查看: 2071|回復: 4
想寫一個單片機計算器,不知道為什么輸入的數(shù)不超過255
ID:1004248 發(fā)表于 2022-2-8 19:57 | 顯示全部樓層 |閱讀模式
#include <REGX51.H>
unsigned char a[]={0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
unsigned char b[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80 } ;
unsigned char d[]={~0x21,~0x12,~0x22,~0x42,~0x14,~0x24,~0x44,~0x18,~0x28,~0x48};
unsigned char e[]={~0x01,~0x02,~0x04,~0x08};
unsigned char c[8];
unsigned int i,j,k,l,n,nm,ny;
unsigned int y1,y2;
unsigned int x=5;
void delay(unsigned int x)
        x--;
void shuguan(unsigned int m)
        j=0;
        if(m!=0)
            n=m;
                do
                  j++;
                m=m/10;
                }while(m!=0);
                k=1;
                m=n;
                while(k<=j)
                        l=m;
                        m=m/10;
                        c[8-k]=a[l-10*m];
                        k++;
                k=j;
                i=0;
                while((8-k)>0)
                        c[ i]=0xff;
                        i++;
                        k++;
                for(i=0;i<7;i++)
                {        c[ i]=0xff;
                c[7]=a[0];
        for(i=0;i<8;i++)
                P0=0xff;
                P2=b[ i];
                P0=c[ i];
                delay(300);
void anj()
        for(i=0;i<4;i++)
                P1=e[ i];
                if(P1!=e[ i])
                   y2=i          ;
                        for(nm=0;nm<10;nm++)
                                if(P1==d[nm])
                                         ny=nm;
                                        y1=1;
                if(i==y2)
                        if(P1==e[ i]&&y1==1)
                                x=x*10+ny;
                                y1=0;
        x=2;
        shuguan(x);
        anj();
計算器.zip
56.66 KB, 下載次數(shù): 4
ID:1004248 發(fā)表于 2022-2-8 19:58 | 顯示全部樓層
ID:161164 發(fā)表于 2022-2-9 07:44 來自觸屏版 | 顯示全部樓層
沒有注釋,變數(shù)只用簡單字,誰有耐心去看?
ID:908826 發(fā)表于 2022-2-9 09:21 | 顯示全部樓層
啊,看見255,就要想到無符號字符型變量的取值范圍,0~255.
ID:415064 發(fā)表于 2022-2-9 14:00 | 顯示全部樓層
數(shù)據(jù)溢出
