如題,我用了兩個CC1101模塊做收發(fā)遙控,然后發(fā)射功率我設置到了最大,可是空曠距離很不理想。我看手冊上說怎么也得200米,可是我的只有二三十米的樣子,論壇的友友們,幫忙指點一下我的程序看看是不是哪里還是設置的不對啊。CC1101我買的現(xiàn)成模塊,硬件電路應該沒有問題。我也懷疑問題出在我的程序里面。
單片機程序如下:
- #include <reg52.h>
- #include <intrins.h>
- #define INT8U unsigned char
- #define uchar unsigned char
- #define INT16U unsigned int
- #define uint unsigned int
- sfr P3M1=0xb1;
- sfr P3M0=0xb2;
- sfr P2M1=0x95;
- sfr P2M0=0x96;
- sfr P1M1=0x91;
- sfr P1M0=0x92;
- #define ID_ADDR_ROM 0x1ff9
- #define ID_ADDR_RAM 0xf1
- #define BAUD 0XFD00 //9600bps @11.0592Mhz
- sfr IAP_DATA=0xc2;
- sfr IAP_ADDRH=0xc3;
- sfr IAP_ADDRL=0xc4;
- sfr IAP_CMD=0xc5;
- sfr IAP_TRIG=0xc6;
- sfr IAP_CONTR=0xc7;
- #define ENABLE_IAP 0x82
- #define IAP_ADDRESS 0x0000//前512字節(jié)
- #define IAP_ADDRESS2 0x0200//后512字節(jié)
- #define CMD_IDLE 0
- #define CMD_READ 1
- #define CMD_PROGRAM 2
- #define CMD_ERASE 3
- INT8U id[7]={0},flag_study=0;
- #define HEAD_LEN 6
- #define WRITE_BURST 0x40 //連續(xù)寫入
- #define READ_SINGLE 0x80 //讀
- #define READ_BURST 0xC0 //連續(xù)讀
- #define BYTES_IN_RXFIFO 0x7F //接收緩沖區(qū)的有效字節(jié)數(shù)
- #define CRC_OK 0x80 //CRC校驗通過位標志
- //sbit GDO0 =P3^3;
- //sbit GDO2 =P3^2;
- //sbit MISO =P1^4;
- //sbit MOSI =P1^3;
- //sbit SCK =P1^5;
- //sbit CSN =P2^6;
- sbit GDO0 =P2^7;
- sbit GDO2 =P3^2;
- sbit MISO =P1^4;
- sbit MOSI =P1^3;
- sbit SCK =P1^5;
- sbit CSN =P1^0;
- sbit CSN2 =P1^0;
- //sbit KEY_start =P2^2; //對應KEY2 啟動按鍵
- //sbit KEY_stop =P2^0;//對應KEY0 停止按鍵
- //sbit KEY_up =P2^1; //對應KEY1 上升按鍵
- //sbit KEY_down =P2^3;//對應KEY3 下降按鍵
- //sbit KEY_left =P3^6;//對應KEY6 按鍵 外部中斷2
- //sbit KEY_right =P3^7;//對應KEY5 按鍵 外部中斷3
- //sbit key4 = P2^4;
- //sbit key5 = P3^7;
- //sbit key6 = P3^6;
- //sbit key7 = P3^5;
- sbit KEY0 =P2^0;//停止
- sbit KEY1 =P2^1;//上升
- sbit KEY2 =P2^2;//啟動
- sbit KEY3 =P2^3;//下降
- sbit led1=P2^5; //指示燈LED1,低電平時亮,高電平時暗 紅燈
- sbit led2=P2^4; //指示燈LED1,低電平時亮,高電平時暗 綠燈
- unsigned char key_up=1,key_down;
- unsigned char num;
- //***************更多功率參數(shù)設置可詳細參考DATACC1100英文文檔中第48-49頁的參數(shù)表************
- //INT8U PaTabel[8] = {0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04}; //-30dBm 功率最小
- //INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60}; //0dBm
- INT8U PaTabel[8] = {0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0}; //10dBm 功率最大
- //INT8U PaTabel[8] = {0xC0 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00 ,0x00}; //10dBm 功率最大
- void SpiInit(void);
- void CpuInit(void);
- void RESET_CC1100(void);
- void POWER_UP_RESET_CC1100(void);
- void halSpiWriteReg(INT8U addr, INT8U value);
- void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count);
- void halSpiStrobe(INT8U strobe);
- INT8U halSpiReadReg(INT8U addr);
- void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count);
- INT8U halSpiReadStatus(INT8U addr);
- void halRfWriteRfSettings(void);
- void halRfSendPacket(INT8U *txBuffer, INT8U size);
- INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length);
- // CC1100 STROBE, CONTROL AND STATUS REGSITER
