查看: 2185|回復: 3
單片機超聲波測距和倒計時的定時器怎么弄?搞不清楚
ID:1005855 發表于 2022-2-23 20:36 | 顯示全部樓層 |閱讀模式
10黑幣
#include <reg52.h>
#include <intrins.h>
#include <lcd.h>
sbit key1=P3^0;  //設置鍵
sbit key2=P3^1;  //加鍵
sbit key3=P3^2;  //減鍵
sbit key4=P3^3;  //開始鍵
sbit beep=P2^4;
sbit trig=P1^1;
sbit echo=P1^0;
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
uchar djshi,djfen,djmiao=10;
uchar r,num,s;
uchar distance,t;
bit flag=0;
uchar code table1[]={"time: 00:00:00  "};
uchar code table2[]={"                "};
uchar code table3[]={"chaochuceliangzhi"};
uchar cc[4]={0,0,0};
void LcdInit()                                                  //LCD初始化子程序
                uchar i;
                lcd_writecom(0x38);  //開顯示
                lcd_writecom(0x0c);  //開顯示不顯示光標
                lcd_writecom(0x06);  //寫一個指針加1
                lcd_writecom(0x01);  //清屏
                lcd_writecom(0x80);  //設置數據指針起點
                for(i=0;i<16;i++)
                                lcd_writedate(table1[ i]);[ i]
                lcd_writecom(0xc0);
                        for(i=0;i<17;i++)
                                lcd_writedate(table2[ i]);[ i]
void Timer0Init(void)                //
                TMOD = 0x11;                //使用定時器T0的模式1  定時器T1的模式1
                TL0 = 15536%256;                //設置定時0初值
                TH0 = 15536/256;                //設置定時0初值
                TR0 = 1;                //定時器0開始計時
                ET0=1;
                EA=1;
* 函 數 名         : Delay1ms
* 函數功能                   : 延時函數,延時1ms
* 輸    入         : c
* 輸    出         : 無
* 說    名         : 該函數是在22.1184MHZ晶振下,12分頻單片機的延時。
void Delay1ms(uint n)
   uint x,y;
    for(x=n;x>0;x--)
         for(y=110;y>0;y--);
void write_sfm(uchar add,uchar date)
                lcd_writecom(0x80+add);
                lcd_writedate(date/10+0x30);
                lcd_writedate(date%10+0x30);
                lcd_writecom(0x80+add+1);
void keyscan()
                if(key1==0)
                                Delay1ms(5);
                                if(key1==1)
                                                num++;
                                                TR0=0;
                                                while(!key1);
                                                if(num==1)
        lcd_writecom(0x0f);
        lcd_writecom(0x8D);
                                                if(num==2)
        lcd_writecom(0x8A);
                                                if(num==3)
        lcd_writecom(0x87);
                                                if(num==4)
        lcd_writecom(0x0c);
        num=0;
        TR0=1;
                if(num==1)
                                if(key2==0)
                                                Delay1ms(5);
                                                if(key2==0)
        djmiao++;
        while(!key2);
        if(djmiao==60)
        djmiao=0;
        lcd_writecom(0x8c);
        lcd_writedate(djmiao/10+0x30);
        lcd_writedate(djmiao%10+0x30);
        lcd_writecom(0x8D);
                                if(key3==0)
                                                Delay1ms(5);
                                                if(key3==0)
        djmiao--;
        while(!key3);
        if(djmiao==255)
        djmiao=59;
        lcd_writecom(0x8c);
        lcd_writecom(0x8D);
                if(num==2)
                                if(key2==0)
                                                Delay1ms(5);
                                                if(key2==0)
        djfen++;
        while(!key2);
        if(djfen==60)
        djfen=0;
        lcd_writecom(0x89);
        lcd_writedate(djfen/10+0x30);
        lcd_writedate(djfen%10+0x30);
        lcd_writecom(0x8A);
                                if(key3==0)
                                                Delay1ms(5);
                                                if(key3==0)
        djfen--;
                                                        while(!key3);
        if(djfen==255)
        djfen=59;
        lcd_writecom(0x89);
        lcd_writecom(0x8A);
                if(num==3)
                                if(key2==0)
                                                Delay1ms(5);
                                                if(key2==0)
        djshi++;
        while(!key2);
        if(djshi==24)
        djshi=0;
        lcd_writecom(0x86);
        lcd_writedate(djshi/10+0x30);
        lcd_writedate(djshi%10+0x30);
        lcd_writecom(0x88);
                                if(key3==0)
                                                Delay1ms(5);
                                                if(key3==0)
        djshi--;
        while(!key3);
        if(djshi==255)
        djshi=23;
        lcd_writecom(0x86);
        lcd_writecom(0x88);
                if(key4==0)
                                Delay1ms(5);
                                if(key4==0)
                                                s++;
                                                while(!key4);
                                                if(s==1)
        TR0=0;
                                                if(s==2)
        TR0=1;
                                                if(s==3)
        s=0;
        TR0=0;
        LcdInit();
        djshi=0;
        djfen=0;
        djmiao=0;
void fmq()
        beep=1;
        Delay1ms(5);
        beep=0;
        Delay1ms(5);
                LcdInit();
                Timer0Init();
                trig=0;
        TH1=TL1=0;
                        trig=1;
                        TR1=1;
                        Delay1ms(1);
                        trig=0;
                        TR1=0;
                        while(echo==0);
                        TR1=1;
                        while(echo==1)
                        TR1=0;
                        t=TH1*256+TL0;
                        s=t*0.017;
                        lcd_writecom(0xc0);
                        lcd_writedate(s/100+0x30);
                                keyscan();
                                if(djshi==0 && djfen==0 &&djmiao==0)  //倒計時時間到
                                                TR0=0;          //停止計時
                                          fmq();
void Timer0() interrupt 1
                TL0 = 15536%256;                //設置定時初值
                TH0 = 15536/256;                //設置定時初值
                r++;
                if(r==20)
                                r=0;
                                djmiao--;
                                if(djmiao==255)
                                                djmiao=59;
                                                djfen--;
                                                if(djfen==255)
        djfen=59;
        djshi--;
        if(djshi==255)
        djshi=0;
        if(djshi==0)
        djfen=59;
        if(djfen==0&djshi==0)
        djfen=0;
        write_sfm(6,djshi);
                                                write_sfm(9,djfen);
                                        write_sfm(12,djmiao);
ID:262 發表于 2022-2-23 21:45 | 顯示全部樓層
哪一行搞不清楚?大家幫你研究下
ID:1005855 發表于 2022-2-24 21:29 | 顯示全部樓層
使用超聲波測距程序的時候,倒計時程序不能使用,而且我不知道怎么同時使用兩個定時器,用兩個定時器的時候,倒計時等于0后,定時器1好像沒有關閉,倒計時會重新驅動
ID:123289 發表于 2022-2-26 14:03 | 顯示全部樓層
去看書,重點了解:
1、如何設置定時器。
2、如何起動定時器。
3、如何停止定時器計數工作。
明白后再研究一下程序。
