#include<reg51.h>
sbit sw1=P3^0;
sbit sw2=P3^1;
sbit sw3=P3^2;
sbit key_ew=P3^3;
sbit key_sn=P3^4;
sbit BZ=P3^5;
uchar TH,TL;
uchar SN=30,EW=25,NN=60;
uint tt,ii,jj,kk;
uchar code DisCode[]
={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar Disbuff0[2];
uchar Disbuff1[2];
void Delay(uint x)//MS延時(shí)
uchar i;
while(x--)for(i=0;i<123;i++);
void init()
TMOD=0x01;
TH=(65536-4000)/256,
TL=(65536-4000)%256;
TH0=TH;
TL0=TL;
EA=1;
ET0=1;
TR0=1;
void fenli0()
Disbuff0[0]=SN/10;
Disbuff0[1]=SN%10;
void fenli1()
Disbuff1[0]=EW/10;
Disbuff1[1]=EW%10;
void Display()
uchar ii;
if(ii==0)
P0=0x80;
P2=0x80;
P2=DisCode[Disbuff0[0]]|0x80;
P0=DisCode[Disbuff1[0]]&0x7f;
P0=0x80;
P2=0x80;
P2=DisCode[Disbuff0[1]]&0x7f;
P0=DisCode[Disbuff1[1]]|0x80;
ii=~ii;
void fuzhi()//賦值
if(NN==60)
SN=30;
EW=25;
P1=0x5E;
if(EW==0&&NN==35)
EW=5;
P1=0x6E;
if(NN==30)
SN=25;
EW=30;
P1=0xB3;
if(SN==0&&NN==5)
SN=5;
P1=0xB5;
void LED()//LED
if(NN<=40&&NN>35)//
if(kk)
P1=0x5E;
else P1=0xfE;
if(NN<=35&&NN>30)
if(kk)
P1=0x6E;
else P1=0xEE;
if(NN<=10&&NN>5)
if(kk)
P1=0xB3;
else P1=0xF7;
if(NN<=5)
if(kk)
P1=0xB5;
else P1=0xF5;
void qiangzhi_sw()//強(qiáng)制通行
if(key_ew==0)
TR0=0;
P0=0x3f;
P2=0x3f;
P1=0x5e;
while(!key_ew);
TR0=1;
if(key_sn==0)
TR0=0;
P0=0x3f;
P2=0x3f;
P1=0xb3;
while(!key_sn);
TR0=1;
void key1()//調(diào)時(shí)
uchar m=0,num=0,n=0;
uchar sw11,sw22=1,sw33=1;
if(sw1==0)
Delay(10);
if(sw1==0)
while(!sw1);
num++;
TR0=0;
while(!m)
if(n==1)
if(sw11==1&&sw1==0)
Delay(10);
if(sw11==1&&sw1==0)
num++;
if(num==3)
while(!sw1);
sw11=sw1;
n=1;
Delay(3);
switch (num)
case 1:
if(sw22==1&&sw2==0)
SN++;
EW++;
if(EW==100)
EW=5;
SN=0;
if(SN==100)
SN=5;
EW=0;
fenli0();
fenli1();
sw22=sw2;
if(sw33==1&&sw3==0)
SN--;
EW--;
if(EW==255)
EW=94;
SN=99;
if(SN==255)
SN=94;
EW=99;
fenli0();
fenli1();
sw33=sw3;
Display();
} break;
case 2:
TR0=1;
m=1;
while(!sw1);
Delay(5);
while(!sw1);
} break;
init();
fenli0();
fenli1();
qiangzhi_sw();
key1();
void timer0() interrupt 1
TH0=TH;
TL0=TL;
tt++;
jj++;
if(tt==250)
tt=0;
fuzhi();
EW--;
SN--;
if(SN==30)
NN=61;
if(EW==30)
NN=30;
if(EW<30||SN<30)
NN--;
if(NN==0)
NN=60;
fenli0();
fenli1();
Display();
LED();
if(jj==50)
jj=0;
kk=~kk;