- #define CCxxx0_IOCFG2 0x00 // GDO2 output pin configuration
- #define CCxxx0_IOCFG1 0x01 // GDO1 output pin configuration
- #define CCxxx0_IOCFG0 0x02 // GDO0 output pin configuration
- #define CCxxx0_FIFOTHR 0x03 // RX FIFO and TX FIFO thresholds
- #define CCxxx0_SYNC1 0x04 // Sync word, high INT8U
- #define CCxxx0_SYNC0 0x05 // Sync word, low INT8U
- #define CCxxx0_PKTLEN 0x06 // Packet length
- #define CCxxx0_PKTCTRL1 0x07 // Packet automation control
- #define CCxxx0_PKTCTRL0 0x08 // Packet automation control
- #define CCxxx0_ADDR 0x09 // Device address
- #define CCxxx0_CHANNR 0x0A // Channel number
- #define CCxxx0_FSCTRL1 0x0B // Frequency synthesizer control
- #define CCxxx0_FSCTRL0 0x0C // Frequency synthesizer control
- #define CCxxx0_FREQ2 0x0D // Frequency control word, high INT8U
- #define CCxxx0_FREQ1 0x0E // Frequency control word, middle INT8U
- #define CCxxx0_FREQ0 0x0F // Frequency control word, low INT8U
- #define CCxxx0_MDMCFG4 0x10 // Modem configuration
- #define CCxxx0_MDMCFG3 0x11 // Modem configuration
- #define CCxxx0_MDMCFG2 0x12 // Modem configuration
- #define CCxxx0_MDMCFG1 0x13 // Modem configuration
- #define CCxxx0_MDMCFG0 0x14 // Modem configuration
- #define CCxxx0_DEVIATN 0x15 // Modem deviation setting
- #define CCxxx0_MCSM2 0x16 // Main Radio Control State Machine configuration
- #define CCxxx0_MCSM1 0x17 // Main Radio Control State Machine configuration
- #define CCxxx0_MCSM0 0x18 // Main Radio Control State Machine configuration
- #define CCxxx0_FOCCFG 0x19 // Frequency Offset Compensation configuration
- #define CCxxx0_BSCFG 0x1A // Bit Synchronization configuration
- #define CCxxx0_AGCCTRL2 0x1B // AGC control
- #define CCxxx0_AGCCTRL1 0x1C // AGC control
- #define CCxxx0_AGCCTRL0 0x1D // AGC control
- #define CCxxx0_WOREVT1 0x1E // High INT8U Event 0 timeout
- #define CCxxx0_WOREVT0 0x1F // Low INT8U Event 0 timeout
- #define CCxxx0_WORCTRL 0x20 // Wake On Radio control
- #define CCxxx0_FREND1 0x21 // Front end RX configuration
- #define CCxxx0_FREND0 0x22 // Front end TX configuration
- #define CCxxx0_FSCAL3 0x23 // Frequency synthesizer calibration
- #define CCxxx0_FSCAL2 0x24 // Frequency synthesizer calibration
- #define CCxxx0_FSCAL1 0x25 // Frequency synthesizer calibration
- #define CCxxx0_FSCAL0 0x26 // Frequency synthesizer calibration
- #define CCxxx0_RCCTRL1 0x27 // RC oscillator configuration
- #define CCxxx0_RCCTRL0 0x28 // RC oscillator configuration
- #define CCxxx0_FSTEST 0x29 // Frequency synthesizer calibration control
- #define CCxxx0_PTEST 0x2A // Production test
- #define CCxxx0_AGCTEST 0x2B // AGC test
- #define CCxxx0_TEST2 0x2C // Various test settings
- #define CCxxx0_TEST1 0x2D // Various test settings
- #define CCxxx0_TEST0 0x2E // Various test settings
- // Strobe commands
- #define CCxxx0_SRES 0x30 // Reset chip.
- #define CCxxx0_SFSTXON 0x31 // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
- // If in RX/TX: Go to a wait state where only the synthesizer is
- // running (for quick RX / TX turnaround).
