查看: 2143|回復: 4
關于51單片機四位數碼管滾動顯示0~9的程序問題
ID:1014417 發表于 2022-3-30 20:51 | 顯示全部樓層 |閱讀模式
請教一下,為什么我在實物板子上能運行到了Protues仿真里卻無法正常運行啊?
代碼如下:
#include <REGX52.H>
unsigned char N[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void Delay(unsigned int xms)
    unsigned char i, j;
    while(xms--)
        i = 2;
        j = 239;
        do
            while (--j);
        } while (--i);
void led (unsigned char Location,Number)
    switch(Location)
        case 1:P3_7=0x00;P3_6=0xFF;P3_5=0xFF;P3_4=0xFF;break;
        case 2:P3_7=0xFF;P3_6=0x00;P3_5=0xFF;P3_4=0xFF;break;
        case 3:P3_7=0xFF;P3_6=0xFF;P3_5=0x00;P3_4=0xFF;break;
        case 4:P3_7=0xFF;P3_6=0xFF;P3_5=0xFF;P3_4=0x00;break;
    P0=N[Number];
    Delay(1);
    P0=0xFF;
    unsigned int i,j;
      i=0;
            for(i=0;i<7;i++)
            for(j=0;j<100;j++)
        led(1,i+0);
     led(2,i+1);
        led(3,i+2);
       led(4,i+3);
ID:161164 發表于 2022-3-30 23:40 | 顯示全部樓層
P0有沒有加上拉電阻?
ID:123289 發表于 2022-3-31 08:45 | 顯示全部樓層
P3_X是位,不是字節,用0、1;不要用FFH.
另外:走單步學會自己調試。
ID:860248 發表于 2022-3-31 22:25 | 顯示全部樓層
由於我用的是普中幵發板, 所以有少許修改, 並將顯示做到無縫連續顯示, 不會顯 6789後馬上變為0123
#include <REG52.H>
sbit LSA = P1^0;
sbit LSB = P1^1;
sbit LSC = P1^2;
unsigned char SMG[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xc0,0xf9,0xa4,0xb0};
    unsigned char i, j;
    while(xms--)
        i = 2;
        j = 239;
        do
            while (--j);
        } while (--i);
    switch(Location)
        case 1: LSA = 0; LSB = 0; LSC = 0; break;
        case 2: LSA = 1; LSB = 0; LSC = 0; break;
        case 3: LSA = 0; LSB = 1; LSC = 0; break;
        case 4: LSA = 1; LSB = 1; LSC = 0; break;
    P0=~SMG[Number];
    Delay(1);
    P0=0x00;
    unsigned int i,j;
      i=0;
        for(i=0;i<10;i++)
            for(j=0;j<100;j++)
                        led(1,i+0);
                             led(2,i+1);
                        led(3,i+2);
                               led(4,i+3);
ID:1013716 發表于 2022-4-1 23:24 | 顯示全部樓層
數碼管是不顯示 還是顯示錯誤 建議靜態測試一下 看你這程序是共陽管 P0=0xc0;P3=0xff;試試看.
