查看: 2145|回復: 8
單片機動態數碼管和中斷結合的程序問題
ID:1007138 發表于 2022-3-4 18:12 | 顯示全部樓層 |閱讀模式
我想實現一個計分板左三個數碼管和右三個數碼管是分數中間兩個是--,按鍵處理的時候如果把按鍵處理封裝成一個函數的話,再按按鍵的時候數碼管不會顯示,我想沒有這個空窗期,想用中斷試下看,但是不明白這個為什么不行?難道要用定時器計數器?
  1. #include <reg52.h>
  2. typedef unsigned char uchar;
  3. typedef unsigned int  uint;
  4. sbit key1 = P1^0;
  5. sbit key2 = P1^1;
  6. sbit key3 = P1^2;
  7. sbit LSA = P1^3;
  8. sbit LSB = P1^4;
  9. sbit LSC = P1^5;
  10. uint point1 = 0,point2 = 0;
  11. uchar code duan[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  12. uchar disp[8];
  13. void delay(uint z) {
  14.         uint y;
  15.         for (;z>0;z--) {
  16.                 for (y = 0; y < 110; y++) {
  17.                 }
  18.         }
  19. }
  20. void keyzhongduanInit() {
  21.         EA = 1;
  22.         EX0 = 1;
  23.         IT0 = 1;          //下降沿觸發
  24. }
  25. void keypros() interrupt 0 {
  26.         if (key1 == 0) {
  27.                 delay (10);
  28.                 if (key1 == 0) {
  29.                         point1++;
  30.                 }
  31.                 while (!key1);
  32.         }
  33.         if (key2 == 0) {
  34.                 delay (10);
  35.                 if (key2 == 0) {
  36.                         point2++;
  37.                 }
  38.                 while (!key2);
  39.         }
  40.         if (key3 == 0) {
  41.                 delay (10);
  42.                 if (key3 == 0) {
  43.                         point1 = 0;
  44.                         point2 = 0;
  45.                 }
  46.                 while (!key3);
  47.         }
  48. }
  49. void DisplayData() {
  50.         disp[0] = duan[point1 / 100];
  51.         disp[1] = duan[point1 % 100 / 10];
  52.         disp[2] = duan[point1 % 10];
  53.         disp[3] = 0x40;
  54.         disp[4] = 0x40;
  55.         disp[5] = duan[point2 / 100];
  56.         disp[6] = duan[point2 % 100 / 10];
  57.         disp[7] = duan[point2 % 10];
  58. }
  59. void weixuan() {
  60.         uchar i;
  61.         for (i = 0; i < 8; i++) {
  62.                 switch (i) {
  63.                         case (0): LSA = 0;LSB = 0;LSC = 0;break;
  64.                         case (1): LSA = 1;LSB = 0;LSC = 0;break;
  65.                         case (2): LSA = 0;LSB = 1;LSC = 0;break;
  66.                         case (3): LSA = 1;LSB = 1;LSC = 0;break;
  67.                         case (4): LSA = 0;LSB = 0;LSC = 1;break;
  68.                         case (5): LSA = 1;LSB = 0;LSC = 1;break;
  69.                         case (6): LSA = 0;LSB = 1;LSC = 1;break;
  70.                         case (7): LSA = 1;LSB = 1;LSC = 1;break;
  71.                 }
  72.                 P0 = disp[i];
  73.                 delay(1);
  74.                 P0 = 0x00;
  75.         }
  76. }
  77. void main() {
  78.         keyzhongduanInit();
  79.         while (1) {
  80.                 DisplayData();
  81.                 weixuan();
  82.         }
  83. }
ID:161164 發表于 2022-3-4 21:02 | 顯示全部樓層
不要用delay和while(!Key1)!
