完整代碼
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1 = P3^0;
- sbit key2 = P3^1;
- sbit key3 = P3^2;
- sbit smg1=P2^0;
- sbit smg2=P2^1;
- sbit beep=P1^0;
- sbit led=P1^1;
- uchar disp[]={0,0};
- uchar scan;
- uchar i,i1,Second_Counts;
- uchar flag=1;
- uchar DSY_CODE[]=
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
- void DelayMS(uint ms)
- uchar t;
- while(ms--)
- for(t=0;t<120;t++);
- void delay_ms(unsigned int ms) // ms延時函數 (AT89C51 @ 11.0592MHz)
- unsigned int i;
- unsigned char j;
- for(i=0;i<ms;i++)
- for(j=0;j<200;j++);
- for(j=0;j<102;j++);
- void Timer0Init()
- TMOD=0X01;//選擇為定時器0模式,工作方式1,僅用TR0打開啟動。
- TH0 = (65535-50000)/256;
- TL0 = (65535-50000)%256;
- ET0=1;//打開定時器0中斷允許
- EA=1;//打開總中斷
- TR0=0;//關閉定時器
- void Timer0() interrupt 1
- TL0 = (65535-50000)%256; //50ms
- if(flag==1)
- if(++i==20)
- i = 0;
- ++Second_Counts;
- if(Second_Counts > 99) Second_Counts = 0;
- else if(flag==2)
- i1++;
- if(i1==5)
- led=!led;
- P2=0xff;
- if(i1==10)
- i1=0;
- led=!led;
- P2=0x00;
- void scanner(void) //數碼管顯示函數
- uchar i;
- scan=0x01;
- if(flag==2&&i1<5)
- for(i=0;i<2;i++) //顯示ADC獲取的電壓
- P2=scan;
- P0=DSY_CODE[disp[i]];
- delay_ms(5);
- scan<<=1; //數碼管移位
- if(flag==1)
- P2=scan;
- delay_ms(5);
- scan<<=1; //數碼管移位
- void main()
- i = 0;
- Second_Counts = 0;
- Timer0Init();
- led=0;
- beep=0;
- while(1)
- scanner();
- if(key1==0)
- delay_ms(10);
- if(key1==0)
- flag=1;
- TR0=1;
- while(!key1);
- if(key2==0)
- delay_ms(10);
- if(key2==0)
- flag=2;
- while(!key2);
- if(key3==0)
- delay_ms(10);
- if(key3==0)
- Second_Counts=0;
- TR0=0;
- led=0;
- flag=1;
- while(!key3);
- disp[0]=Second_Counts%10;
- disp[1]=Second_Counts/10;
- if(flag==1)
- if(disp[0]==9&&disp[1]==9)
- TR0=0;
- beep=1;
- led=1;
- else
- beep=0;
- led=0;
秒表0-99.zip
2022-4-10 16:31 上傳
329.02 KB, 下載次數: 24
