查看: 1851|回復: 4
單片機倒計時程序按鍵只能加減秒和分不能控制時
ID:1005855 發表于 2022-4-9 20:06 | 顯示全部樓層 |閱讀模式
初始倒計時設置了djfen的值但是仿真顯示不出來,只能顯示設置的djmiao,還有按鍵按到小時設置的時候不能加也不能減,只能加減秒和分,不知道又是哪里有問題了,求解決呀
#include <reg52.h>
#include <intrins.h>
#include <lcd.h>
sbit key1=P3^0;  //設置鍵
sbit key2=P3^1;  //加鍵
sbit key3=P3^2;  //減鍵
sbit key4=P3^3;  //開始鍵
sbit beep=P2^4;
sbit trig=P1^7;
sbit echo=P1^6;
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
uchar djshi,djfen=1,djmiao=8;
uchar r,num,s,i;
uchar distance,t;
bit flag=0;
bit flag1s=0;
uchar code table1[]={"time: 00:00:00  "};
uchar code table2[]={"                "};
uchar code table3[13]={'0','1','2','3','4','5','6','7','8','9','.','-','M'};
uchar code table4[]={"xdz:"};
uchar cc[4]={0,0,0,0};
void startmodule();
void start();
void count();
void LcdInit()                                                  //LCD初始化子程序
                uchar i;
                lcd_writecom(0x38);  //開顯示
                lcd_writecom(0x0c);  //開顯示不顯示光標
                lcd_writecom(0x06);  //寫一個指針加1
                lcd_writecom(0x01);  //清屏
                lcd_writecom(0x80);  //設置數據指針起點
                for(i=0;i<16;i++)
                                lcd_writedate(table1[ i]);[ i]
void Timer0Init(void)                //
                TMOD |= 0x01;                //使用定時器T0的模式1  定時器T1的模式1
                TL0 = 15536%256;                //設置定時0初值
                TH0 = 15536/256;                //設置定時0初值
                TR0 = 1;                //定時器0開始計時
                ET0=1;
                EA=1;
void Timer1Init(void)                //
                TMOD |= 0x10;                //使用定時器T0的模式1  定時器T1的模式1
                TL1 = 0;                //設置定時0初值
                TH1 = 0;                //設置定時0初值
        TF1=0;
                TR1 = 1;                //定時器0開始計時
                ET0=1;
                EA=1;
void Delay1ms(uint n)
   uint x,y;
    for(x=n;x>0;x--)
         for(y=110;y>0;y--);
void write_sfm(uchar add,uchar date)
                lcd_writecom(0x80+add);
                lcd_writedate(date/10+0x30);
                lcd_writedate(date%10+0x30);
                lcd_writecom(0x80+add+1);
void keyscan()
                if(key1==0)
                                Delay1ms(5);
                                if(key1==0)
                                                num++;
                                                TR0=0;
                                                while(!key1);
                                                if(num==1)
        lcd_writecom(0x0f);
        lcd_writecom(0x8D);
                                                if(num==2)
        lcd_writecom(0x8A);
                                                if(num==3)
        lcd_writecom(0x87);
                                                          num=0;
                if(num==1)
                                if(key2==0)
                                                Delay1ms(5);
                                                if(key2==0)
        djmiao++;
        while(!key2);
        if(djmiao==60)
        djmiao=0;
        lcd_writecom(0x8c);
        lcd_writedate(djmiao/10+0x30);
        lcd_writedate(djmiao%10+0x30);
        lcd_writecom(0x8D);
                                if(key3==0)
                                                Delay1ms(5);
                                                if(key3==0)
        djmiao--;
        while(!key3);
        if(djmiao==255)
        djmiao=59;
        lcd_writecom(0x8c);
        lcd_writecom(0x8D);
                if(num==2)
                                if(key2==0)
                                                Delay1ms(5);
                                                if(key2==0)
        djfen++;
        while(!key2);
        if(djfen==60)
        djfen=0;
        lcd_writecom(0x89);
        lcd_writedate(djfen/10+0x30);
        lcd_writedate(djfen%10+0x30);
        lcd_writecom(0x8A);
                                if(key3==0)
                                                Delay1ms(5);
                                                if(key3==0)
        djfen--;
                                                        while(!key3);
        if(djfen==255)
        djfen=59;
        lcd_writecom(0x89);
        lcd_writecom(0x8A);
                if(num==3)
                                if(key2==0)
                                                Delay1ms(5);
                                                if(key2==0)
        djshi++;
        while(!key2);
        if(djshi==24)
        djshi=0;
        lcd_writecom(0x86);
        lcd_writedate(djshi/10+0x30);
        lcd_writedate(djshi%10+0x30);
        lcd_writecom(0x88);
                                if(key3==0)
                                                Delay1ms(5);
                                                if(key3==0)
        djshi--;
        while(!key3);
        if(djshi==255)
        djshi=23;
        lcd_writecom(0x86);
        lcd_writecom(0x88);
                if(key4==0)
                                Delay1ms(5);
                                if(key4==0)
        TR0=1;
                                        lcd_writecom(0x0c);
void fmq()
        beep=1;
        Delay1ms(5);
        beep=0;
        Delay1ms(5);
                LcdInit();
                Timer0Init();
          Timer1Init();
                trig=0;
                Delay1ms(1000);
                        if(flag1s)
                                flag1s=0;
                                        startmodule();
                        start();
                        count();
                        keyscan();
                                if(djshi==0 && djfen==0 &&djmiao==0)  //倒計時時間到
                                                TR0=0;          //停止計時
                                          fmq();
void Timer0() interrupt 1
                TL0 = 15536%256;                //設置定時初值
                TH0 = 15536/256;                //設置定時初值
                r++;
                if(r==20)
                                r=0;
                                djmiao--;
                                if(djmiao==255)
                                                djmiao=59;
                                                djfen--;
                                                if(djfen==255)
        djfen=59;
        djshi--;
        if(djshi==255)
        djshi=0;
        if(djshi==0)
        djfen=59;
        if(djfen==0&djshi==0)
        djfen=0;
        write_sfm(6,djshi);
                                                write_sfm(9,djfen);
                                        write_sfm(12,djmiao);
                                        flag1s=1;
void startmodule()
                trig=1;
                _nop_(); _nop_(); _nop_(); _nop_();
                trig=0;
void start()
                   while(!echo);                //當Echo為零時等待
             TR1=1;                            //開啟
             while(echo);                //當Echo為1計數并等待
             TR1=0;                                //關閉
void count()
        t=TH1*256+TL1;
        TH1=0;
        TL1=0;
        distance=t/58.0;
        cc[0]=distance/1000%10;
        cc[1]=distance/100%10;
        cc[2]=distance/10%10;
        cc[3]=distance/1%10;
ID:161164 發表于 2022-4-9 23:23 | 顯示全部樓層
  1.         if(num==3)
  2.         {
  3.                 lcd_writecom(0x87);
  4.         }
  5.         if(num==4)num=0;
ID:121859 發表于 2022-4-10 08:20 | 顯示全部樓層
加一條語句:num++;num%=4;
ID:987736 發表于 2022-4-13 17:27 來自觸屏版 | 顯示全部樓層
請問if(djfen==255)中的255是什么意思呀
ID:161164 發表于 2022-4-14 09:14 | 顯示全部樓層
樹根l 發表于 2022-4-13 17:27
因為djfen的類型是unsinged char 范圍是0~255 沒有負數
前一句是djfen--;
djfen==255就是檢查djfen有沒有溢出