沒必要用中斷
把keypros()函數放進main()的while(1)里
  1. void keypros()//多鍵短按
  2. {
  3.         static uchar Delay_XD=0;                        //消抖計數
  4.         if(!key1 || !Key2 || !Key3)
  5.         {
  6.                 if(Delay_XD<0xFF)Delay_XD++;
  7.                 if(Delay_XD==50)                        //調節消抖時間
  8.                 {
  9.                         if(!key1)
  10.                         {
  11.                                 point1++;
  12.                         }
  13.                         if(!Key2)
  14.                         {
  15.                                 point2++;
  16.                         }
  17.                         if(!key3)
  18.                         {
  19.                                 point1 = 0;
  20.                                 point2 = 0;
  21.                         }
  22.                 }
  23.         }
  24.         else                                                        //按鍵抬起
  25.                 Delay_XD=0;                                        //Delay_XD清0
  26. }
ID:213173 發表于 2022-3-4 21:13 | 顯示全部樓層
  4. /*
  5. sbit key1 = P1^0;
  6. sbit key2 = P1^1;
  7. sbit key3 = P1^2;
  8. sbit LSA = P1^3;
  9. sbit LSB = P1^4;
  10. sbit LSC = P1^5;
  11. **/
  12. uint point1=0,point2=0;
  13. uchar code duan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  14. uchar disp[8]={0,0,0,0x40,0x40,0,0,0};
  15. void delay(uint z)
  16. {
  17.         uint y;
  18.         for(;z>0;z--)
  19.                 for(y=0;y<110;y++);
  20. }
  21. void key_scan()
  22. {
  23.         static uchar count=0;
  24.         static bit key_sign=0;
  25.         uchar key_value=P1&0x07;
  26.         if(key_value!=0x07)
  27.         {
  28.                 if(++count>=10 && key_sign==0)
  29.                 {
  30.                         key_sign=1;
  31.                         switch(key_value)
  32.                         {
  33.                                 case 0x06: if(point1<100)point1++; break;
  34.                                 case 0x05: if(point2<100)point2++; break;
  35.                                 case 0x03: point1=0;point2=0; break;
  36.                                 default: break;
  37.                         }
  38.                 }
  39.         }
  40.         else
  41.         {
  42.                 count=0;
  43.                 key_sign=0;
  44.         }
  45. }
  46. void DisplayData()
  47. {
  48.         disp[0] = duan[point1/100%10];
  49.         disp[1] = duan[point1/10%10];
  50.         disp[2] = duan[point1%10];
  51.         disp[5] = duan[point2/100%10];
  52.         disp[6] = duan[point2/10%10];
  53.         disp[7] = duan[point2%10];
  54. }
  55. void weixuan()
  56. {
  57.         static uchar i;
  58.         P0=0x00;
  59.         P1&=0xc7;
  60.         P1|=i<<3;
  61.         P0=disp[i];
  62.         i=++i%8;
  63. }
  64. void main()
  65. {
  66.         while (1)
  67.         {
  68.                 key_scan();
  69.                 DisplayData();
  70.                 weixuan();
  71.                 delay(1);
  72.         }
  73. }
ID:1007138 發表于 2022-3-5 13:04 | 顯示全部樓層
wulin 發表于 2022-3-4 21:13
按鍵掃描和數碼管動態顯示代碼,常見有十多鐘寫法。你選擇了兩個最差的寫法。給你改了一下,你試試。
請問++count>=10是消抖用嗎?還有P1&=0xc7;
        P1|=i<<3;這兩句話沒看懂什么意思
ID:1007138 發表于 2022-3-5 13:17 | 顯示全部樓層
小小彩姬 發表于 2022-3-5 13:04
        P1|=i
后面兩句話懂了,但是按鍵模塊里的count和key_sign是做什么的呢?
感謝大佬指導
ID:1007138 發表于 2022-3-5 13:24 | 顯示全部樓層
怎么感覺++count>=10實現不了呢?如果有按鍵按下的話,count才加1.這里好像不會循環判斷吧為什么會超過10呢?不解
ID:213173 發表于 2022-3-5 14:35 | 顯示全部樓層
小小彩姬 發表于 2022-3-5 13:24
怎么感覺++count>=10實現不了呢?如果有按鍵按下的話,count才加1.這里好像不會循環判斷吧為什么會超過10 ...
非特殊情況不要用delay阻滯型延時和 while (x)死等。在幾乎所有程序中都要讓主循環不停跑起來。在這個示例中用delay的目的是控制主循環周期約1ms,也就是1ms時間子函數輪詢一遍。按鍵按下count計數10次約10ms與按鍵狀態key_sign標志“相與”,滿足條件執行相應語句。key_sign=1,下次輪詢時沒有松手就不會重復執行。直到松手key_sign=0。數碼管動態掃描同樣是1ms顯示1位,這樣按鍵和數碼管就不會互相干擾了。
ID:1007138 發表于 2022-3-5 15:47 | 顯示全部樓層
wulin 發表于 2022-3-5 14:35
非特殊情況不要用delay阻滯型延時和 while (x)死等。在幾乎所有程序中都要讓主循環不停跑起來。在這個示 ...
這個count的意思是等一段時間先讓數碼管先亮起來,然后再做按鍵處理吧?最后的延時1ms好像可以去掉
ID:1007138 發表于 2022-3-5 16:06 | 顯示全部樓層
小小彩姬 發表于 2022-3-5 15:47
請問這里為什么可以不延時1ms數碼管顯示,以前那個為什么要延時的
