根據STM32103F實戰指南寫的程序,結果不能在12864屏上顯示,求各位大神幫我看看,是哪個環節寫錯了呢?
#include "stm32f10x.h" // Device header
#define ADC_APBxClock_FUN RCC_APB2PeriphClockCmd
#define ADCx ADC1
#define ADC_CLK RCC_APB2Periph_ADC1
#define ADC_GPIO_APBxClock_FUN RCC_APB2PeriphClockCmd
#define ADC_GPIO_CLK RCC_APB2Periph_GPIOA
#define ADC_PORT GPIOA
#define ADC_PIN GPIO_Pin_1
#define ADC_CHANNEL ADC_Channel_1
#define ADC_IRQ ADC1_2_IRQn
#define ADC_IRQHandler ADC1_2_IRQHandler
float ADC_ConvertedValue;
static void ADCx_GPIO_Config(void) //ADC GPIO初始化
ADC_GPIO_APBxClock_FUN (ADC_GPIO_CLK ,ENABLE ); //打開ADC IO 端口
GPIO_InitStructure.GPIO_Pin =ADC_PIN; //配置ADC IO引腳模式,必須為模擬輸入
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN ;
GPIO_Init (ADC_PORT ,&GPIO_InitStructure); //初始化ADC IO
static void ADCx_Mode_Config(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_APBxClock_FUN(ADC_CLK,ENABLE ); //打開ADC時鐘
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent ; //ADC模式配置,只使用一個ADC,屬于獨立模式
ADC_InitStructure.ADC_ScanConvMode = DISABLE; //禁止掃描模式,多通道需要,單通道不需要
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //連續轉換模式
ADC_InitStructure.ADC_DataAlign = ADC_ExternalTrigConv_None; //不用外部觸發,軟件開啟即可
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //轉換結果右對齊
ADC_InitStructure.ADC_NbrOfChannel = 1; //轉換同道1個
ADC_Init(ADCx,&ADC_InitStructure); //初始化ADC
RCC_ADCCLKConfig(RCC_PCLK2_Div8); //配置ADC時鐘為CLK2的8分頻,即9MHz
ADC_RegularChannelConfig (ADCx,ADC_CHANNEL,1,ADC_SampleTime_55Cycles5 );
//配置ADC通道轉換順序為1,第一個轉換,采樣時間為55.5個時鐘周期
ADC_ITConfig(ADCx,ADC_IT_EOC,ENABLE);
//ADC轉換結束產生中斷,在中斷服務程序中讀取轉換值
ADC_Cmd(ADCx,ENABLE); // 開啟ADC,并開始轉換
ADC_ResetCalibration(ADCx); //校準寄存器初始換
while(ADC_GetResetCalibrationStatus (ADCx)); //等待寄存器初始化完成
ADC_StartCalibration(ADCx); //ADC開始校準
while(ADC_GetCalibrationStatus(ADCx)); //等待校準完成
ADC_SoftwareStartConvCmd(ADCx,ENABLE); //由于沒有采用外部觸發,所以使用軟件觸發ADC轉換
static void ADC_NVIC_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQ;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
float ConvertedValue_Get(void)
return
ADC_ConvertedValue;
void ADC_IRQHandler(void)
if(ADC_GetITStatus(ADCx,ADC_IT_EOC) == SET)
ADC_ConvertedValue = ADC_GetConversionValue(ADCx);
ADC_ClearITPendingBit(ADCx,ADC_IT_EOC);
void ADCx_Init(void)
ADCx_GPIO_Config();
ADCx_Mode_Config();
ADC_NVIC_Config();
然后我在主程序調用ConvertedValue_Get變量,顯示屏一點反應也沒,請教各位大神,是什么問題?
#include "12864.h"
#include "Delay.h"
#include "Value.h"
extern void PutString(char *str,u8 line); //在第line行輸出字符串
extern void PutIntNum(int value,u8 num,u8 choose); //在第line行輸出整數
extern void PutFloatNum(float value,u8 num1,u8 num2); //在第line行輸出小數
float DisNum=0,DisNum1=0;
uint32_t CountSenser_Get(void);
float ConvertedValue_Get(void);
uint8_t FLAG = 0;
int main(void)
ADCx_Init();
ChipHalInit(); //片內硬件初始化
LCD_Init (); //LCD初始化
DisNum1 = ConvertedValue_Get()/4096*3.3;
PutString("電壓: ",3);
PutFloatNum(DisNum1,5,5);
PutChar("V");
