查看: 1934|回復: 5
C語言一次按4字節倍數讀取,怎么優雅改成按讀1字節倍數讀取呢?
ID:731155 發表于 2022-4-5 19:43 | 顯示全部樓層 |閱讀模式
C語言源程序如下:
  1. int flash_read(UINT32 ptr_add,uint8_t *buffer,int Read_Lengh )
  2. {
  3.         UINT32 *ptr = (UINT32*)ptr_add;
  4.         UINT32 buf = 0;
  5.         int black = 0;
  6.         int r_black = 0;
  7.         black = Read_Lengh/4;
  8.         while(black!= r_black)
  9.         {
  10.                 buf = *ptr;
  11.                 buffer[0+r_black*4] = buf&0x000000ff;
  12.                 buffer[1+r_black*4] = buf>>8&0x000000ff;
  13.                 buffer[2+r_black*4] = buf>>16&0x000000ff;
  14.                 buffer[3+r_black*4] = buf>>24&0x000000ff;
  15.                 ptr++;
  16.                 printf("%02X %02X %02X %02X ",buffer[0+r_black*4],buffer[1+r_black*4],buffer[2+r_black*4],buffer[3+r_black*4]);
  17.                 r_black++;
  18.                 if ((r_black*4)%16==0)
  19.                         printf("\n");
  20.         }
  21.         printf("\n");
  22.         return (r_black*4);
  23. }
ID:883242 發表于 2022-4-5 23:57 | 顯示全部樓層
  1. uint8_t *ptr = ptr_add;
  2. ...
  3.                 buf = *ptr;
  4.                 buffer[0+r_black*4] = *(ptr++);
ID:731155 發表于 2022-4-6 01:08 | 顯示全部樓層
感謝幫忙解答,寫的好簡潔,我試試看
ID:310441 發表于 2022-4-6 06:55 來自觸屏版 | 顯示全部樓層
這是指針最基礎的用法,C++最精髓的地方了,不是說教,這都沒理解好就強行編碼會陷入更大的麻煩的。
ID:731155 發表于 2022-4-6 12:10 | 顯示全部樓層
hei51com 發表于 2022-4-6 01:08
感謝幫忙解答,寫的好簡潔,我試試看
這樣修改后,符合期望了
int ByteReadFlash(UINT32 ptr_add,uint8_t *buffer,int Read_Lengh )
        uint8_t *ptr = ((uint8_t*)ptr_add);
        int black = 0;
        int r_black = 0;
        black = Read_Lengh;
                printf("Read_Lengh %d,black %d\n",Read_Lengh,black);
                buffer[0+r_black] = *(ptr++);
                printf("%02X ",buffer[0+r_black]);
                r_black++;
                if ((r_black)%16==0)
                        printf("\n");
        printf("\n");
        return (r_black);
ID:731155 發表于 2022-4-6 12:14 | 顯示全部樓層
DoneDone 發表于 2022-4-6 06:55
說的確實是,我一直沒能理解好,請教下有沒有竅門呢?
