查看: 2535|回復: 3
DS18B20的為啥不能在顯示屏顯示
ID:984843 發表于 2022-4-2 14:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define delayNOP() {_nop_();_nop_();_nop_();_nop_();}
sbit DQ = P3^3;
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
uchar code Temp_Disp_Title[]={"Current Temp : "};
uchar Current_Temp_Display_Buffer[]={" TEMP:   "};
uchar code Temperature_Char[8] =
        0x0c,0x12,0x12,0x0c,0x00,0x00,0x00,0x00
uchar code df_Table[]=
        0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9
uchar CurrentT = 0;
uchar Temp_Value[]={0x00,0x00};
uchar Display_Digit[]={0,0,0,0};
bit DS18B20_IS_OK = 1;
void DelayXus(uint x)
        uchar i;
        while(x--)
                 for(i=0;i<200;i++);
bit LCD_Busy_Check()
        bit result;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 1;
        delayNOP();
        result = (bit)(P0&0x80);
        LCD_EN=0;
        return result;
void Write_LCD_Command(uchar cmd)
        while(LCD_Busy_Check());
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_EN = 0;
        _nop_();
        _nop_();
        P0 = cmd;
        delayNOP();
        LCD_EN = 1;
        delayNOP();
        LCD_EN = 0;
void Write_LCD_Data(uchar dat)
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_EN = 0;
        P0 = dat;
        delayNOP();
        LCD_EN = 1;
        delayNOP();
        LCD_EN = 0;
void LCD_Initialise()
        Write_LCD_Command(0x01);
        DelayXus(5);
        Write_LCD_Command(0x38);
        DelayXus(5);
        Write_LCD_Command(0x0c);
        DelayXus(5);
        Write_LCD_Command(0x06);
        DelayXus(5);
void Set_LCD_POS(uchar pos)
        Write_LCD_Command(pos|0x80);
void Delay(uint x)
        while(--x);
uchar Init_DS18B20()
        uchar status;
        DQ = 1;
        Delay(8);
        DQ = 0;
        Delay(90);
        DQ = 1;
        Delay(8);
        DQ = 1;
        return status;
uchar ReadOneByte()
        uchar i,dat=0;
        DQ = 1;
        _nop_();
        for(i=0;i<8;i++)
                 DQ = 0;
                dat >>= 1;
                DQ = 1;
                _nop_();
                _nop_();
                if(DQ)
                        dat |= 0X80;
                Delay(30);
                DQ = 1;
        return dat;
void WriteOneByte(uchar dat)
        uchar i;
        for(i=0;i<8;i++)
                 DQ = 0;
                DQ = dat& 0x01;
                Delay(5);
                DQ = 1;
                dat >>= 1;
void Read_Temperature()
        if(Init_DS18B20()==1)
                DS18B20_IS_OK=0;
                WriteOneByte(0xcc);
                WriteOneByte(0x44);
                Init_DS18B20();
                WriteOneByte(0xcc);
                WriteOneByte(0xbe);
                Temp_Value[0] = ReadOneByte();
                Temp_Value[1] = ReadOneByte();
                DS18B20_IS_OK=1;
void Display_Temperature()
        uchar i;
        uchar t = 150, ng = 0;
        if((Temp_Value[1]&0xf8)==0xf8)
                 Temp_Value[1] = ~Temp_Value[1];
                Temp_Value[0] = ~Temp_Value[0]+1;
                if(Temp_Value[0]==0x00)
                        Temp_Value[1]++;
                ng = 1;
        Display_Digit[0] = df_Table[Temp_Value[0]&0x0f];
        CurrentT = ((Temp_Value[0]&0xf0)>>4) | ((Temp_Value[1]&0x07)<<4);
        Display_Digit[3] = CurrentT/100;
        Display_Digit[2] = CurrentT%100/10;
        Display_Digit[1] = CurrentT%10;
        Current_Temp_Display_Buffer[11] = Display_Digit[0] + '0';
        Current_Temp_Display_Buffer[10] = '.';
        Current_Temp_Display_Buffer[9]  = Display_Digit[1] + '0';
        Current_Temp_Display_Buffer[8]  = Display_Digit[2] + '0';
        Current_Temp_Display_Buffer[7]  = Display_Digit[3] + '0';
        if(Display_Digit[3] == 0)
                Current_Temp_Display_Buffer[7]  = ' ';
        if(Display_Digit[2] == 0&&Display_Digit[3]==0)
                Current_Temp_Display_Buffer[8]  = ' ';
        if(ng)
                 if(Current_Temp_Display_Buffer[8]  == ' ')
                        Current_Temp_Display_Buffer[8]  = '-';
                else if(Current_Temp_Display_Buffer[7]  == ' ')
                        Current_Temp_Display_Buffer[7]  = '-';
                        Current_Temp_Display_Buffer[6]  = '-';
        Set_LCD_POS(0x00);
        for(i=0;i<16;i++)
                Write_LCD_Data(Temp_Disp_Title[i]);
        Set_LCD_POS(0x40);
        for(i=0;i<16;i++)
                Write_LCD_Data(Current_Temp_Display_Buffer[i]);
        Set_LCD_POS(0x4d);
        Write_LCD_Data(0x00);
        Set_LCD_POS(0x4e);
        Write_LCD_Data('C');
        LCD_Initialise();
        Read_Temperature();
        Delay(50000);
        Delay(50000);
                 Read_Temperature();
                if(DS18B20_IS_OK)
                        Display_Temperature();
                DelayXus(100);
ID:161164 發表于 2022-4-3 09:50 來自觸屏版 | 只看該作者
是讀不到DS18B20還是LCD不顯示?
ID:139866 發表于 2022-4-8 13:25 | 只看該作者
我完全想象不到ds18B20跟LCD有什么直接的聯系
ID:584814 發表于 2022-4-8 14:51 | 只看該作者
DS18B20的為啥不能在顯示屏顯示 ?
多半是你沒安裝攝像頭等圖形轉換裝置,顯示屏也缺少相應顯示驅動功能。
