main.c 部分
#include <REGX52.H>
#include "LCD1602.h"
LCD_Init();
LCD_ShowChar(1,1,'n');
LCD1602.H 部分
#ifndef __LCD1602_H__
#define __LCD1602_H__
//用戶調用函數:
void LCD_Init();
void LCD_ShowChar(unsigned char Line,unsigned char Column,char Char);
void LCD_ShowString(unsigned char Line,unsigned char Column,char *String);
void LCD_ShowNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length);
void LCD_ShowSignedNum(unsigned char Line,unsigned char Column,int Number,unsigned char Length);
void LCD_ShowHexNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length);
void LCD_ShowBinNum(unsigned char Line,unsigned char Column,unsigned int Number,unsigned char Length);
#endif
LCD1602.c部分
#include <REGX52.H>
//引腳配置:
sbit LCD_RS=P3^4;
sbit LCD_RW=P3^5;
sbit LCD_EN=P3^6;
#define LCD_DataPort P0
//函數定義:
* @brief LCD1602延時函數,12MHz調用可延時1ms
* @param 無
* @retval 無
void LCD_Delay()
unsigned char i, j;
i = 2;
j = 239;
do
while (--j);
} while (--i);
* @brief LCD1602寫命令
* @param Command 要寫入的命令
* @retval 無
void LCD_WriteCommand(unsigned char Command)
LCD_RS=0;
LCD_RW=0;
LCD_DataPort=Command;
LCD_EN=1;
LCD_Delay();
LCD_EN=0;
LCD_Delay();
* @brief LCD1602寫數據
* @param Data 要寫入的數據
* @retval 無
void LCD_WriteData(unsigned char Data)
LCD_RS=1;
LCD_RW=0;
LCD_DataPort=Data;
LCD_EN=1;
LCD_Delay();
LCD_EN=0;
LCD_Delay();
* @brief LCD1602設置光標位置
* @param Line 行位置,范圍:1~2
* @param Column 列位置,范圍:1~16
* @retval 無
void LCD_SetCursor(unsigned char Line,unsigned char Column)
if(Line==1)
LCD_WriteCommand(0x80|(Column-1));
else if(Line==2)
LCD_WriteCommand(0x80|(Column-1+0x40));
* @brief LCD1602初始化函數
* @param 無
* @retval 無
void LCD_Init()
LCD_WriteCommand(0x38);//八位數據接口,兩行顯示,5*7點陣
LCD_WriteCommand(0x0c);//顯示開,光標關,閃爍關
LCD_WriteCommand(0x06);//數據讀寫操作后,光標自動加一,畫面不動
LCD_WriteCommand(0x01);//光標復位,清屏
* @brief 在LCD1602指定位置上顯示一個字符
* @param Char 要顯示的字符
* @retval 無
LCD_SetCursor(Line,Column);
LCD_WriteData(Char);
* @brief 在LCD1602指定位置開始顯示所給字符串
* @param Line 起始行位置,范圍:1~2
* @param Column 起始列位置,范圍:1~16
* @param String 要顯示的字符串
* @retval 無
unsigned char i;
for(i=0;String[ i]!='\0';i++)
LCD_WriteData(String[ i]);
* @brief 返回值=X的Y次方
int LCD_Pow(int X,int Y)
unsigned char i;
int Result=1;
for(i=0;i<Y;i++)
Result*=X;
return Result;
* @brief 在LCD1602指定位置開始顯示所給數字
* @param Number 要顯示的數字,范圍:0~65535
* @param Length 要顯示數字的長度,范圍:1~5
* @retval 無
unsigned char i;
for(i=Length;i>0;i--)
LCD_WriteData(Number/LCD_Pow(10,i-1)%10+'0');
* @brief 在LCD1602指定位置開始以有符號十進制顯示所給數字
* @param Number 要顯示的數字,范圍:-32768~32767
* @retval 無
unsigned char i;
unsigned int Number1;
if(Number>=0)
LCD_WriteData('+');
Number1=Number;
LCD_WriteData('-');
Number1=-Number;
LCD_WriteData(Number1/LCD_Pow(10,i-1)%10+'0');
* @brief 在LCD1602指定位置開始以十六進制顯示所給數字
* @param Number 要顯示的數字,范圍:0~0xFFFF
* @param Length 要顯示數字的長度,范圍:1~4
* @retval 無
unsigned char i,SingleNumber;
SingleNumber=Number/LCD_Pow(16,i-1)%16;
if(SingleNumber<10)
LCD_WriteData(SingleNumber+'0');
LCD_WriteData(SingleNumber-10+'A');
* @brief 在LCD1602指定位置開始以二進制顯示所給數字
* @param Number 要顯示的數字,范圍:0~1111 1111 1111 1111
* @param Length 要顯示數字的長度,范圍:1~16
* @retval 無
unsigned char i;
LCD_WriteData(Number/LCD_Pow(2,i-1)%2+'0');
還附帶的51單片機的原理圖 哪里還需要修改 顯示屏無法顯示數字
