查看: 2800|回復: 14
請教如何利用P30按鍵的長按來操作51單片機芯片內(nèi)的EEPROM,讓a得到8至20間的數(shù)
ID:334440 發(fā)表于 2022-5-25 01:21 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*   d1-p31,d2-p32,d3-p33,d4-p34
a-P10,b-P11,c-P12,d-P13,e-P14,f-P15,g-P16,dp-P17
12v to in1 to p37(IN)......P35 is out......P30 is OUT2 */
#include <stc12c20xx.h>
#include <intrins.h>
#define FOSC 11059200L
#define T1MS (FOSC/12-1000)
uint a,b,c;
uchar code table[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
void  cc(uint addr);
void  xcx(uint addr,uchar dat);
uchar dcx(uint addr);
void  Q0();
void delay(uint i)
  uint j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display()
   P1=table[a%10000/1000];
   P31 = 0;
   delay(5);
   P31 = 1;
   P1=table[a%1000/100];
   P32 = 0;
   delay(5);
   P32 = 1;
   P1=table[a%100/10];
   P33 = 0;
   delay(5);
   P33 = 1;
   P1=table[a%10];
   P34 = 0;
   delay(5);
   P34 = 1;
void Timer_Init(void)
          AUXR &= 0x3F;//00111111
           TMOD = 0x11;
          TL1 = T1MS;
          TH1 = T1MS>>8;
          TF1 = 0;
          ET1 = 1;
void main(void)
        P1M0 = 0x00;
        P1M1 = 0x00;
  P3M1 = 0x00;
        P3M0 = 0x20;      //00100000
  a=0;
  b=0;
  P35=0;
        c = dcx(0x2002);
  Timer_Init();
                if((P37==1)&&(P30==0))
                        delay(5);
                                if(c<8){c==8;cc(0x2000);xcx(0x2002,c);}else;
                                if(c>20){c==8;cc(0x2000);xcx(0x2002,c);}else;
                                EA=1;
                                TR1=1;
                         }else;
                 }else;
void cc(uint addr)
// 0x83(??<5M)   0x82(??<10M)   0x81(??<20M)   0x80(??<40M)
    ISP_CONTR = 0x81;
    ISP_CMD   = 0x03;
    ISP_ADDRL = addr;
    ISP_ADDRH = addr>>8;
          EA =0;
    ISP_TRIG = 0x46;
    ISP_TRIG = 0xB9;
    _nop_();
    Q0();
    ISP_CONTR = 0x81;
    ISP_CMD   = 0x02;
    ISP_ADDRL = addr;
    ISP_DATA  = dat;
    EA = 0;
    ISP_TRIG = 0x46;
    ISP_TRIG = 0xB9;
    _nop_();
    Q0();
    uchar dat;
          ISP_CONTR = 0x81;
    ISP_CMD   = 0x01;
    ISP_ADDRL = addr;
    EA = 0;
    ISP_TRIG = 0x46;
    ISP_TRIG = 0xB9;
    _nop_();
    dat = ISP_DATA;
        Q0();
        return dat;
void Q0()
    ISP_CONTR = 0;
    ISP_CMD   = 0;
    ISP_TRIG  = 0;
void t1(void) interrupt 3 using 2
        TL1=T1MS;
        TH1=T1MS>>8;
        b++;
        a=c;
  display();
    if(b>=1000)
                 b=0;
           c++;
                 if(c>20)c=8;else ;
  if(P30==1){delay(5);if(P30==1){a=0;TR1=0;}else;}else ;
ID:334440 發(fā)表于 2022-5-25 07:43 | 只看該作者
剛驗證了一下,是可以用了,把T1MS改為常數(shù)64536穩(wěn)定一些
ID:230742 發(fā)表于 2022-5-25 12:23 | 只看該作者
隨機數(shù)產(chǎn)生了!恭喜恭喜。
ID:334440 發(fā)表于 2022-5-26 05:57 來自觸屏版 | 只看該作者
啤酒瓶子老大 發(fā)表于 2022-5-25 12:23
可以指點一下嗎
ID:161164 發(fā)表于 2022-5-26 10:40 來自觸屏版 | 只看該作者
看不懂你的提問,a和EEProm有啥關(guān)系?
