查看: 2961|回復: 3
關于絕緣路徑和絕緣類型
絕緣路徑A-a2和絕緣類型DI/RI是什么含義?具體指的什么?這里也沒有講到https://wenku.baidu.com/view/ca13dd5c4b73f242336c5fe6.html
ID:668004 發表于 2022-6-2 15:58 | 只看該作者
Hephaestus 發表于 2022-6-1 21:20
Insulation Diagrams
Over many years working as a consultancy you begin to build up a picture of the ...
非常感謝
ID:883242 發表于 2022-6-1 21:20 | 只看該作者
Insulation Diagrams
Over many years working as a consultancy you begin to build up a picture of the tricky topics in 60601. The one that is definitely at the top of the list is insulation (or isolation) diagrams. 60601 at present does not reference insulation diagrams, but ultimately this type of diagram is one of the most important tools in helping understand the challenges in section 8 on Electrical Hazards. Design teams need to have a full understanding of the isolation landscape and test houses will generally include an insulation diagram at the start of the 60601-1 report.
ID:883242 發表于 2022-6-1 21:09 | 只看該作者
double insulation .....................................................:DI
reinforced insulation ................:RI
