查看: 1664|回復: 2
這種程序錯誤應該怎么改啊
ID:1027558 發表于 2022-5-20 12:05 | 顯示全部樓層 |閱讀模式
本帖最后由 3458227407 于 2022-5-20 12:49 編輯
#include<reg52.h>
#define ui unsigned int
#define uc unsigned char
sbit SET=P3^1;
sbit DEC=P3^2;
sbit ADD=P3^3;
sbit BEEP=P3^6;
sbit ALAM=P1^2;
sbit DQ =P3^7;
sbit SCL=P1^6;
sbit SDA=P1^7;
sbit DIAN=P0^5;
bit bdata shanshuo_st;
bit bdata beep_st;
uc x=0;
ui bai,shi,ge;
uc set_st=0;
char shangxian,xiaxian;
//uc code
LEDData[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};
uc code
LEDData[]={0x5F,0x44,0x9D,0xD5,0xC6,0xD3,0xDB,0x47,0xDF,0xD7,0xCF,0xDA,0
x9B,0xDC,0x9B,0x8B};
//====================================DS18B20===================
void Delay_DS18B20(int num)
while(num--) ;
void delay()
void start()
SDA=1;
delay();
SCL=1;
delay();
SDA=0
delay()
void stop()
SDA=0;
delay();
SCL=1;
delay();
SDA=1
delay()
void respons()
uc i;
SCL=1;
delay();
while((SDA==1)&&(i<250))i++;
SCL=0;
delay();
void init24c04()
SDA=1;
delay();
SCL=1;
delay();
void write_byte(uc date)
uc i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
SCL=0;
delay();
SDA=CY;
delay();
SCL=1;
delay();
SCL=0;
delay();
SDA=1;
delay();
uc read_byte()
uc i,k;
SCL=0;
delay();
SDA=1;
delay();
for(i=0;i<8;i++)
SCL=1;
delay();
k=(k<<1)|SDA;
SCL=0;
delay();
return k;
void write_add(uc address,uc date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uc read_add(uc address)
uc date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
void Init_DS18B20(void)
uc w=0;
DQ = 1;
Delay_DS18B20(8);
DQ = 0;
Delay_DS18B20(78);
DQ = 1;
Delay_DS18B20(14);
w = DQ;
Delay_DS18B20(20);
unsigned char ReadOneChar(void)
uc i=0;
uc dat = 0;
for (i=8;i>0;i--)
DQ = 0;
dat>>=1;
DQ = 1;
if(DQ)
dat|=0x80;
Delay_DS18B20(4);
return(dat);
void WriteOneChar(uc dat)
uc i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
Delay_DS18B20(5);
DQ = 1;
dat>>=1;
ui ReadTemperature(void)
ui b=0;
ui t=0;
ui a=0;
float tt=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
t=b;
t<<=8;
t=t|a;
tt=t*0.0625;
t=tt*10+0.5;
return(t);
void Delay(ui num)
while( --num );
void InitTimer(void)
TMOD=0x01;
TH0=0x3c;
TL0=0xb0;
void check_wendu(void)
ui f;
f=ReadTemperature()-5;
if(f<0)f=0;
if(f>999)f=999;
bai=f/100;
shi=(f%100)/10;
ge=(f%100)%10;
void Disp_init(void)
P0 = ~0x80;
P2 = 0x7F;
Delay(200);
P2 = 0xDF;
Delay(200);
P2 = 0xF7;
Delay(200);
P2 = 0xFD;
Delay(200);
P2 = 0xFF;
void Disp_Temperature(void)
P0 = ~0x98;
P2 = 0x7F;
Delay(400);
P2 = 0xff;
P0=~LEDData[ge];
P2 = 0xDF;
Delay(400);
P2 = 0xff;
P0 =~LEDData[shi];
DIAN = 0;
P2 = 0xF7;
Delay(400);
P2 = 0xff;
P0 =~LEDData[bai];
P2 = 0xFD;
Delay(400);
P2 = 0xff;
void Disp_alarm(uc baojing)
P0 =~0x98;
P2 = 0x7F; //01111111
Delay(200);
P2 = 0xff;
P0 =~LEDData[baojing%10];
P2 = 0xDF; //1101
Delay(200);
P2 = 0xff;
P0 =~LEDData[baojing/10];
P2 = 0xF7; //11110111
Delay(200);
P2 = 0xff;
if(set_st==1)P0 =~0xCE;
else if(set_st==2)P0 =~0x1A;
P2 = 0xFD;
Delay(200);
P2 = 0xff;
void Alarm()
if(x>=10){beep_st=~beep_st;x=0;}
if((((bai*10+shi)>=shangxian)||((bai*10+shi)<xiaxian))&&beep_st==1)
BEEP=0;
ALAM=0;
else if((((bai*10+shi)>=shangxian)||((bai*10+shi)<xiaxian))&&beep_st==0)
BEEP=1;
ALAM=1;
else if(((bai*10+shi)<shangxian)&&((bai*10+shi)>=xiaxian))
BEEP=1;
ALAM=1;
void main(void)
ui z;
InitTimer();
EA=1;
TR0=1;
ET0=1;
check_wendu();
check_wendu();
shangxian=read_add(10);
xiaxian=read_add(20);
for(z=0;z<300;z++)
Disp_init();
if(SET==0)
Delay(2000);
do{}
while(SET==0);
set_st++;x=0;shanshuo_st=1;
if(set_st>2)set_st=0;
if(set_st==0)
check_wendu();
Disp_Temperature();
Alarm();
else if(set_st==1)
BEEP=1;
ALAM=1;
if(x>=10){shanshuo_st=~shanshuo_st;x=0;}
if(shanshuo_st) {Disp_alarm(shangxian);}
if(ADD==0)
do{Disp_alarm(shangxian);}
while(ADD==0);
shangxian++;
if(shangxian>99)shangxian=99;
write_add(10,shangxian);
else if(DEC==0)
while(DEC==0);
shangxian--;
if(shangxian<xiaxian) shangxian=xiaxian;
else if(set_st==2)
BEEP=1;
ALAM=1;
if(shanshuo_st) {Disp_alarm(xiaxian);}
if(ADD==0)
do{Disp_alarm(xiaxian);}
while(ADD==0);
xiaxian++;
if(xiaxian>shangxian) xiaxian=shangxian;
write_add(20,xiaxian);
else if(DEC==0)
while(DEC==0);
xiaxian--;
if(xiaxian<0) xiaxian=0;
void timer0(void) interrupt 1
TH0=0x3c;
TL0=0xb0;
x++;
程序(60): error C141: syntax error near '<', expected ')'
程序(60): error C129: missing ';' before '++'
ID:883242 發表于 2022-5-20 15:04 | 顯示全部樓層
少了個分號。
ID:94031 發表于 2022-5-20 17:06 | 顯示全部樓層
主要是換行,缺分號,復制程序還有換行問題,索性發工程給你,自己對照找錯誤。 測試.rar (37.27 KB, 下載次數: 2)
