249,184,250,104,250,184,251,76,251,207,252,68};
ID:883242 發表于 2022-6-1 20:53 | 只看該作者
你貼的是數據,不是代碼。
