查看: 2125|回復: 1
STM32F103C8T6單片機定時器1通道1,2,3無輸出
ID:988147 發表于 2022-3-9 21:10 | 顯示全部樓層 |閱讀模式
#include "PWM.h"
extern u16 zhankong;
void PWM_init(u16 a,u16 b)
        GPIO_InitTypeDef  GPIO_InitStruct;
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
//        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOB,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,DISABLE);
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP ;
        GPIO_PinRemapConfig(GPIO_PartialRemap_TIM1,ENABLE);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStruct);
        TIM_TimeBaseInitStruct.TIM_Period = 0;//自動裝載ARR的值
        TIM_TimeBaseInitStruct.TIM_Prescaler =300;
        TIM_TimeBaseInitStruct.TIM_ClockDivision = 0;
        TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInitStruct.TIM_RepetitionCounter =0;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStruct);
        TIM_OCInitStructure.TIM_Pulse = a;//比較CCR的值,決定脈沖寬度,決定占空比
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //選擇定時器模式:TIM脈沖寬度調制模式
         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//比較輸出使能TIM_
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
        //TIM_OCInitStructure.TIM_OutputState = TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //輸出極性:TIM輸出比較極性高
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根據T指定的參數初始化外設TIM3 OC2
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //使能TIM3在CCR2上的預裝載寄存器
         TIM_CtrlPWMOutputs(TIM1, ENABLE);
        TIM_Cmd(TIM1,ENABLE);
void pwm(void)
                {TIM_SetAutoreload(TIM1, 0X3000);//設置預裝載寄存器
                TIM_SetCompare1( TIM1,zhankong);//設置占空
ID:988147 發表于 2022-3-13 11:47 | 顯示全部樓層
#include "stm32f10x.h"
int main(void){
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,DISABLE);
        RCC->APB2ENR|=1<<11;             //TIM1時鐘使能
  RCC->APB2ENR|=1<<2;            //使能PORTA時鐘
        RCC->APB2ENR|=1<<3;            //使能PORTB時鐘
        RCC->APB2ENR|=1<<0;     //開啟輔助時鐘
        GPIOA->CRH&=0XFFFFF000;        //清除PA8,9,10配置
        GPIOA->CRH|=0X00000BBB;        //PA8,9,10推挽復用功能輸出 B=1011
        GPIOB->CRH&=0X000FFFFF;        //清除PB13,14,15配置
        GPIOB->CRH|=0XBBB00000;        //PB13,14,15推挽復用功能輸出
        GPIOA->ODR|=1<<8;
        GPIOA->ODR|=1<<9;GPIOA->ODR|=1<<10;
        GPIOB->ODR|=1<<13;
        GPIOB->ODR|=1<<14;GPIOB->ODR|=1<<15;
        TIM1->CCR1=1500;
        TIM1->CCR2=800;
        TIM1->CCR3=1200;
        TIM1->ARR=3000;                        //設定計數器自動重裝值
        TIM1->PSC=30;                        //預分頻器不分頻
        TIM1->BDTR|=0xCD;     // 死區時間設定
        TIM1->CCER|=1<<0;//TIM1CH1通道開關使能
        TIM1->CCER|=1<<2;//TIM1CH1N 通道開關
        TIM1->CCER|=1<<4;
        TIM1->CCER|=1<<6;
        TIM1->CCER|=1<<8;
        TIM1->CCER|=1<<10;
        TIM1->CCMR1|=7<<4;          //CH1 PWM2模式
        TIM1->CCMR1|=1<<3;          //CH1預裝載使能
        TIM1->CCMR1|=7<<12;          //CH2 PWM2模式
        TIM1->CCMR1|=1<<11;         //CH1預裝載使能
  TIM1->CCMR2|=7<<4;          //CH3 PWM2模式
        TIM1->CCMR2|=1<<11;         //CH3預裝載使能
        TIM1->CR1|=0X80;// CR1 ARPE自動重裝載預裝載允許位使能
        TIM1->BDTR|=1<<15;  //剎車使能位置1,開啟所有輸出通道
        TIM1->CR1|=0X01;   //使能定時計數器1
