查看: 1800|回復: 1
單片機flash掉電存不了數(shù)據(jù),麻煩指導一下哪里有問題
ID:941265 發(fā)表于 2022-5-25 14:54 | 顯示全部樓層 |閱讀模式
各位大佬幫忙看下,謝謝大家
void SaveAllPar(void)
      uint i;
          u8 tempd;
          i=EEPROM_BASE_ADDRESS;
          FSCMD=0;
          LOCK  = CMD_DATA_AREA_UNLOCK;
         for(i=EEPROM_BASE_ADDRESS;i<EEPROM_BASE_ADDRESS+32;i++)
                  PTSH = (unsigned char)(i>>8);
            PTSL = (unsigned char)i;
            FSCMD = CMD_DATA_AREA_READ;
                tempd=FSDAT;
                FSCMD = 0;
            if( tempd== 0xFF)
        break;
  if(i==EEPROM_BASE_ADDRESS+32)
           PTSH = 0;
           PTSL = 0;
           FSCMD = CMD_DATA_AREA_ERASE_PAGE;
           i =EEPROM_BASE_ADDRESS;
          FSCMD = 0;
          FSCMD = CMD_DATA_AREA_WIRTE_PAGE;
          FSDAT = dim_data;
          FSDAT = up_flag;
            FSCMD = 0;
          LOCK  = CMD_FLASH_LOCK;
void LoadAllPar(void)
    uint i;
    u8 tempd;
    FSCMD = 0;
                tempd=FSDAT;
                FSCMD = 0;
            if(tempd==0xFF)
        break;
  if(i==EEPROM_BASE_ADDRESS)
    dim_data=255;
    up_flag=0;
             i--;
             FSCMD = 0;
             PTSH =(unsigned char)(i>>8);
             dim_data= FSDAT;
             up_flag=FSDAT;
             FSCMD = 0;
ID:743992 發(fā)表于 2022-5-25 22:31 | 顯示全部樓層
大概率是數(shù)據(jù)沒寫進去,不是掉電的問題
寫之前一定要先擦,確保寫入的背景是空白的,所有數(shù)據(jù)都能正常寫入;
擦、寫完了之后要讀一遍,確保真的寫進去了;
有的單片機可能有flash加密,擦除完之后獨到的可能不是全F(一般是安全類的芯片),但寫入數(shù)據(jù)之后一定要讀一遍。
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