- #define CCxxx0_SXOFF 0x32 // Turn off crystal oscillator.
- #define CCxxx0_SCAL 0x33 // Calibrate frequency synthesizer and turn it off
- // (enables quick start).
- #define CCxxx0_SRX 0x34 // Enable RX. Perform calibration first if coming from IDLE and
- // MCSM0.FS_AUTOCAL=1.
- #define CCxxx0_STX 0x35 // In IDLE state: Enable TX. Perform calibration first if
- // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
- // Only go to TX if channel is clear.
- #define CCxxx0_SIDLE 0x36 // Exit RX / TX, turn off frequency synthesizer and exit
- // Wake-On-Radio mode if applicable.
- #define CCxxx0_SAFC 0x37 // Perform AFC adjustment of the frequency synthesizer
- #define CCxxx0_SWOR 0x38 // Start automatic RX polling sequence (Wake-on-Radio)
- #define CCxxx0_SPWD 0x39 // Enter power down mode when CSn goes high.
- #define CCxxx0_SFRX 0x3A // Flush the RX FIFO buffer.
- #define CCxxx0_SFTX 0x3B // Flush the TX FIFO buffer.
- #define CCxxx0_SWORRST 0x3C // Reset real time clock.
- #define CCxxx0_SNOP 0x3D // No operation. May be used to pad strobe commands to two
- // INT8Us for simpler software.
- #define CCxxx0_PARTNUM 0x30
- #define CCxxx0_VERSION 0x31
- #define CCxxx0_FREQEST 0x32
- #define CCxxx0_LQI 0x33
- #define CCxxx0_RSSI 0x34
- #define CCxxx0_MARCSTATE 0x35
- #define CCxxx0_WORTIME1 0x36
- #define CCxxx0_WORTIME0 0x37
- #define CCxxx0_PKTSTATUS 0x38
- #define CCxxx0_VCO_VC_DAC 0x39
- #define CCxxx0_TXBYTES 0x3A
- #define CCxxx0_RXBYTES 0x3B
- #define CCxxx0_PATABLE 0x3E
- #define CCxxx0_TXFIFO 0x3F
- #define CCxxx0_RXFIFO 0x3F
- // RF_SETTINGS is a data structure which contains all relevant CCxxx0 registers
- typedef struct S_RF_SETTINGS
- INT8U FSCTRL2; //自已加的
- INT8U FSCTRL1; // Frequency synthesizer control.
- INT8U FSCTRL0; // Frequency synthesizer control.
- INT8U FREQ2; // Frequency control word, high INT8U.
- INT8U FREQ1; // Frequency control word, middle INT8U.
- INT8U FREQ0; // Frequency control word, low INT8U.
- INT8U MDMCFG4; // Modem configuration.
- INT8U MDMCFG3; // Modem configuration.
- INT8U MDMCFG2; // Modem configuration.
- INT8U MDMCFG1; // Modem configuration.
- INT8U MDMCFG0; // Modem configuration.
- INT8U CHANNR; // Channel number.
- INT8U DEVIATN; // Modem deviation setting (when FSK modulation is enabled).
- INT8U FREND1; // Front end RX configuration.
- INT8U FREND0; // Front end RX configuration.
- INT8U MCSM0; // Main Radio Control State Machine configuration.
- INT8U FOCCFG; // Frequency Offset Compensation Configuration.
- INT8U BSCFG; // Bit synchronization Configuration.
- INT8U AGCCTRL2; // AGC control.
- INT8U AGCCTRL1; // AGC control.
- INT8U AGCCTRL0; // AGC control.
- INT8U FSCAL3; // Frequency synthesizer calibration.
- INT8U FSCAL2; // Frequency synthesizer calibration.
- INT8U FSCAL1; // Frequency synthesizer calibration.
- INT8U FSCAL0; // Frequency synthesizer calibration.
- INT8U FSTEST; // Frequency synthesizer calibration control
- INT8U TEST2; // Various test settings.
- INT8U TEST1; // Various test settings.
- INT8U TEST0; // Various test settings.
- INT8U IOCFG2; // GDO2 output pin configuration
- INT8U IOCFG0; // GDO0 output pin configuration
- INT8U PKTCTRL1; // Packet automation control.
- INT8U PKTCTRL0; // Packet automation control.
- INT8U ADDR; // Device address.
- INT8U PKTLEN; // Packet length.
