查看: 1779|回復: 2
11.c(55): error C141: syntax error near 'unsigned', expected '__asm'請問應該...
ID:1026843 發表于 2022-5-15 22:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#define SNAKE 20                //????
#define TIME 50                 //??????
#define SPEED 71                //????
//#define keyenable 1
sbit keyenable=P3^6;           //????
/*sbit keyx=Po^1;              /??
sbit keyy=po2;                 //?? */
//sbit up=P6^0;
sbit up=P3^3;                  //down
sbit down=P3^1;
sbit right=P3^2;
sbit left=P3^4;
uchar x[SNAKE+1];
uchar y[SNAKE+1];
uchar time,n,i,e;              //????,????,??????,????
char addx,addy;                //?????
void delay(char MS)
char us,usn;
while(MS!=0)
usn = 0;
while(usn!=0)
us=0xff;
while(us!=0){us--;};
usn--;
MS--;
void turnkey()         // interrupt 0 using 2
{//up=1;
if(keyenable)
if(left){addy=0;if(addx!=1)addx=-1; else addx=1;}
if(right){addy=0;if(addx!=-1)addx=1; else addx=-1;}
if(up){addx=0;if(addy!=-1)addy=1; else addy=-1;}
if(down){addx=0;if(addy!=1)addy=-1; else addy=1;}
uchar mux(uchar temp)
if(temp==7)return 128;
if(temp==6)return 64;
if(temp==5)return 32;
if(temp==4)return 16;
if(temp==3)return 8;
if(temp==2)return 4;
if(temp==1)return 2;
if(temp==0)return 1;
return 0;
void timer0(uchar k)
{while(k--)
{for(i=0;i<SNAKE+1;i++)
{P2=mux(x[i]);P1=255-mux(y[i]);
turnkey();
delay(TIME);
P2=0x00;P1=0xff;
void main(void)
{e=SPEED;
P5=0x00;
P1=0xff;
P2=0x00;
P3=0x00;
{//if(keyenable==1){P1=0x00;P2=0xff;}else(P1=0xff;P2=0x00;}
for(i=3;i<SNAKE+1;i++)x[i]=100;for(i=3;i<SNAKE+1;i++)y[i]=100;   //???
x[0]=4;y[0]=4;           //??
n=3;                     //?? n=-1
x[1]=1;y[1]=0;          //??
x[2]=0;y[2]=0;         //??1
addx=0;addy=0;         //????
//k=1;
while(1){if(keyenable)break;timer0(1);}
{timer(e);
if(knock()){e=SPEED;break;}                      //????
if((x[0]==x[1]+addx)&(y[0]==y[1]+addy))          //?????
{n++;
if(n==SNAKE+1)
{n=3;e=e-10;
x[0]=x[n-2];
y[0]=y[n-2];
for(i=n-1;i>1;i--){x[i]=x[i-1];y[i]=y[i-1];}            //x[n-1]=x[2];y[n-1]=y[2];
x[1]=x[2]+addx;y[1]=y[2]+addy; //??
ID:155507 發表于 2022-5-16 01:21 | 只看該作者
給你改了,對比一下就知道哪里錯了。
  1. #include <reg51.h>
  2. #include <string.h>
  3. #include <stdlib.h>
  4. #include <stdio.h>
  5. #define uchar unsigned char
  6. #define SNAKE 20                //????
  7. #define TIME 50                 //??????
  8. #define SPEED 71                //????
  9. //#define keyenable 1
  10. sbit keyenable=P3^6;           //????
  11. /*sbit keyx=Po^1;              /??
  12. sbit keyy=po2;                 //?? */
  13. //sbit up=P6^0;
  14. sbit up=P3^3;                  //down
  15. sbit down=P3^1;
  16. sbit right=P3^2;
  17. sbit left=P3^4;
  18. uchar x[SNAKE+1];
  19. uchar y[SNAKE+1];
  20. uchar time,n,i,e;              //????,????,??????,????
