查看: 1125|回復: 1
stm32F0xx_it.c文件里的中斷都表示什么
ID:302293 發表于 2022-3-18 09:21 | 顯示全部樓層 |閱讀模式
#include "stm32f0xx_it.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/*            Cortex-M0 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles PendSVC exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
ID:883242 發表于 2022-3-18 17:41 | 顯示全部樓層
這幾個都是內核中斷,看STM32的資料你是找不到任何有效信息的。只能看內核的資料,推薦《Cortex-M0權威指南》。