- } RF_SETTINGS;
- const RF_SETTINGS rfSettings =
- 0x00,
- 0x08, // FSCTRL1 Frequency synthesizer control.
- 0x00, // FSCTRL0 Frequency synthesizer control.
- 0x10, // FREQ2 Frequency control word, high byte.
- 0xA7, // FREQ1 Frequency control word, middle byte.
- 0x62, // FREQ0 Frequency control word, low byte.
- // 0x5B, // MDMCFG4 Modem configuration.
- // 0xF8, // MDMCFG3 Modem configuration.
- 0x5B, // MDMCFG4
- 0xE4, // MDMCFG3
- 0x03, // MDMCFG2 Modem configuration.
- 0x22, // MDMCFG1 Modem configuration.
- 0xF8, // MDMCFG0 Modem configuration.
- 0x00, // CHANNR Channel number.
- 0x47, // DEVIATN Modem deviation setting (when FSK modulation is enabled).
- 0xB6, // FREND1 Front end RX configuration.
- 0x10, // FREND0 Front end RX configuration.
- 0x18, // MCSM0 Main Radio Control State Machine configuration.
- 0x1D, // FOCCFG Frequency Offset Compensation Configuration.
- 0x1C, // BSCFG Bit synchronization Configuration.
- 0xC7, // AGCCTRL2 AGC control.
- 0x00, // AGCCTRL1 AGC control.
- 0xB2, // AGCCTRL0 AGC control.
- 0xEA, // FSCAL3 Frequency synthesizer calibration.
- 0x2A, // FSCAL2 Frequency synthesizer calibration.
- 0x00, // FSCAL1 Frequency synthesizer calibration.
- 0x11, // FSCAL0 Frequency synthesizer calibration.
- 0x59, // FSTEST Frequency synthesizer calibration.
- 0x81, // TEST2 Various test settings.
- 0x35, // TEST1 Various test settings.
- 0x09, // TEST0 Various test settings.
- 0x0B, // IOCFG2 GDO2 output pin configuration.
- 0x06, // IOCFG0D GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation.
- 0x04, // PKTCTRL1 Packet automation control.
- 0x05, // PKTCTRL0 Packet automation control.
- 0x00, // ADDR Device address.
- 0x0c // PKTLEN Packet length.
- //函數(shù)名:delay(unsigned int s)
- //輸入:時間
- //輸出:無
- //功能描述:普通廷時,內部用
- static void delay(unsigned int s)
- unsigned int i;
- for(i=0; i<s; i++);
- void delay1ms(int t)//誤差0.434028 us
- unsigned char i=0,j=0,m=0;
- for(m=t;m>0;m--)
- for(i=55;i>0;i--)
- for(j=53;j>0;j--);
- void delay1s(uchar t)//誤差1.000000 us
- {//6倍速
- unsigned char i=0,j=0,k=0,m=0;
- for(m=t;m>0;m--)
- for(i=66;i>0;i--)
- for(j=218;j>0;j--)
- for(k=207;k>0;k--);
- void delay12us()//誤差0.234375 us
- unsigned char i=0;
- for(i=33;i>0;i--);
- void IapIdle()
- IAP_CONTR=0;//關閉IAP功能
- IAP_CMD=0;//清除命令寄存器
- IAP_TRIG=0;//清除觸發(fā)寄存器
- IAP_ADDRH=0x80;//將地址設置到非IAP區(qū)域
- IAP_ADDRL=0;
- uchar IapReadByte(uint addr)
- uchar dat;
- IAP_CONTR=ENABLE_IAP;//使能IAP
- IAP_CMD=CMD_READ;//設置IAP命令
- IAP_ADDRL=addr;//設置IAP低地址
- IAP_ADDRH=addr>>8;//設置IAP高地址
- IAP_TRIG=0x5a;//寫觸發(fā)命令
- IAP_TRIG=0xa5;
- _nop_();//等待操作完成
- dat=IAP_DATA;//讀數(shù)據(jù)
- IapIdle();
- return dat;
