查看: 2060|回復(fù): 4
關(guān)于單片機(jī)定時(shí)器中用按鍵控制蜂鳴器
ID:1000562 發(fā)表于 2022-2-25 10:33 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
其中,我設(shè)置的按鍵對(duì)蜂鳴器進(jìn)行控制,但是在仿真的時(shí)候,按鍵按下,蜂鳴器并不響,同時(shí)數(shù)碼管的倒計(jì)時(shí)顯示也受到了影響
#define _MAIN_C
#include "use.h"
#include "main.h"
#include "time.h"
#include "key.h"
bit flag1s;
sbit nsg = P2^0;
sbit nsy = P2^1;
sbit nsr = P2^2;
sbit weg = P2^5;
sbit wey = P2^4;
sbit wer = P2^3;
sbit k1 = P3^5;
sbit k2 = P3^6;
sbit bp = P1^0;
int key1 = 1;
int key2 = 1;
int Bun=0;
uchar count1s,NS_time,WE_time;
uchar GreenTime=30,RedTime=35;
uchar index=0;
enum eStaSysterm StaSysterm=NormalRun;
void Beep_on()
        bp=~bp;
        Delay10us(2000);
void keypros1()
        if(k1 == 0)
                if(wer == 1)
                                key1 = 2;
                                Bun=10;
        while(!k1);
void keypros2()
        if(k2 == 0)
                if(nsr == 1)
                        key2 = 2;
                        Bun=10;
        while(!k2);
        EA=1;
        InintTimer0();
                LEDScan();
                KeyDriver();
                keypros2();
                keypros1();
                if((Bun > 0 && key1 == 2) || (Bun > 0 && key2 == 2)  )
                        Beep_on();
                        Bun--;
                if(Bun<0)
                        key1=1;
                        key2=1;
                if(flag1s)
                        flag1s=0;
                        NS_time--;
                        WE_time--;
void InintTimer0()
        TMOD=0X01;
        TH0=0X4C;
        TL0=0X00;
        ET0=1;
        TR0=1;
void Timer0() interrupt 1
        TH0=0XBB;
        TL0=0X00;
        KeyScan();
        if(++count1s<50)        return;
        count1s=0;
        if(StaSysterm==NormalRun) flag1s=1;
void LEDScan()
                if(NS_time==0 || WE_time==0)
                        switch(index)
                                case 0:
                                        index=1;
                                        NS_time=GreenTime;
                                        WE_time=RedTime;
                                        P2=0x09;
                                }break;
                                case 1:
                                        index=2;
                                        NS_time=RedTime-GreenTime;
                                        P2=0X0A;
                                }break;
                                case 2:
                                        index=3;
                                        NS_time=RedTime;
                                        WE_time=GreenTime;
                                        P2=0X24;
                                }break;
                                case 3:
                                        index=0;
                                        WE_time=RedTime-GreenTime;
                                        P2=0X14;
                                }break;
                                default:break;
                Seg_Display(NS_time/10,0);
                Seg_Display(NS_time%10,1);
                Seg_Display(WE_time/10,2);
                Seg_Display(WE_time%10,3);
        else if(StaSysterm==UrgentRun)
                P2=0x12;
                Delayms(200);
                P2=0x00;
                Delayms(200);
ID:584814 發(fā)表于 2022-2-25 15:23 | 只看該作者
void Beep_on()
        bp=~bp; //蜂鳴器分有源、無源,不響是用了后者或器件問題
        Delay10us(2000);//蜂鳴器觸發(fā)后延時(shí),程序中更新顯示要等這個(gè)結(jié)束
ID:1006187 發(fā)表于 2022-2-25 15:33 | 只看該作者
沒仔細(xì)看,不過你KEYSCAN放中斷里不對(duì),軟件邏輯有問題
ID:135723 發(fā)表于 2022-2-25 21:48 | 只看該作者
蜂鳴器,按鍵掃描中都不應(yīng)該有軟件延時(shí)這種阻塞延時(shí),通過定時(shí)器計(jì)數(shù)方式實(shí)現(xiàn)無阻塞延時(shí)。
ID:123289 發(fā)表于 2022-2-26 10:50 | 只看該作者
不看程序了,查查有沒有在中斷中用了DELAY()!
