制作一個(gè)數(shù)碼管秒表,用兩個(gè)led數(shù)碼管顯示,最小計(jì)時(shí)單位為100ms,范圍為0.1-9.9s,按下第一個(gè)功能鍵后開始計(jì)時(shí),第二次按下時(shí)停止
#include <reg51.h>
unsigned char code discode1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
unsigned char code discode2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char timer=0;
unsigned char second;
unsigned char key=0;
main()
TMOD=0x01;
ET0=1;
EA=1;
second=0;
P0=discode1[second/10];
P2=discode2[second%10];
if((P3&0x01)==0x00)
key++;
switch(key)
case 1:
TH0=0xee;
TL0=0x00;
TR0=1;
break;
case 2:
TR0=0;
break;
case 3:
key=0;
second=0;
break;
while((P3&0x01)==0x00);
void int_T0() interrupt 1 using 0
TR0=0;
TH0=0xee;
TL0=0X00;
timer++;
if(timer==20)
timer=0;
second++;
if(second==99)
TR0=0;
second=0;
key=2;
TR0=1;
附件里面是仿真圖,不含代碼(自行生成hex文件)僅供參考,請自行測試,如有錯(cuò)誤請告知:
制作LED數(shù)碼管秒表.zip
(40.65 KB, 下載次數(shù): 13)
2022-4-18 13:23 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