- void IapProgramByte(uint addr,uchar dat)
- IAP_CMD=CMD_PROGRAM;//設置IAP命令
- IAP_DATA=dat;//寫IAP數(shù)據(jù)
- IAP_TRIG=0xa5;
- _nop_();//等待操作完成
- IapIdle();
- void IapEraseSector(uint addr)
- IAP_CMD=CMD_ERASE;//設置IAP命令
- IAP_ADDRL=addr;//設置低地址
- IAP_ADDRH=addr>>8;//設置高地址
- IAP_TRIG=0xa5;
- _nop_();//等待操作完成
- IapIdle();
- void SaveData(uchar *dat,uchar len)
- uchar i=0;
- IapEraseSector(IAP_ADDRESS);
- for(i=0;i<len;i++)
- IapProgramByte(IAP_ADDRESS+i,dat[i]);
- delay1ms(1);
- void halWait(INT16U timeout) {
- do {
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- } while (--timeout);
- CSN=0;
- SCK=0;
- CSN=1;
- //函數(shù)名:CpuInit()
- //輸入:無
- //輸出:無
- //功能描述:SPI初始化程序
- SpiInit();
- delay(5000);
- //函數(shù)名:SpisendByte(INT8U dat)
- //輸入:發(fā)送的數(shù)據(jù)
- //輸出:無
- //功能描述:SPI發(fā)送一個字節(jié)
- INT8U SpiTxRxByte(INT8U dat)
- INT8U i,temp;
- temp = 0;
- SCK = 0;
- for(i=0; i<8; i++)
- if(dat & 0x80)
- MOSI = 1;
- else MOSI = 0;
- dat <<= 1;
- SCK = 1;
- _nop_();
- _nop_();
- temp <<= 1;
- if(MISO)temp++;
- SCK = 0;
- _nop_();
- _nop_();
- return temp;
- //函數(shù)名:void RESET_CC1100(void)
- //輸入:無
- //輸出:無
- //功能描述:復位CC1100
- CSN = 0;
- while (MISO);
- SpiTxRxByte(CCxxx0_SRES); //寫入復位命令
- while (MISO);
- CSN = 1;
- //函數(shù)名:void POWER_UP_RESET_CC1100(void)
- //輸入:無
- //輸出:無
- //功能描述:上電復位CC1100
- CSN = 1;
- halWait(1);
- CSN = 0;
- halWait(1);
- CSN = 1;
- halWait(41);
- RESET_CC1100(); //復位CC1100
- //函數(shù)名:void halSpiWriteReg(INT8U addr, INT8U value)
- //輸入:地址和配置字
- //輸出:無
- //功能描述:SPI寫寄存器
- CSN = 0;
- while (MISO);
- SpiTxRxByte(addr); //寫地址
- SpiTxRxByte(value); //寫入配置
- CSN = 1;
- //函數(shù)名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
- //輸入:地址,寫入緩沖區(qū),寫入個數(shù)
- //輸出:無
- //功能描述:SPI連續(xù)寫配置寄存器
- INT8U i, temp;
- temp = addr | WRITE_BURST;
- CSN = 0;
- while (MISO);
- SpiTxRxByte(temp);
- for (i = 0; i < count; i++)
- SpiTxRxByte(buffer[i]);
- CSN = 1;
- //函數(shù)名:void halSpiStrobe(INT8U strobe)
- //輸入:命令
- //輸出:無
- //功能描述:SPI寫命令
- CSN = 0;
- while (MISO);
- SpiTxRxByte(strobe); //寫入命令
- CSN = 1;
- //函數(shù)名:INT8U halSpiReadReg(INT8U addr)
- //輸入:地址
- //輸出:該寄存器的配置字
- //功能描述:SPI讀寄存器
- INT8U temp, value;
- temp = addr|READ_SINGLE;//讀寄存器命令
- CSN = 0;
- while (MISO);
- value = SpiTxRxByte(0);
- CSN = 1;
- return value;
- //函數(shù)名:void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count)
- //輸入:地址,讀出數(shù)據(jù)后暫存的緩沖區(qū),讀出配置個數(shù)
- //輸出:無
- INT8U i,temp;
- temp = addr | READ_BURST; //寫入要讀的配置寄存器地址和讀命令
- CSN = 0;
- while (MISO);
- buffer[i] = SpiTxRxByte(0);
- CSN = 1;
- //輸入:地址
- //輸出:該狀態(tài)寄存器當前值
- //功能描述:SPI讀狀態(tài)寄存器
- INT8U value,temp;
- temp = addr | READ_BURST; //寫入要讀的狀態(tài)寄存器的地址同時寫入讀命令