  21. char addx,addy;                //?????
  22. /*****************
  23. ????
  24. ****************/
  25. void delay(char MS)
  26. {
  27.         char us,usn;
  28.         while(MS!=0)
  29.         {
  30.                 usn = 0;
  31.                 while(usn!=0)
  32.                 {
  33.                         us=0xff;
  34.                         while(us!=0){us--;};
  35.                         usn--;
  36.                 }
  37.                 MS--;
  38.         }
  39. }
  40. /******************************************
  41. ????????
  42. ************************/
  43. void turnkey()         // interrupt 0 using 2
  44. {//up=1;
  45.         if(keyenable)
  46.         {
  47.                 if(left){addy=0;if(addx!=1)addx=-1; else addx=1;}
  48.                 if(right){addy=0;if(addx!=-1)addx=1; else addx=-1;}
  49.                 if(up){addx=0;if(addy!=-1)addy=1; else addy=-1;}
  50.                 if(down){addx=0;if(addy!=1)addy=-1; else addy=1;}
  51.         } //<----------------這里缺少
  52. } //<----------------這里缺少
  53. uchar mux(uchar temp)
  54. {
  55.         if(temp==7)return 128;
  56.         if(temp==6)return 64;
  57.         if(temp==5)return 32;
  58.         if(temp==4)return 16;
  59.         if(temp==3)return 8;
  60.         if(temp==2)return 4;
  61.         if(temp==1)return 2;
  62.         if(temp==0)return 1;
  63.         return 0;
  64. }
  65. void timer0(uchar k)
  66. {while(k--)
  67.         {for(i=0;i<SNAKE+1;i++)
  68.                 {P2=mux(x[i]);P1=255-mux(y[i]);
  69.                         turnkey();
  70.                         delay(TIME);
  71.                         P2=0x00;P1=0xff;
  72.                 }
  73.         }
  74. }
  75. void main(void)
  76. {e=SPEED;
  77.         P5=0x00;
  78.         P1=0xff;
  79.         P2=0x00;
  80.         P3=0x00;
  81.         while(1)
  82.         {//if(keyenable==1){P1=0x00;P2=0xff;}else(P1=0xff;P2=0x00;}
  83.                 for(i=3;i<SNAKE+1;i++)x[i]=100;for(i=3;i<SNAKE+1;i++)y[i]=100;   //???
  84.                 x[0]=4;y[0]=4;           //??
  85.                 n=3;                     //?? n=-1
  86.                 x[1]=1;y[1]=0;          //??
  87.                 x[2]=0;y[2]=0;         //??1
  88.                 addx=0;addy=0;         //????
  89.                 //k=1;
  90.                 while(1){if(keyenable)break;timer0(1);}
  91.                 while(1)
  92.                 {timer(e);
  93.                         if(knock()){e=SPEED;break;}                      //????
  94.                         if((x[0]==x[1]+addx)&(y[0]==y[1]+addy))          //?????
  95.                         {n++;
  96.                                 if(n==SNAKE+1)
  97.                                 {n=3;e=e-10;
  98.                                         for(i=3;i<SNAKE+1;i++)x[i]=100;
  99.                                         for(i=3;i<SNAKE+1;i++)y[i]=100;
  100.                                 }
  101.                                 x[0]=x[n-2];
  102.                                 y[0]=y[n-2];
  103.                         }
  104.                         for(i=n-1;i>1;i--){x[i]=x[i-1];y[i]=y[i-1];}            //x[n-1]=x[2];y[n-1]=y[2];
  105.                         x[1]=x[2]+addx;y[1]=y[2]+addy; //??
  106.                 }
  107.         }
  108. }
ID:1012735 發表于 2022-5-16 03:24 | 只看該作者
turnkey()函數結尾差兩右大括號!
代碼太亂了也不知道整理一個格式
寫了這么長的代碼,肯定也不是你的作品
出錯信息已告訴你55行錯誤,你應該在55行找為什么在此報錯
