只需一步,快速開(kāi)始
查看: 1884|回復(fù): 1
運(yùn)行錯(cuò)誤 單片機(jī)步進(jìn)電機(jī)模塊 正轉(zhuǎn),反轉(zhuǎn)調(diào)速Proteus仿真+程序
ID:991417 發(fā)表于 2022-3-29 22:50 | 顯示全部樓層 |閱讀模式
步進(jìn)電機(jī)模塊,正轉(zhuǎn),反轉(zhuǎn)調(diào)速
單片機(jī)源程序如下:
                         LCD1602.C文件 LCD1602的函數(shù)
#include "hardware.h"
#include "lcd1602.h"
void LCD_check_busy(void)   //檢測(cè)LCD狀態(tài),看它是不是還在忙呢
   LCD_EN=0;
   LCD_RS=0;
   LCD_RW=1;
   LCD_DATA=0xff;
   LCD_EN=1;
   if(!LCD_BUSY)break;
LCD_EN=0;
void LCD_cls(void)          //LCD清屏
LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=1;
LCD_EN=1;
LCD_EN=0;
void LCD_write_instruction(unsigned char LCD_instruction)   //寫(xiě)指令到LCD
  LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=LCD_instruction;
LCD_EN=1;
LCD_EN=0;
void LCD_write_data(unsigned char LCD_data)      //輸出一個(gè)字節(jié)數(shù)據(jù)到LCD
  LCD_check_busy();
LCD_RS=1;
LCD_RW=0;
LCD_DATA=LCD_data;
LCD_EN=1;
LCD_EN=0;
void LCD_set_position(unsigned char x)            //LCD光標(biāo)定位到x處
LCD_write_instruction(0x80+x);
void LCD_go_home(void)                         //LCD光標(biāo)歸位
LCD_write_instruction(LCD_GO_HOME);
void LCD_printc(unsigned char lcd_data)          //輸出一個(gè)字符到LCD
LCD_write_data(lcd_data);
void LCD_prints(unsigned char *lcd_string)       //輸出一個(gè)字符串到LCD
unsigned char i=0;
while(lcd_string[ i]!=0x00)
   LCD_write_data(lcd_string[ i]);
   i++;
void LCD_initial(void)                        //初始化LCD
LCD_write_instruction(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
LCD_write_instruction(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
LCD_write_instruction(LCD_DISPLAY_DOUBLE_LINE);
LCD_cls();
運(yùn)行錯(cuò)誤 求指導(dǎo): 步進(jìn)電機(jī)模塊.zip (59.61 KB, 下載次數(shù): 11)
評(píng)分
參與人數(shù) 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:102963 發(fā)表于 2022-3-30 10:08 | 顯示全部樓層
仿真圖沒(méi)有Lcd1602,程序里面怎么有Lcd1602的程序呢?