- CSN = 0;
- while (MISO);
- CSN = 1;
- return value;
- //函數(shù)名:void halRfWriteRfSettings(RF_SETTINGS *pRfSettings)
- //輸入:無
- //輸出:無
- //功能描述:配置CC1100的寄存器
- halSpiWriteReg(CCxxx0_FSCTRL0, rfSettings.FSCTRL2);//自已加的
- // Write register settings
- halSpiWriteReg(CCxxx0_FSCTRL1, rfSettings.FSCTRL1);
- halSpiWriteReg(CCxxx0_FSCTRL0, rfSettings.FSCTRL0);
- halSpiWriteReg(CCxxx0_FREQ2, rfSettings.FREQ2);
- halSpiWriteReg(CCxxx0_FREQ1, rfSettings.FREQ1);
- halSpiWriteReg(CCxxx0_FREQ0, rfSettings.FREQ0);
- halSpiWriteReg(CCxxx0_MDMCFG4, rfSettings.MDMCFG4);
- halSpiWriteReg(CCxxx0_MDMCFG3, rfSettings.MDMCFG3);
- halSpiWriteReg(CCxxx0_MDMCFG2, rfSettings.MDMCFG2);
- halSpiWriteReg(CCxxx0_MDMCFG1, rfSettings.MDMCFG1);
- halSpiWriteReg(CCxxx0_MDMCFG0, rfSettings.MDMCFG0);
- halSpiWriteReg(CCxxx0_CHANNR, rfSettings.CHANNR);
- halSpiWriteReg(CCxxx0_DEVIATN, rfSettings.DEVIATN);
- halSpiWriteReg(CCxxx0_FREND1, rfSettings.FREND1);
- halSpiWriteReg(CCxxx0_FREND0, rfSettings.FREND0);
- halSpiWriteReg(CCxxx0_MCSM0 , rfSettings.MCSM0 );
- halSpiWriteReg(CCxxx0_FOCCFG, rfSettings.FOCCFG);
- halSpiWriteReg(CCxxx0_BSCFG, rfSettings.BSCFG);
- halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
- halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
- halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
- halSpiWriteReg(CCxxx0_FSCAL3, rfSettings.FSCAL3);
- halSpiWriteReg(CCxxx0_FSCAL2, rfSettings.FSCAL2);
- halSpiWriteReg(CCxxx0_FSCAL1, rfSettings.FSCAL1);
- halSpiWriteReg(CCxxx0_FSCAL0, rfSettings.FSCAL0);
- halSpiWriteReg(CCxxx0_FSTEST, rfSettings.FSTEST);
- halSpiWriteReg(CCxxx0_TEST2, rfSettings.TEST2);
- halSpiWriteReg(CCxxx0_TEST1, rfSettings.TEST1);
- halSpiWriteReg(CCxxx0_TEST0, rfSettings.TEST0);
- halSpiWriteReg(CCxxx0_IOCFG2, rfSettings.IOCFG2);
- halSpiWriteReg(CCxxx0_IOCFG0, rfSettings.IOCFG0);
- halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
- halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
- halSpiWriteReg(CCxxx0_ADDR, rfSettings.ADDR);
- halSpiWriteReg(CCxxx0_PKTLEN, rfSettings.PKTLEN);
- //函數(shù)名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
- //輸入:發(fā)送的緩沖區(qū),發(fā)送數(shù)據(jù)個數(shù)
- //輸出:無
- //功能描述:CC1100發(fā)送一組數(shù)據(jù)
- halSpiWriteReg(CCxxx0_TXFIFO, size);
- halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size); //寫入要發(fā)送的數(shù)據(jù)
- halSpiStrobe(CCxxx0_STX); //進入發(fā)送模式發(fā)送數(shù)據(jù)
- // Wait for GDO0 to be set -> sync transmitted
- while (!GDO0);
- // Wait for GDO0 to be cleared -> end of packet
- while (GDO0);
- // led1=1;
- halSpiStrobe(CCxxx0_SFTX);
- void setRxMode(void)
- halSpiStrobe(CCxxx0_SRX); //進入接收狀態(tài)
