//改動的主要是main函數(shù)中while循環(huán)內(nèi)的代碼.
// 主程序
uchar i = 0;
uchar IIC_Password[10];
uchar IS_Valid_User = 0;
P0 = 0xFF;
P1 = 0xFF;
P2 = 0xFF;
TMOD = 0x02; //T0設(shè)置為8位自動重裝模式
TH0 = 175;
TL0 = 175;
TR0 = 1; //啟動T0
DelayMS(10);
LCD_Init(); //初始化LCD
IIC_24C04_Init(); //初始化24C04
Display_String(Title_Text,0x00); //在第1行顯示標(biāo)題
//24C04的內(nèi)容已由初始化BIN文件導(dǎo)入
//將24C04中預(yù)先寫入的密碼讀入pass
RecString(0xa0, 0 , IIC_Password, 6);
IIC_Password[6] = '\0';
P1 = 0xF0;
if(P1 != 0xF0) KeyNo = Keys_Scan(); //掃描鍵盤獲取鍵序號KeyNo
switch ( KeyNo )
case 0: case 1: case 2: case 3: case 4:
case 5: case 6: case 7: case 8: case 9:
if ( i<= 5 ) //密碼限制在6位以內(nèi)
//如果i為0則執(zhí)行一次清屏
if (i ==0) Display_String(" ",0x40);
UserPassword[ i] = KeyNo + '0';[ i]
UserPassword[i+1] = '\0';
DSY_BUFFER[ i] = '*';[ i]
DSY_BUFFER[i+1] = '\0';
Display_String(DSY_BUFFER,0x40);
i++;
break;
case 10: //按A鍵開鎖
if (strcmp(UserPassword,IIC_Password) == 0)
LED_OPEN = 0; //點亮LED
Clear_Password();
Display_String("Unlock OK! ",0x40);
IS_Valid_User = 1;
LED_OPEN =1; //關(guān)閉LED
Clear_Password();
Display_String("ERROR ! ",0x40);
IS_Valid_User = 0;
i = 0;
break;
case 11: //按B鍵上鎖
LED_OPEN =1;
Clear_Password();
i = 0;
IS_Valid_User = 0;
break;
case 12: //按C鍵設(shè)置新密碼
//如果是合法用戶則提示輸入新密碼
if ( !IS_Valid_User ) Display_String("No rights !",0x40);
i = 0;
Display_String("New Password: ",0x00);
break;
case 13: //按D鍵保存新密碼
SendString(0xa0, 0 , UserPassword, 6);
//重新讀入剛寫的密碼
i = 0;
Display_String("Password Saved! ",0x40);
break;
case 14: //按E鍵消除所有輸入
i = 0;
Clear_Password();
Beep();
DelayMS(100);
P1= 0xF0;
while (P1 != 0xF0); //如果有鍵未釋放則等待
while (P1 == 0xF0); //如果沒有再次按下按鍵則等待
