查看: 2195|回復: 2
為啥我的單片機循跡小車程序燒錄進去之后不能循跡啊 就一直按著直線走?
ID:1029445 發表于 2022-5-24 23:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
幫忙看看謝謝大家
#include <reg52.h>#define uint unsigned int
sbit IN11=P1^6;    //左前輪
sbit IN12=P1^7;
sbit IN13=P1^4;     //右前輪
sbit IN14=P1^5;
sbit IN21=P1^0;     // 左后輪
sbit IN22=P1^1;
sbit IN23=P1^2;     //右后輪
sbit IN24=P1^3;
sbit S1=P0^3;       //速度
sbit S2=P0^2;
sbit S3=P0^1;
sbit S4=P0^0;
sbit D1=P2^3;       //循跡
sbit D2=P2^2;
sbit D3=P2^1;
sbit D4=P2^0;
uchar counter,compare;
void a ()          //左輪前進
  IN11=1;
  IN12=0;
        IN21=1;
        IN22=0;
void aa ()          //左輪后退
  IN11=0;
  IN12=1;
        IN21=0;
        IN22=1;
void b ()
        IN13=0;     //右輪前進
  IN14=1;
        IN23=0;
        IN24=1;
void bb ()
        IN13=1;     //右輪后退
  IN14=0;
        IN23=1;
        IN24=0;
void car_stop ()     //停止
        IN11=1;
        IN12=1;
        IN13=1;
        IN14=1;
        IN21=1;
  IN22=1;
        IN23=1;
        IN24=1;
void Timer0_Init()                //100微秒@11.0592MHz
        TMOD &= 0xF0;                //設置定時器模式
        TMOD |= 0x01;                //設置定時器模式
        TL0 = 0xA4;                //設置定時初始值
        TH0 = 0xFF;                //設置定時初始值
        TF0 = 0;                //清除TF0標志
        TR0 = 1;                //定時器0開始計時
        ET0=1;      //定時器0中斷允許開關
        EA=1;      //定時器總開關
        PT0=0;    //定時器0中斷優先級
void Timer0_Routine() interrupt 1 //中斷函數
        TL0 = 0xA4;
        TH0 = 0xFF;
  compare=6;
        counter++;
        if(counter>=20)
                counter=0;
  if(counter<compare)
          S1=1;
          S2=1;
          S3=1;
          S4=1;
          S1=0;
          S2=0;
          S3=0;
          S4=0;
void car_go()   //小車向前
        compare=5;
        a();
        b();
void car_back()//小車向后
  compare=5;
        aa();
  bb();
void car_leftgo()//左拐
        compare=5;
        aa();
        b();
void car_rightgo()  //右拐
        compare=5;
  a();
  bb();
void delayms (uint x)
        int i,j;
        for(i=x;i>0;i--)
  for(j=110;j>0;j--);
void xunji ()
if(D1==1&&D2==1&&D3==1&&D4==1)  //全檢測到黑線
   car_go ();
if(D1==0&&D2==1&&D3==0&&D4==0)  //中間右側檢測到黑線,小車偏左,小車向右移動
  car_rightgo ();
  if(D1==0&&D2==0&&D3==0&&D4==0)
          car_go ();
if(D1==0&&D2==0&&D3==1&&D4==0)  //中間左側檢測到黑線,小車偏右,小車向左移動
  car_leftgo ();
          car_go ();
if(D1==0&&D2==0&&D3==1&&D4==1)  //直角左拐
  car_go ();
  delayms(500);
   car_stop();
   delayms(500);
   car_leftgo ();
if(D1==1&&D2==1&&D3==0&&D4==0)  //直角右拐
  car_go ();
  delayms(500);
   car_stop();
   delayms(500);
   car_rightgo ();
if((D1==0&&D2==0&&D3==0&&D4==1)||(D1==0&&D2==1&&D3==0&&D4==1)||(D1==0&&D2==1&&D3==1&&D4==1))  //銳角左拐
  car_go ();
  delayms(500);
  delayms(500);
   car_stop();
   delayms(500);
   car_leftgo();
if((D1==1&&D2==0&&D3==0&&D4==0)||(D1==1&&D2==0&&D3==1&&D4==0)||(D1==1&&D2==1&&D3==1&&D4==0))  //銳角右拐
  car_go ();
  delayms(500);
  delayms(500);
   car_stop();
   delayms(500);
   car_rightgo();
if(D1==0&&D2==1&&D3==1&&D4==0)
   car_go();
void main ()
Timer0_Init();
car_go ();
while (1)
   xunji ();
ID:844772 發表于 2022-5-25 09:39 | 只看該作者
1.調整好紅外模塊,基本每次上場都要調的。
2.確認你模塊邏輯,你程序認為在黑線上是1,平時是0,確認一下是不是真這樣?
3.循跡程序有問題,發現黑線后,車轉向需要時間,可能會有一個過線的情況,你馬上跟了判斷全白的程序,來不及執行轉向就收到直行命令了。建議你先做簡單判斷尋線程序,成功后再逐步增加特殊情況。
ID:979299 發表于 2022-5-25 11:48 | 只看該作者
程序看上去沒什么問題,只有倒車函數未調用,檢查硬件正常工作了沒有,有沒有插錯,接反和損壞之類的
