查看: 1329|回復: 4
單片機信號發生器程序 主函數文件有幾個疑問,求大佬看看
回帖獎勵 100 黑幣 回復本帖可獲得 10 黑幣獎勵! 每人限 1 次
ID:941176 發表于 2022-5-7 16:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
以上是主程序,問題放在了程序中,還請大家幫忙看看
#include "reg51.H"
#include "ad9834.h"
#include "LCD1602.h"
#include "keyScan.h"
#define  MAX_VOLT   47   //為啥47代表4.7V
//sbit LED = P0^0;
//sbit key1 = P1^2;
//sbit key2 = P1^3;
//sbit key3 = P1^4;
//sbit key4 = P1^5;
//sbit key5 = P1^6;
//sbit FSK = P3^6;
*        函 數 名: DelayMs
*        功能說明: 時鐘延時
*        形    參: ms 以毫秒為單位.
*        返 回 值: 無
void DelayMs( unsigned int ms)
        unsigned int i,j;
        for (i = 0; i < ms; i++)
                for(j=0;j<1000;j++);        //單片機晶振12MHZ,j是隨便取嗎
        unsigned long FreqData=20000;
  unsigned int volt=MAX_VOLT;
                unsigned int ratio;
        unsigned char AmpData=255;        //不懂這兩行,255是啥
        unsigned char WaveModle=0;
        unsigned char  keyNum = 16;
        unsigned char SetFreq_flag=0;//設置頻率的標志
        ratio=2550/MAX_VOLT;// 5.7= 255/47; ratio放大10倍了取整數, 44最高輸出4.7V
   InitLCD();
   DelayMs( 100);
   DispStrAt("AD9834", 0, 0);
         DispStrAt("sinWave", 8, 0);
          DispDecSpaceAt(FreqData, 0, 1, 7);DispStrAt("HZ", 7, 1);        //0,1,7的0是啥
    AD9834_WaveSeting(FreqData,0,SIN_WAVE,0 );//2KHz,        頻率寄存器0,正弦波輸出 ,初相位0
    AD9834_AmpSet(AmpData);        //設置幅值,幅值最大 255
           DispStrAt("am   V", 10, 1);
                 DispDecShiftAt(volt, 12, 1, 1);
          keyNum = keyScan();
    if(keyNum!=16)
                        if(SetFreq_flag==0) //不是鍵盤輸入設置頻率狀態, 步進設置狀態
                                                if(keyNum==10 && SetFreq_flag==0)
                                                        SetFreq_flag=1;
                                                        FreqData=0;
                                                        DispDecSpaceAt(FreqData, 0, 1, 7);DispStrAt("  ", 7, 1);
                                                        //AD9833_WaveSeting(FreqData,0,SIN_WAVE,0 );
                                        if(keyNum==12)
                                                FreqData=FreqData+1000;
                                                AD9834_WaveSeting(FreqData,0,WaveModle,0 );
                                                //while(key1==0);
                                 else if(keyNum==13)
                                                if(FreqData>=1000)
                                                FreqData=FreqData-1000;
                                                //while(key2==0);
                                 else if(keyNum==14)
                                                if(volt<MAX_VOLT)
                                                volt=volt+1;
                                                AmpData=volt*ratio/10;
                                                //DispDecSpaceAt(AmpData, 13, 1, 3);
                                                //while(key3==0);
                                 else if(keyNum==15)
                                                        if(volt>0)
                                                        volt=volt-1;
                                                        //while(key4==0);
                                 else if(keyNum==11)
                                         WaveModle=WaveModle+1;
                                         if(WaveModle==3)WaveModle=0;
                                         if(WaveModle==0){AD9834_WaveSeting(FreqData,0,SIN_WAVE,0 );DispStrAt("sinWave", 8, 0);}
                                         else if(WaveModle==1){AD9834_WaveSeting(FreqData,0,TRI_WAVE,0 );DispStrAt("TriWave", 8, 0);}
                                         else if(WaveModle==2){AD9834_WaveSeting(FreqData,0,SQU_WAVE,0 );DispStrAt("SquWave", 8, 0);}
                                         //else if(WaveModle==3){AD9834_SetFSK(1000,5000);DispStrAt("FSKWave", 8, 0);}
                                         //else if(WaveModle==4){AD9834_SetPSK(0,180,5000);DispStrAt("PSKWave", 8, 0);}
                                                //while(key5==0);
                                 else if(SetFreq_flag==1) //是矩陣鍵盤輸入設置頻率狀態
                                                if(keyNum<10)//輸入頻率
                                                        FreqData=FreqData*10+keyNum;
                                                else if(keyNum==15)//輸錯倒退
                                                        FreqData=FreqData/10;
                                                        DispDecSpaceAt(FreqData, 0, 1,7);
                                                else if(keyNum==10)//HZ確定輸出
                                                        SetFreq_flag=0;
                                                else if(keyNum==11)////KHZ確定輸出
                                                        DispDecSpaceAt(FreqData, 0, 1, 6);DispStrAt("KHZ", 6, 1);
                                                        FreqData=FreqData*1000;
                                                        SetFreq_flag=0;
                                                else if(keyNum==12)////MHZ確定輸出
                                                        DispDecSpaceAt(FreqData, 0, 1, 6);DispStrAt("MHZ", 6, 1);
                                                        FreqData=FreqData*1000000;
                                                        SetFreq_flag=0;
ID:121859 發表于 2022-5-7 17:27 | 只看該作者
那個255,就是最大幅值呀,后面0,1,7的0應該是X坐標。
ID:514254 發表于 2022-5-7 18:36 | 只看該作者
MAX_VOLT是后面計算擴大了10倍
j的取值其實是個估算的,這個延時不夠準確,能用
ID:213173 發表于 2022-5-7 21:17 | 只看該作者
能用整數盡量不用小數。如ADC轉換計算電壓時VCC采用5000mV,顯示時在千位加小數點即可,既方便又精確。
ID:123289 發表于 2022-5-9 14:58 | 只看該作者
遇到此類問題的處理方式:
1、粗略讀通邏輯關系。
2、弄清程序的輸入是什么,程序的目的是什么?
3、如果自己去設計程序,如何架構。
4、試作寫一寫。
估計你會遇到同樣的問題需要解決,這時再回頭看他人的程序,或許理解就深刻了。