- // Bit masks corresponding to STATE[2:0] in the status byte returned on MISO
- #define CCxx00_STATE_BM 0x70
- #define CCxx00_FIFO_BYTES_AVAILABLE_BM 0x0F
- #define CCxx00_STATE_TX_BM 0x20
- #define CCxx00_STATE_TX_UNDERFLOW_BM 0x70
- #define CCxx00_STATE_RX_BM 0x10
- #define CCxx00_STATE_RX_OVERFLOW_BM 0x60
- #define CCxx00_STATE_IDLE_BM 0x00
- static INT8U RfGetRxStatus(void)
- INT8U temp, spiRxStatus1,spiRxStatus2;
- INT8U i=4;// 循環(huán)測試次數(shù)
- temp = CCxxx0_SNOP|READ_SINGLE;//讀寄存器命令
- CSN = 0;
- while (MISO);
- spiRxStatus1 = SpiTxRxByte(0);
- do
- spiRxStatus2 = SpiTxRxByte(0);
- if(spiRxStatus1 == spiRxStatus2)
- if( (spiRxStatus1 & CCxx00_STATE_BM) == CCxx00_STATE_RX_OVERFLOW_BM)
- halSpiStrobe(CCxxx0_SFRX);
- return 0;
- return 1;
- spiRxStatus1=spiRxStatus2;
- while(i--);
- CSN = 1;
- return 0;
- INT8U status[2];
- INT8U packetLength;
- INT8U i=(*length)*4; // 具體多少要根據(jù)datarate和length來決定
- //delay(5);
- //while (!GDO1);
- //while (GDO1);
- delay(2);
- while (GDO0)
- delay(2);
- --i;
- if(i<1)
- return 0;
- if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字節(jié)數(shù)不為0
- packetLength = halSpiReadReg(CCxxx0_RXFIFO);//讀出第一個字節(jié),此字節(jié)為該幀數(shù)據(jù)長度
- if (packetLength <= *length) //如果所要的有效數(shù)據(jù)長度小于等于接收到的數(shù)據(jù)包的長度
- halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //讀出所有接收到的數(shù)據(jù)
- *length = packetLength; //把接收數(shù)據(jù)長度的修改為當前數(shù)據(jù)的長度
- // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI)
- halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2); //讀出CRC校驗位
- halSpiStrobe(CCxxx0_SFRX); //清洗接收緩沖區(qū)
- return (status[1] & CRC_OK); //如果校驗成功返回接收成功
- else
- return 0;
- else
- return 0;
- void Delay(unsigned int s)
- unsigned int i;
- //uchar key_scan()
- // //上升、下降
- // if((KEY1==0)) //第一次 key_up=1 此時如果有操作按鍵按下則執(zhí)行下面的程序||key3==0key_up&&
- // delay1ms(10); //延時小豆
- // if((KEY1==0)) //||key3==0key_up&&
- //// key_up=0; //松手標志位0 那么下次檢測, if 結果就為0 則就不會執(zhí)行這里的語句
- //// key_down=1; //按鍵被按下標志 最后如果按鍵松手,那么還應該發(fā)送一個數(shù)據(jù)出去執(zhí)行關閉
- //// if(KEY1==0) //
- // return 1;
- //// if(key3==0)
- //// return 3;
- // else
- //// if(KEY1!=0) //上升下降 按鍵都沒有被按下&&key3==1
- //// key_up=1; //必須所有按鍵都沒有被按下 松手標志初始化
- //// if(key_down==1) //這里判斷按鍵是否按下過,按下過就發(fā)送一個數(shù)據(jù)過去關閉之前的輸出
- //// key_down=0; //初始化
- // return 99; //返回值
- void main(void)
- // P2M1=0x0f;
- // P2M0=0x00;
- INT8U leng =8,i=0,mode=0,cont=0,offset=0,flag1=0,key_num,tf1=0,key_down1=0,key_down=0;
- INT8U tf =0;
- // INT8U DS_UP=0;DS_STOP=0;DS_DOWN=0;
- INT8U TxBuf[8]={0}; // 8字節(jié), 如果需要更長的數(shù)據(jù)包,請正確設置
- INT8U RxBuf[8]={0};
- INT8U code *cptr;
- INT8U idata *iptr;
- cptr=ID_ADDR_ROM;
- iptr=ID_ADDR_RAM;
- for(i=0;i<7;i++)