ID:334440 發(fā)表于 2022-5-26 12:24 | 只看該作者
lkc8210 發(fā)表于 2022-5-26 10:40
需要8至20的常數(shù)作另外的代碼運算,EEPROM可以記錄這個數(shù),P30用來修改這個數(shù),不修改的話,就是一個固定值,賦值給a
ID:624769 發(fā)表于 2022-5-26 13:10 來自觸屏版 | 只看該作者
if(c<8){c==8;cc(0x2000);xcx(0x2002,c);} 這個病句,就沒人看出來么?
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:230742 發(fā)表于 2022-5-26 14:59 | 只看該作者
我也不會。
我只是一個愛好者。
超級喜歡單片機而已。
ID:334440 發(fā)表于 2022-5-26 22:44 來自觸屏版 | 只看該作者
188610329 發(fā)表于 2022-5-26 13:10
if(c
如果讀到的c小于8,則賦值8,并擦除扇區(qū),重新寫入c的值,以備取用
ID:624769 發(fā)表于 2022-5-26 22:58 | 只看該作者
onetwoto 發(fā)表于 2022-5-26 22:44
你說的如此理直氣壯,倒是弄得我不自信了……
不如大家投票吧……
問題: 給 c 賦值 8 應該用以下哪個語句?
A)   c =  8;
B)   c == 8;
答:
ID:161164 發(fā)表于 2022-5-26 23:44 來自觸屏版 | 只看該作者
onetwoto 發(fā)表于 2022-5-26 12:24
需要8至20的常數(shù)作另外的代碼運算,EEPROM可以記錄這個數(shù),P30用來修改這個數(shù),不修改的話,就是一個固定 ...
但看你的代碼,c是隨時間由8增加到20又變回8啊?
根本不固定
而且P30==1 是按下還是沒按下?
代碼頭幾行注釋P30是Out, 所以P30是輸入還是輸出?
P37==1 && P30==0 又是哪個鍵按下?
ID:334440 發(fā)表于 2022-5-27 07:09 來自觸屏版 | 只看該作者
188610329 發(fā)表于 2022-5-26 22:58
不如大家投票吧……
抱歉抱歉,我不是理直氣壯,我是業(yè)余學習,時間比較緊,語言不到之處請見諒,賦值是c=8;
ID:334440 發(fā)表于 2022-5-27 07:13 來自觸屏版 | 只看該作者
lkc8210 發(fā)表于 2022-5-26 23:44
根本不固定
而且P30==1 是按下還是沒按下?
1.是要求c必須是8至20間的數(shù),如果小于8或大于20就不行。2.常規(guī)stc的設(shè)計,等于0的都表示按下了,等于1的都表示松開,p30在這里用按鍵輸入
ID:161164 發(fā)表于 2022-5-27 10:22 | 只看該作者
onetwoto 發(fā)表于 2022-5-27 07:13
1.是要求c必須是8至20間的數(shù),如果小于8或大于20就不行。2.常規(guī)stc的設(shè)計,等于0的都表示按下了,等于1的 ...
終于弄明白你這憋扭的代碼
0
上電
讀取EEProm,放到C
初始化定時器但不運行
1
P30按下,消抖,檢驗C值,寫入EEProm,運行定時器
2
1ms后,定時器中斷,d++,把C值放到A,輸出數(shù)碼管
1ms后,重復2
5ms后,重復1
3
P30放開,停止定時器
4
P30不放開,直到d大于1000(1s)
d清零,c++,然后檢查是否大于零
這就是你的長按改變c的運行流程
這代碼最大的問題是每次長按EEProm都會擦寫200次
不知道這c值會不會經(jīng)常改變
不然號稱10萬次擦寫壽命的EEProm只能定的住5000次長按
ID:334440 發(fā)表于 2022-5-27 22:48 來自觸屏版 | 只看該作者
lkc8210 發(fā)表于 2022-5-27 10:22
終于弄明白你這憋扭的代碼
0
上電
很感激你能讀透我的思路,看樣子我這代表碼問題嚴重,實現(xiàn)不了這個功能了嗎