- id[i]=cptr[i];
- //id[6]=3;
- P1M1=0x00;
- P1M0=0x01;
- //P2M1=0x40;
- //P2M0=0x40;
- CpuInit();
- POWER_UP_RESET_CC1100();
- halRfWriteRfSettings();
- halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8);
- TxBuf[1]=1;TxBuf[2]=0;led1=1;//;led5=0
- //halRfSendPacket(TxBuf,8); // Transmit Tx buffer data
- INT1=1;
- IT1=1;
- EX1=1; //開啟外部中斷1
- EA=1;
- TL1 = BAUD;
- TH1 = BAUD >> 8;
- TR1 = 1;
- ET1 = 1;
- PT1 = 1;
- // EX0=1; //開啟外部中斷0
- TMOD=0x01; //T0方式為1 16位
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256; //50000*12*(1/12M)=50ms
- TR0=1; //啟動定時器T0
- ET0=1; //使能定時器T0中斷
- // key_up=0;
- delay1s(3);
- // P2M1=0x0f;
- // P2M0=0x00;
- if(KEY0==0)
- delay1ms(10);
- if(KEY0==0)
- mode=1;//學習模式
- led1=0;//亮
- delay1ms(10);
- led1=1;//亮
- offset=0;
- TxBuf[offset++]=0xaa;//普通數(shù)據(jù)
- TxBuf[offset++]=0xbb;
- TxBuf[offset++]=id[3];
- TxBuf[offset++]=id[4];
- TxBuf[offset++]=id[5];
- TxBuf[offset++]=id[6];
- //輸入模式
- // P2M0 = 0x00;
- // P2M1 = 0x0F;
- while(1)
- //接收端
- /*if(halRfReceivePacket(RxBuf,&leng))
- //發(fā)送端
- if(mode==1)
- if((KEY0==0)&&(KEY3==0))
- delay1ms(10);
- if(cont<4)
- cont++;
- // while((KEY0==0)&&(KEY3==0));
- if(cont==4)
- led1=0;//亮
- offset=0;
- TxBuf[offset++]=0xff;//識別碼標志
- halRfSendPacket(TxBuf,8);
- delay1ms(200);
- led1=1;//熄滅
- delay1ms(200);
- // mode=0;
- else
- {//正常模式 發(fā)送按鍵數(shù)據(jù)
- // if(key_up&&KEY1==0)//第一次key_up==1;那么如果其他按鍵有按下,則為真,執(zhí)行下面程序
- if(((KEY1==1)&&(KEY3==1))&&(KEY2!=0))//點動上升
- delay1ms(50);
- TxBuf[1]=0xa1;
- tf1=1;
- key_down=0;
- key_down1=0;
- ET0=1;
- else if((KEY1==0)&&(key_down1==0))
- delay1ms(50);
- if(KEY1==0)
- TxBuf[1]=0xb1;
- tf1=1;
- key_down=1;
- ET0=0;
- led2=0;//亮
- delay1ms(30);
- led2=1;//亮
- // if(KEY3==1)//點動下降
- // delay1ms(50);
- // if(KEY3==1)
- // TxBuf[1]=0xa2;
- // tf1=1;
- // key_down1=0;
- else if((KEY3==0)&&(key_down==0))
- delay1ms(50);
- if(KEY3==0)
- TxBuf[1]=0xb2;
- tf1=1;
- key_down1=1;
- ET0=0;
- led2=0;//亮
- delay1ms(30);
- led2=1;//亮
- if(KEY0==0)//停止
- delay1ms(50);
- if(KEY0==0)
- TxBuf[1]=0xcc;
- tf1=1;
- ET0=1;
- led2=0;//亮
- delay1ms(30);
- led2=1;//亮
- if(KEY2==0)//啟動
- delay1ms(50);
- if(KEY2==0)
- TxBuf[1]=0xc5;
- tf1=1;
- ET0=1;
- led2=0;//亮
- delay1ms(30);
- led2=1;//亮
- if (tf1==1)
- TxBuf[HEAD_LEN]=2;
- tf1=0;
- if(num>=80)
- halSpiStrobe(CCxxx0_SIDLE); //進入空閑模式
- halSpiStrobe(CCxxx0_SXOFF);
- halSpiStrobe(CCxxx0_SPWD); //關閉無線模塊
- _nop_();
- _nop_();
- _nop_();
- num=0;
- // led2=0;
- ET0=0;
- delay(500);
- // led1=0;
- PCON=0X02; //PD=1,進入掉電模式 //PCON=0X01;//IDL=1,進入空閑模式
- _nop_();
- _nop_();
- _nop_();
- void exint1() interrupt 2
- PCON=0;
- // led1=1;
- void timer0() interrupt 1
- num++;//每50ms加1
復制代碼 |
